Forgotten audio formats: Wire recording
masterofninja
Brilliant article! This is what I love about Ars. I was interested to hear about the "The Live Wire" album, and the restoration process. I'm going to have to have a Google (other search engines available) day to read about how they did it, as it seems that whoever's restored it is due more than a Grammy. Even the Wikipedia page only gives a passing mention to it, whereas it seems a more "exotic" method of extraction was used which must be good for digital archaeology. This must be great to try and get better sound out of old recordings - I particularly like the story of the 19th century recordings of Otto von Bismarck singing the Marseillaise.
fragile
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32351491#p32351491:1d4cfzd3 said:
bongbong[/url]":1d4cfzd3]is it really accurate to call wire recording or tape or vinyl, an audio format?
Im not trying to sound smart alecky or be a nitpicker.
but is this the proper form so i can use it without error since the audio formats i know are flac, wav ,mp3 etc which I KNOW are file fomats.
wont audio device be a better term?
BTW their recovery methods are brilliant and awe inspiring
I think it is accurate.
Coming from an era where everything was analogue, be it reel-to-reel tape, cassette tape, records etc, then this is definitely a format.
You are really thinking about file format - which simply does not apply in this instance as far as I can tell.
Jim Salter
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32351491#p32351491:3m3ugcn2 said:
bongbong[/url]":3m3ugcn2]is it really accurate to call wire recording or tape or vinyl, an audio format?
If you absolutely must nitpick this, the term you're looking for is "media" - or, in the singular, medium.
AFP
Re: the video clip showing a wire recorder in "The Two Jakes". Watch a few seconds past the wire recorder, and you also get a nice glimpse at another recording medium of days-past, instant cameras (although, given that there's a lot of overlap between photographers and people who love anachronistic things, you can still buy instant cameras and the stuff to feed them).
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32351501#p32351501:25gwpc2q said:
charltjr[/url]":25gwpc2q]Love this sort of "lost tech" piece, more please.......
Techmoan did a really interesting video on a wire recorder (well, I thought it was interesting :) )
https://youtu.be/90ihiTwJPCc
And in a couple more months, Ars will cover music for oscilloscopes.
cbreak
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32351491#p32351491:26pc9tyw said:
bongbong[/url]":26pc9tyw]is it really accurate to call wire recording or tape or vinyl, an audio format?
The article doesn't actually describe the format, unfortunately, but there certainly is a way in which the data is encoded.
Jim Salter
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32351551#p32351551:3pjvfv7y said:
fragile[/url]":3pjvfv7y]Coming from an era where everything was analogue, be it reel-to-reel tape, cassette tape, records etc, then this is definitely a format.
Digging back in memory, I think what audio engineers used to call "format" in the analog days wasn't ever really a tightly-defined term. It generally encompassed physical medium, encoding, and modulation in one all-encompassing if somewhat vague term - because you never really had much call to separate the layers back then; they all went together.
For that matter, the "encoding" was usually "none whatsoever" when it came right down to it. Wire or tape are both direct modulation of a magnetic medium with no encoding. Phonograph is direct modulation of a physical medium with no encoding.
Jim Salter
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352215#p32352215:14hmupog said:
cbreak[/url]":14hmupog]The article doesn't actually describe the format, unfortunately, but there certainly is a way in which the data is encoded.
No, there isn't. It's direct amplitude modulation. There's no encoding whatsoever.
An example of encoding would be the old "eight, none, and one" of telephone modem days - referring to eight signal bits, no parity bit, one stop bit. There's absolutely none of that in wire, tape, phonograph, or AM radio - you literally just translate the amplitude modulation of the medium directly into movement of a speaker driver, and presto, you get sound.
It's arguable whether you could constitute FM radio as "encoded" or not - the amplitude modulation of the recorded sound is translated into frequency modulation of a carrier signal, but there's still no encoding to interpret around it, it's just the direct waveform of the original sound on an underlying medium.
cbreak
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352229#p32352229:35axktf4 said:
Jim Salter[/url]":35axktf4]
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352215#p32352215:35axktf4 said:
cbreak[/url]":35axktf4]The article doesn't actually describe the format, unfortunately, but there certainly is a way in which the data is encoded.
Amplitude modulation IS an encoding. Not every encoding is digital.
