Technical details on how this works are still unknown. The hardware of the Xbox 360 is very different from the hardware of the Xbox One, and pure emulation of the kind used in console emulators such as MESS and arcade emulators like MAME is technically improbable; Xbox 360 is simply too fast, too new. The limited compatibility and need to download even those games that are owned on disc suggests to us that some mix of recompilation and emulation is in use.
The WiiU doesn't emulate the Wii. It has the same hardware as the Wii built into it, just like the Gamecube was essentially built into the Wii.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206521#p29206521:2sitmrp8 said:soulsabr[/url]":2sitmrp8]Ye gods let them do this better than what Nintendo did with the Wii to WiiU. Emulate the Wii but remove all of the cool features of the WiiU like using the control pad as your TV screen.
You mean the execs over there with the dark glasses, fingers in their ears, singing "la la la la la"?[url=http://meincmagazine.com/civis/viewtopic.php?p=29206579#p29206579:h34su8bo said:LimpBagel[/url]":h34su8bo]I hope Nintendo notices how they aren't charging customers a fee to re-buy the same game on a new platform.
Have you not used a Wii U? You can stream original Wii games to the pad, and the pad has a mini sensor bar in it.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206521#p29206521:2hci2sb5 said:soulsabr[/url]":2hci2sb5]Ye gods let them do this better than what Nintendo did with the Wii to WiiU. Emulate the Wii but remove all of the cool features of the WiiU like using the control pad as your TV screen.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29206579#p29206579:26yuju2i said:LimpBagel[/url]":26yuju2i]I hope Nintendo notices how they aren't charging customers a fee to re-buy the same game on a new platform.
They're doing the same thing they did for original Xbox games on 360. It isn't a compatibility layer, MS just isn't using the binaries on the disc or in the download and is using a special one created for the new system. This is why it doesn't work for every game.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206633#p29206633:30p1kvt2 said:yeahreally[/url]":30p1kvt2]From what I understand, the Xbox OS and games run as virtual machines under a hypervisor. It's possible that they've got a guest image that allows 360 games to run on the hypervisor. I always wondered if they would use that for allowing backwards compatibility with the next generation of hardware, but I didn't think they'd do it with this past generation.
There's no reason Sony can't do this too. It isn't emulation so CELL isn't an issue.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206635#p29206635:30p1kvt2 said:gijames1225[/url]":30p1kvt2]Very smart, they're going where Sony can't follow. This may actually make my buy a Xbox One this Fall instead of a PS4 like I was planning to.
That isn't QUITE true. Yes it is native but it also can access WiiU features as Wikipedia (which is never wrong) states. Anyhow, I stand thoroughly corrected. Must be the mind bleach from an earlier discussion on robotic heads.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206601#p29206601:1ske3tv6 said:Mgamerz[/url]":1ske3tv6]The WiiU doesn't emulate the Wii. It has the same hardware as the Wii built into it, just like the Gamecube was essentially built into the Wii.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206521#p29206521:1ske3tv6 said:soulsabr[/url]":1ske3tv6]Ye gods let them do this better than what Nintendo did with the Wii to WiiU. Emulate the Wii but remove all of the cool features of the WiiU like using the control pad as your TV screen.
As such it doesn't have access to WiiU features.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29206673#p29206673:hpagqen4 said:Mitlov[/url]":hpagqen4]Huh. I just recently bought a 360 instead of an XBO because there were so many 360 games I wanted to play, and the XBO wasn't backwards-compatible. I don't have buyer's remorse--I got a great price on the 360--but I'm glad for other buyers that that's no longer an issue and they can just buy an XBO for the best of both worlds.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29206677#p29206677:3ab6xfg5 said:Danrarbc[/url]":3ab6xfg5]They're doing the same thing they did for original Xbox games on 360. It isn't a compatibility layer, MS just isn't using the binaries on the disc or in the download and is using a special one created for the new system. This is why it doesn't work for every game.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206633#p29206633:3ab6xfg5 said:yeahreally[/url]":3ab6xfg5]From what I understand, the Xbox OS and games run as virtual machines under a hypervisor. It's possible that they've got a guest image that allows 360 games to run on the hypervisor. I always wondered if they would use that for allowing backwards compatibility with the next generation of hardware, but I didn't think they'd do it with this past generation.
There's no reason Sony can't do this too. It isn't emulation so CELL isn't an issue.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206635#p29206635:3ab6xfg5 said:gijames1225[/url]":3ab6xfg5]Very smart, they're going where Sony can't follow. This may actually make my buy a Xbox One this Fall instead of a PS4 like I was planning to.
