I mean I get it, but every additional batch of satellites that has to be launched and positioned increases the odds of a collision with something already up there, maybe in an orbit where it wasn't intended to be. (All this also increases the odds of one of these players failing to manage or notice a slowly degrading orbit for one of their many thousands of satellites.) Basically just a numbers / odds game. So while the kessler comments aren't too original at this point, ironically, the longer we go the more relevant they become in this scenario.500,000 satellite in orbit in ten years? Incoming Kessler syndrome commentary in 3, 2, 1...
Citation sorely needed. Isn't rather the opposite true? The only organizations I can think of that are both successful and diversified are the massive governmental space agencies, e.g. NASA, ESA and JAXA.“Every single successful space company is diversified in its products.”
The CEO says:
The private, for-profit companies that are also successful are definitely not diversified, but rather focused on narrow avenues. Even the most notorious one, SpaceX, is focused on lifting objects to orbit, with Starlink building communication satellites, for some extra flavoring. Both SpaceX and Starlink are doing achieving something difficult and deserve the praise. But they're not diversified, and they're the most prominent (loudest) in the field.
You might argue about Northrop Grumman, which built the JWST and does some other launch-related work, but... are they successful from their space work? Rather, I think they're profiting a lot from the US military. Yes, they have successful space-focused projects, but they're not a space company.
I think "diversification" is somewhat in opposition with "space company", because space is hard, and you can't usually afford diversity. Unless you're a defense-funded giant, I guess.
SpaceX doing launch and running an ISP shows that they are diversified (they adding social media and xAI shows that they are way more diversified now)Both SpaceX and Starlink are doing achieving something difficult and deserve the praise. But they're not diversified
Mash 'em together - satellite surgeon!I’m gonna be a fighter pilot when I grow up. Or a veterinarian.
Historically, in the United States, a handful of large companies such as Boeing, Lockheed Martin, Northrop Grumman, Maxar, and Sierra Space have manufactured medium and large satellites. Typically these were costly and often bespoke designs that cost tens to often hundreds of millions of dollars.
Pretty sure that all of the companies listed sell sat buses. Similar products to what Vast is now trying to sell
For example Lockheed Martin has the LM series. Their option for 15kW is heavier, but allows for a heavier payload.
https://www.lockheedmartin.com/cont.../LM400-LM2100_LM50_Product_Card_Final_Web.pdf
I don't know, space is really big. If I said, we will build 500,000 buildings on the surface of the earth, you wouldn't think that would require them to be particularly close. Now add layers of altitude.500,000 satellite in orbit in ten years? Incoming Kessler syndrome commentary in 3, 2, 1...
Your 500k buildings aren't moving relative to each other.I don't know, space is really big. If I said, we will build 500,000 buildings on the surface of the earth, you wouldn't think that would require them to be particularly close. Now add layers of altitude.
On the other hand, dependency on a vast array of satellites (and see adjacent article about threats to undersea cables which may get replaced by even more satellites) could result in a disaster if there was an extreme solar storm, a bad actor setting off a nuke in orbit, etc. So I don't think Kessler syndrome is the only thing to worry about.
Space is big....but Earth orbit is getting very crowded with junk from launches, and abandoned satellites, and so on. And intentionally filling it up with intentionally-shortlived orbital satellite platforms, as well as their own launch-junk, for nothing but digital beanie babies is beyond shortsighted.I don't know, space is really big. If I said, we will build 500,000 buildings on the surface of the earth, you wouldn't think that would require them to be particularly close. Now add layers of altitude.
It's not a coincidence that everybody is talking about building space rollercoasters and space hot dog stands as SpaceX is getting ready to IPO.
According to TFA, they will be in a variety of orbits ranging from LEO to cislunar.Can someone explain the orientation of these please? Will they be geostationary around the planet? I know the surface area is not that large compared to the Earth, but they would shade the planet a tiny amount, wouldn't they?
You ever play SimCity2000 and place a Microwave power station, with disasters enabled?Yeah once AI finally crashes (nobody has made money on it except the chipmakers) all these super duper everything in the sky plans will likely go away.
I mean if power in space is cheap and easy why not generate power in space and beam it down to Earth. Hell you could beam it right to those power hungry terrestrial datacenters.
There are over 10 million RVs in just the US.Your 500k buildings aren't moving relative to each other.
The sats are moving and crossing each others paths.
What orbital data center inferencing needs?Haot added that Vast also plans to offer an Nvidia Space-1 Vera Rubin Module to support orbital data center inferencing needs.
15kW is in Starlink V2 range. So this bus is good for more things than just datacenters.Yeah, well, what else? Can't blame them for jumping on that wagon. But if the orbital data centre thing doesn't pan out for whatever reason, gonna be a LOT of casualties.
