Nitpick: It isn't, not by any physical metric you could associate with "size".Apple is the world's largest company
The USRP B100 architecture includes a Xilinx® Spartan® 3A 1400 FPGA, 64 MS/s dual ADC, 128 MS/s dual DAC and USB 2.0 connectivity to provide data to host processors. A modular design allows the USRP B100 to operate from DC to 6 GHz.
Bah! You've beaten me to it. :-(ColinABQ":2cusw5dv said:I haven't read all of this article yet, but it's already reminded me of a prior one, at the other end of the scale:
http://meincmagazine.com/information-technology/2012/06/how-to-blow-6-billion-on-a-tech-project/
Not so stupid a question actually. I also wondered about that.redleader":15bppifj said:So stupid question:
How do these software radios actually work electrically? Are they reprogrammable tuners/mixers or are they literally just parking an oscillator at some frequency and running a really fast A/D to capture everything moving through the air over a very wide band?
Can they simultaneously read in 1 GHz and 2 GHz transmission for instance?
redleader":bqzrhyze said:So stupid question:
pepoluan":jdm0qe3b said:Not so stupid a question actually. I also wondered about that.redleader":jdm0qe3b said:So stupid question:
Due to the nature of electromagnetic, signals need to be modulated or EM waves will not be emitted.
pepoluan":jdm0qe3b said:Plus, the antennas must be at least as long as 1/4 lambda and (IIRC) not multiples of 1/2 lambda. This practically limits the usable wavelengths used, introducing "blind spots" here and there.
JustAdComics":29ernhjt said:Very interesting article. I wonder if some form of widely-dispersed radio astronomy could be done with this, akin to the SETI@home project? Given enough of these units spread across a huge geographic area, the right kind of software could create a virtual antenna with a ginormous radius.
It's hard to say for sure, but I think there's a very good chance that will not actually end up being a huge deal, at least once society adjusts. The key factor is that, of the entire range of technology crimes, or even crimes in general, it's hard to think of many where a person or item announces the problem more clearly. "Maliciousness" and "incompetence" appear to be similar here: someone sets up a device that, either by intention or just simple misconfiguration, ends up being a bad EM citizen and pumps out too much power too randomly, thus acting like a jammer and mucking things up for others. However, by definition anything operating with that kind of power is dead easy to find by anyone at all. The exact same physics that cause it to mess with other network equipment also means it's a big fat "Here I Am" sign.mikecyber":33ik9lrh said:What happens when people decide to intentionally be malicious?
sigmasirrus":204dji81 said:Wow, I can't believe nobody thought of this already! Kudos!
sigmasirrus":sv9w3wmo said:Wow, I can't believe nobody thought of this already! Kudos!
redleader":1gxalide said:How do these software radios actually work electrically? Are they reprogrammable tuners/mixers or are they literally just parking an oscillator at some frequency and running a really fast A/D to capture everything moving through the air over a very wide band?
In terms of a dipole, that's mostly correct but a more complex wide-band antenna could be used.redleader":1gxalide said:Can they simultaneously read in 1 GHz and 2 GHz transmission for instance?
xoa":247s5snl said:It's hard to say for sure, but I think there's a very good chance that will not actually end up being a huge deal, at least once society adjusts. The key factor is that, of the entire range of technology crimes, or even crimes in general, it's hard to think of many where a person or item announces the problem more clearly. "Maliciousness" and "incompetence" appear to be similar here: someone sets up a device that, either by intention or just simple misconfiguration, ends up being a bad EM citizen and pumps out too much power too randomly, thus acting like a jammer and mucking things up for others. However, by definition anything operating with that kind of power is dead easy to find by anyone at all. The exact same physics that cause it to mess with other network equipment also means it's a big fat "Here I Am" sign.mikecyber":247s5snl said:What happens when people decide to intentionally be malicious?
Fractal antennas should minimize the blind spots.pepoluan":1xo88c9i said:Not so stupid a question actually. I also wondered about that.redleader":1xo88c9i said:So stupid question:
I'm not saying that those limitations are insurmountable, but designing/engineering around them would surely introduce additional complexities, and hence, increased cost.
iwill":1o90fdzt said:redleader":1o90fdzt said:How do these software radios actually work electrically? Are they reprogrammable tuners/mixers or are they literally just parking an oscillator at some frequency and running a really fast A/D to capture everything moving through the air over a very wide band?
As the name would imply the components of the transmitter or receiver would be implemented in software. Not a very useful statement, I know. In general, SDR makes the whole system more flexible. Instead of "hardcoding" the functionality into an IC it's done in C/C++ or VHDL. Some or all of the following blocks can be implemented: filtering, modulation, demodulation, detection, channel equalization, and amplification. The A/D is usually configurable too.
In terms of a dipole, that's mostly correct but a more complex wide-band antenna could be used.redleader":1o90fdzt said:Can they simultaneously read in 1 GHz and 2 GHz transmission for instance?
True, but using 'smart antennas' certainly will push up the price. After all, smart electronically adaptive antennas are not really mass-produced items.redleader":lvjbsut1 said:pepoluan":lvjbsut1 said:Not so stupid a question actually. I also wondered about that.redleader":lvjbsut1 said:So stupid question:
Well my thinking was that if you have a fast enough A/D and D/A you don't actually need a modulator/demodulator. But apparently we're not quite there yet.
pepoluan":lvjbsut1 said:Plus, the antennas must be at least as long as 1/4 lambda and (IIRC) not multiples of 1/2 lambda. This practically limits the usable wavelengths used, introducing "blind spots" here and there.
Those rules of thumb are for simple dipole antenna. They're probably using something a bit smarter then that. But yes, you have to swap the antenna if you want to go from 100MHz to 4GHz.
Wollesen told us that rather than transmitting data in a narrow range of frequencies at high power, a software-defined radio device can transmit data across an extremely wide range of frequencies at low power—so low that it's imperceptible to the conventional radio devices that are operating on the same frequencies
Phyllis Stein":iw49yeyn said:The worldwide changeover from analog to digital radio in the "consumer" frequencies is already underway.
The days of FM and AM on your radio dial are already numbered.
The terms "VHF", "Medium Wave", "Long Wave" and "Short Wave" are about to be confined to history.
The project is called "Digital Radio Mondiale".
Website : http://www.drm.org
Overview:
http://www.drm.org/uploads/files/DRM_Th ... inal_1.pdf
Technical specs:
http://www.drm.org/uploads/files/broadcast_manual.pdf
Timothy B. Lee is using Market Capitalization as a measurement. The Wikipedia list you linked to can be sorted by Market Capitalization.Puzzlebox42":wd9ax1d0 said:Apple is not the worlds largest company. It's not even the worlds largest tech company, 43rd to Samsung's 24th by 2011 revenue. Try and contain you ridiculously obvious Apple bias just a tinsy bit in future. Oh and research and fact checking are also staples of good journalism... so I hear.
http://en.wikipedia.org/wiki/List_of_co ... by_revenue
Walshicus":28fqanzi said:So here's what I got from this article:
"Apple... apple. Apple apple: Apple! Apple? A-p-p-l-e. (Phi)."
Sorry, it's a fascinating subject ruined by hugely out of place fanboyism.