Hat Monster
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32351491#p32351491:3385tf50 said:
bongbong[/url]":3385tf50]is it really accurate to call wire recording or tape or vinyl, an audio format?
Yes, it is accurate!
The "formats" you list aren't formats at all. They're all ways to store linear PCM data. FLAC is a lossless way to store linear PCM. MP3 is a lossy way to store linear PCM. WAV is just straight up linear PCM inside a RIFF container (which is a derivation of the CBM/EA IFF container format).
The actual audio format in all cases is linear PCM.
Fixpir
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32352223#p32352223:3r1bzikb said:
Jim Salter[/url]":3r1bzikb]
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32351551#p32351551:3r1bzikb said:
fragile[/url]":3r1bzikb]Coming from an era where everything was analogue, be it reel-to-reel tape, cassette tape, records etc, then this is definitely a format.
Direct modulation with a bias, as stated in the article. Or else, the hysteresis curve of the magnetic material introduces an awful distortion.
My understanding is that they did not find any remnant of HF (understand in the context "over 20kHz!") bias, on the wire, because the wire recording used DC bias. Great explanation here.
Compact cassettes and tape recorders used AC bias.
Without bias
With DC bias :
With AC bias :
Jim Salter
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352237#p32352237:3hfinrv0 said:
cbreak[/url]":3hfinrv0]Amplitude modulation IS an encoding. Not every encoding is digital.
No, it really isn't - amplitude modulation is exactly what it says on the tin - modulation. The only way to label what goes on in wire, phonograph, or standard two-channel cassette "encoding" is if you want to get super pedantic and call it "direct" encoding - the equivalent of multiplying a number by one.
Encoding is something above and beyond the original data, which needs to be interpreted or decoded rather than being just blindly played back as part of the main data stream. And no, that doesn't need to be digital - an analog example is the old Dolby Pro Logic encoding that hid an extra couple of channels inside a two-channel recording medium.
Edit: I forgot about recording bias to tape, as pointed out above. Bias would qualify as extremely simple encoding.
Hat Monster
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32352237#p32352237:29gtuevb said:
cbreak[/url]":29gtuevb]
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352229#p32352229:29gtuevb said:
Jim Salter[/url]":29gtuevb]
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352215#p32352215:29gtuevb said:
cbreak[/url]":29gtuevb]The article doesn't actually describe the format, unfortunately, but there certainly is a way in which the data is encoded.
AM isn't an encoding, it's a modulation. You can have both, but you must have the modulation (modulation is how a different medium is changed to accept the signal: If you do no more than that, you haven't encoded anything). An encoding, as the name suggests, translates the signal into another form where it's a symbolic representation of the original. FM and AM are both not encodings, they're direct transfers into another medium. The offset of the signal controls the power of the AM signal, or the offset of the FM signal, directly.
A very simple encoding would be something like PWM, where the length of the pulse represents the power of the signal. You'd think that's a digital form, but it's still analog: The length of the pulses is your analog component. This can be demodulated by nothing more complex than a speaker cone's inertia, so represents a form of encoding and modulation where the act of demodulation is also the act of decoding.
Another common, and simple, encoding is the digitisation and capture of the signal into a digital form, such as LPCM. LPCM is just a long list of numbers, so it's a valid encoding. Being a storage, rather than transmission, format, it has no modulation.
A more complex encoding is a QAM constellation, where each state of the modulation can be one of 4, 16, 64, 256 or even more states, encoding bits into each individual state (it's similar to a look-up table, and uses one).
redtomato
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32352237#p32352237:1aebafrc said:
cbreak[/url]":1aebafrc]
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352229#p32352229:1aebafrc said:
Jim Salter[/url]":1aebafrc]
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352215#p32352215:1aebafrc said:
cbreak[/url]":1aebafrc]The article doesn't actually describe the format, unfortunately, but there certainly is a way in which the data is encoded.
From my perspective, written English is an encoding of spoken English, in that there is little direct relationship between the spoken sounds and the written graphemes. More properly, written English is a notation system, one that is full of irregularities, exemptions, and special cases.
This isn't always the case in other languages, some of which have been reformed so that most words (but still not usually every single word) can be spoken as they are written.
