all for the purpose of fulfilling some DEI goal.
Are you suggesting that Artemis SHOULD continue?
Not so much throwing people under the bus but holding the necessary people accountable for putting ego and image above the safety of actual human beings. I can imagine the amount of furor that occurred in those internal meetings about this before Isaacman's official letter came out.
"should the uncrewed test flight in 2026 go well"I thought Starliner-1 was going to be cargo only given there hasn't been a single successful flight yet. That crew wouldn't happen until Starliner-2. Three for three failures and they are even considering humans on the next flight? JFC. Take what I said above and double it.
Jonathan McDowell has both it and the full report hosted.Is there a version of the NASA administrator letter available without having to head over to Xitter ?
They said in the conference something about one of the possible reasons for declaring something a "Type A mishap" is if it costs at least two million dollars.Maybe it's bad reading comprehension on my part, but what does the "type A" classification mean? What are the other mishap classifications?
It didn't miss the earth, and came down in one piece. That's Boeing flawless.I must have missed somewhere in all of this that the return to earth, uncrewed, on the return, there were ALSO thruster failures.
I thought Boeing had said that the return to earth was 'flawless'
by those definitions, I suppose "didn't burn up on re-entry" also adds to the list.It didn't miss the earth, and came down in one piece. That's Boeing flawless.
Terribly easy? Really?It's terribly easy to dish out blame if the incident in question predates you being installed in the post.
Thanks.Jonathan McDowell has both it and the full report hosted.
Letter: https://planet4589.org/space/misc/starliner26.ji.pdf
Report: https://planet4589.org/space/misc/starliner26.pdf
The issue was a bit more pernicious than that.The first uncrewed test wasn't a "near failure". It was a complete failure. Yes, they got the vehicle back intact, but it didn't complete the primary mission objectives, and it didn't give them enough info to fix the problems on the next try.
This makes you curious what they had expectedStill, after astronauts Butch Wilmore and Suni Williams eventually docked at the station, Boeing officials declared success. “We accomplished a lot, and really more than expected,”
NASA put a huge amount of effort into trying to assert that the heat shield risk had been worked through: but what I think is open to discussion: what else on the risk manifest wasn't retired as completelyNot flying Artemis 2 with humans on board would be a decision worthy of praise.
Unfortunately, this Administrator apparently, and at least so far, also subscribes to the 'hold your breath and push the button' approach to human spaceflight, when convenient.
I will react today exactly as I did in the comments of that the article that covered that: Taht was Bridenstine being a good politician and saving as much face for a valued contractor as he could. His words didn't matter. What would matter was his (and NASA's) actions. And as it turns out, the actions were spot-on. NASA forced Boeing to refly OFT-1.Yeah, but we remember that at the time, after we were still blinking in disbelief at our screens after formal coverage of the test flight finished, and after an hour delay to the presser in order to get their stories straight, that when the feed returned, Jim Bridenstine stared into the camera and confidently announced that "Today, a lot of things went right."
This 2014 message still applies:View attachment 128676
Less manual manoeuvring, probably.This makes you curious what they had expected
Since it happened 40 years ago, there may not be many of us who remember Challenger. Isaacman was only 3 years old so he probably does not remember it, but most likely he has studied it. And to make a black humor reference, Richard Feynman (a dying physicist) was "Schrodinger fired" - simultaneously fired and not fired - from the review board until Sally Ride (a famous NASA astronaut) stepped in and threatened to publicly quit the board unless Feynman and his findings were restored.They killed 8 astronauts twice and nobody so much as lost their job or had a demotion. A few resigned but weren't forced out. In fact the only action in the aftermath of Challenger disaster was to sideline the contractor who warned NASA endlessly that launching under those conditions had a serious risk of a fatal accident. See the problem wasn't killing eight crew the problem was this guy who kept warning us and removing any plausible deniability.
So if they killed two more I wouldn't expect much would change without outside action. "Thoughts and prayers. Space is dangerous. We must continue Butch and Suni's legacy."
Yes at that point Boeing's software appeared so bad that the notion the thrusters fired so much they damaged themselves seemed not only possible but probable. I guess the fact that the thrusters that ultimately failed were not randomly distributed somehow went unobserved though. I would like to think were I am engineer on that project (thank god I'm not) and all the ones that failed just happened to be aft facing I might have at least gone, huh?The issue was a bit more pernicious than that.
The thrusters overheated on OFT-1. But the clock error triggering precision-keeping mode was a reasonable explanation for that issue. So it wasn't that Boeing didn't get enough information to fix the problem, they didn't get enough information to know they had a (thruster) problem in the first place.
Honestly, that may be better than we had any business expecting. That it would enter the earth's atmosphere in a correct orientation seemed like a 50/50 proposition to me.It didn't miss the earth, and came down in one piece. That's Boeing flawless.
Wasn't it obvious that wasn't a real exchange? Even if Boeing and NASA had those thoughts, they'd never express them that bluntly or briefly.Where is a reliable source for that quoted exchange? Google doesn't have any record of it in search results.
And even if that is accurate, the government not wanting to lay off a lot of its employees just because a private contractor failed to deliver under the budget it proposed to win the contract seems entirely legitimate.
But what really makes what you're posting deeply suspect is that we are continuing a thread in this discussion where you said that the Artemis program's sole purpose was "DEI". Which is not only obviously false, but is exactly the kind of slander that Trump cultists chant while posting lying memes. Trump cultists who heiled at Musk's DOGE getting rid of a lot of government employees who were in Musk's way.
So where is that reliable source for that quoted exchange? Just because you're popping off so many red (hat) flags doesn't mean you're definitely lying about the quotes you posted. But until you back it up it's a safe assumption.
Here's the document with the full list of classifications.
Are y'all seriously going to ban one of your most prolific posters who often adds to discussions relating to spaceflight for no better reason than that heused a naughty word twice in responding to a bigoted and asinine post?Fuck off bigot. Just fuck off. This is like the fourth or fifth time you went on your white man cryfest in various topics. Seems it is all you care about.
Also no that isn't the only stated objective of Artemis.
To be clear Trump was not proposing enidng Artemis now. In fact their budget proposal over funded Artemis II and III only to zero it out AFTER a human landing on the moon because he thinks it will happen on his term and he will "get credit".
The upcoming cargo flight exists so that NASA will be the ones paying for another test flight before putting crew on board again. It's an end-run around the CC contract but at least NASA will be getting some service out of it.Did anyone outside of Boeing and NASA think Starliner had been proven safe to carry humans after the results of the second test flight? I sure as hell didn't. Shouldn't they try to at least get one flight without any failures that called into question whether Starliner could successfully fly to ISS and back?
That was a colossal failure of judgment, probably motivated by the desire to keep Boeing involved in the Commercial Crew program. I understand the desire to avoid being reliant on a single contractor, but that can't justify the risks they took by not requiring another uncrewed test to prove that theprevious failures had been solved.
He got threadbanned and a week off. Please do not make drama about moderator actions.Are y'all seriously going to ban one of your most prolific posters who often adds to discussions relating to spaceflight for no better reason than that heused a naughty word twice in responding to a bigoted and asinine post?
That's an overreaction.