It is replacing the binaries, not all of the content.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206747#p29206747:32natii1 said:gijames1225[/url]":32natii1][url=http://meincmagazine.com/civis/viewtopic.php?p=29206677#p29206677:32natii1 said:Danrarbc[/url]":32natii1]They're doing the same thing they did for original Xbox games on 360. It isn't a compatibility layer, MS just isn't using the binaries on the disc or in the download and is using a special one created for the new system. This is why it doesn't work for every game.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206633#p29206633:32natii1 said:yeahreally[/url]":32natii1]From what I understand, the Xbox OS and games run as virtual machines under a hypervisor. It's possible that they've got a guest image that allows 360 games to run on the hypervisor. I always wondered if they would use that for allowing backwards compatibility with the next generation of hardware, but I didn't think they'd do it with this past generation.
There's no reason Sony can't do this too. It isn't emulation so CELL isn't an issue.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206635#p29206635:32natii1 said:gijames1225[/url]":32natii1]Very smart, they're going where Sony can't follow. This may actually make my buy a Xbox One this Fall instead of a PS4 like I was planning to.
So you'll have to re-download a custom version of each 360 game you want to play? Even if you have the disc? Interesting, and not quite as exciting, but still nice to have.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29206677#p29206677:1x8i056f said:Danrarbc[/url]":1x8i056f]They're doing the same thing they did for original Xbox games on 360. It isn't a compatibility layer, MS just isn't using the binaries on the disc or in the download and is using a special one created for the new system. This is why it doesn't work for every game.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206633#p29206633:1x8i056f said:yeahreally[/url]":1x8i056f]From what I understand, the Xbox OS and games run as virtual machines under a hypervisor. It's possible that they've got a guest image that allows 360 games to run on the hypervisor. I always wondered if they would use that for allowing backwards compatibility with the next generation of hardware, but I didn't think they'd do it with this past generation.
There's no reason Sony can't do this too. It isn't emulation so CELL isn't an issue.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206635#p29206635:1x8i056f said:gijames1225[/url]":1x8i056f]Very smart, they're going where Sony can't follow. This may actually make my buy a Xbox One this Fall instead of a PS4 like I was planning to.
Using disc assets doesn't make something an emulator. And emulator runs unmodified binaries on a new platform, which Xbox 360 BC certainly wasn't. Sounds like this is also using assets off the disc if you have a disc, just saving them to the hard drive.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206801#p29206801:nphyzd63 said:salamanderjuice[/url]":nphyzd63][url=http://meincmagazine.com/civis/viewtopic.php?p=29206677#p29206677:nphyzd63 said:Danrarbc[/url]":nphyzd63]They're doing the same thing they did for original Xbox games on 360. It isn't a compatibility layer, MS just isn't using the binaries on the disc or in the download and is using a special one created for the new system. This is why it doesn't work for every game.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206633#p29206633:nphyzd63 said:yeahreally[/url]":nphyzd63]From what I understand, the Xbox OS and games run as virtual machines under a hypervisor. It's possible that they've got a guest image that allows 360 games to run on the hypervisor. I always wondered if they would use that for allowing backwards compatibility with the next generation of hardware, but I didn't think they'd do it with this past generation.
There's no reason Sony can't do this too. It isn't emulation so CELL isn't an issue.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206635#p29206635:nphyzd63 said:gijames1225[/url]":nphyzd63]Very smart, they're going where Sony can't follow. This may actually make my buy a Xbox One this Fall instead of a PS4 like I was planning to.
You're right about this but for Xbox 360 Backwards compatibility it actually was an emulator. Games need their own specific tweaks to work but it still read and used the assets off the disk. I hope Sony does something similar and at least gets PS1 classics on PS4 already.
Mass Effect was shown during the announcement, so that's almost definitely coming.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206611#p29206611:1b5s8pmh said:dfjdejulio[/url]":1b5s8pmh]Well now. If the backwards compatibility list includes "Bioshock", "Mass Effect", and "Rock Band: The Beatles", Microsoft just sold me an XB1.
(If it includes at least one of those plus a few others I really care about, that might do the trick too.)
I don't think it's using the disc for anything but confirming you own the game; Note that you only need the disc if you didn't it digitally, and it says it downloads the game fully.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206809#p29206809:35t78cmh said:Danrarbc[/url]":35t78cmh] Sounds like this is also using assets off the disc if you have a disc, just saving them to the hard drive.
They showed Mass Effect running on the Xbox One during the announcement. The list is due out later today. It was part of Microsoft's E3 press conference, so it was only one small part of the overall press conference, which is why more details are forthcoming once the press conference is over.[url=http://meincmagazine.com/civis/viewtopic.php?p=29206851#p29206851:tauy9719 said:maxwell[/url]":tauy9719]What is the point of pre-announcing something like this?
I've seen enough grand proclamations from Microsoft to wait out this one. Show us the list. Show us a working 360 title on an Xone...or be quiet about it.