On a more philosophical level, all languages can be regarded as domain specific encodings of the speaker's thoughts, that require years of training to decode.
Carewolf
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32352229#p32352229:6xo1rl8n said:
Jim Salter[/url]":6xo1rl8n]
[url=https://arstechnica.co.uk/civis/viewtopic.php?p=32352215#p32352215:6xo1rl8n said:
cbreak[/url]":6xo1rl8n]The article doesn't actually describe the format, unfortunately, but there certainly is a way in which the data is encoded.
Well directly storing as a magnetic signal is an encoding. Plus there is the speed, which is an important part of analogue formats like this, and mentioned in the article, in fact as a form of encoded messages
Jozsi
I had no idea that wire recorders had such a long and complex history. In the early sixties a friend of mine a few years older than me had acquired one of these machines and I've never forgotten how bad it sounded. It was simply dreadful with a great deal of distortion and noise, completely unsuitable for almost anything but perhaps adequate for dictation which I imagine was its original purpose. I don't recall the recording wire itself being terribly fine but like I said, it's been a while. ;)
Rookie_MIB
Ah - now this explains something I read about a while back. I was reading a book and there was a reference to a 'wire recording', and I just assumed that it was a 'tape recorder wired in'. I never knew that this was how they used to do older recordings...
And of course it makes sense, and you learn something new every day.
Coriolanus
[url=http://meincmagazine.com/civis/viewtopic.php?p=32364449#p32364449:qlkab2gb said:
Danathar[/url]":qlkab2gb]I wonder, was there ever an attempt to do digital recording onto a wire? Something incredibly long lasting might be useful somehow.
I'd imagine the bitrate would be pathetically low by today's standards, but with enough wire you could record something digitally and archive it for a VERY long time.
I always thought the benefit of analog is that it degrades relatively gracefully. If you had an antenna and you were trying to pull in a TV station from far away that is analog, then you might get a lot of static and snow, but you'll still get a recognizable picture and sound.
But if you have a digital signal, if it degrades beyond a certain point, you've got nothing. So, maybe storing digital recordings onto wire might be okay initially, but as it degrades, it'll just turn into junk.
[url=http://meincmagazine.com/civis/viewtopic.php?p=32352195#p32352195:1y4y944x said:
Wardatrigger[/url]":1y4y944x]
[url=http://arstechnica.co.uk/civis/viewtopic.php?p=32351501#p32351501:1y4y944x said:
charltjr[/url]":1y4y944x]Love this sort of "lost tech" piece, more please.......
Which is currently going nuts on youtube - search for Jerobeam Fenderson.
I'm listening to one of the Guthrie songs in the background, and it's giving me chills hearing a 60 year old recording that sounds that good. Does anyone have a link to the uncorrected audio?
flashback_rtk
a home-recording medium that people could, and did, use to record their own voices, as well as their own music and songs off the radio—thus giving the world its first example of illegal home recording.
Was there any law preventing it at the time? You make it sound as if it was the first observation of a natural phenomenon in a laboratory.
The less complicated tape decks were also getting cheaper and soon became the recorder of choice for universities, schools, independent studios, and, eventually, home recordists who fancied stealing sounds from the radio.
And that's why I ask, insisting on it makes me think you're just trying to educate your readers on your opinion on recording songs from the radio.
It was a very interesting article by the way.
[url=http://meincmagazine.com/civis/viewtopic.php?p=32351887#p32351887:14rmyxi3 said:
jerminator[/url]":14rmyxi3]Very interesting read on a technology that I've seen in old movies, and didn't think it was quite this ubiquitous. Good stuff. I liked the Guthrie guitar sticker "This machine kills fascists." We'll be seeing more of that sentiment soon again looking at where we're all headed.
The Guthries are a national treasure.
[url=http://meincmagazine.com/civis/viewtopic.php?p=32364733#p32364733:i72cw7qu said:
Umbaglo[/url]":i72cw7qu]Is this format what was being referred to by all my old tape players that had a switch for various tape formats that included "Metal" as one of them? I don't remember ever seeing any alternate tape format at the time, but I remember thinking "Metal" was certainly a strange one specifically.
No, metal is Chromium Oxide tapes, nothing to do with wire recording. A wire recording looks like a big spool of shiny thread, and is not in a cassette.
