NuScale will get the final approval nearly six years after starting the process.
Read the whole story
As you go smaller in plant size, the safety, shielding, and regulatory burden becomes a larger percentage of the plant cost, not to mention overall balance of plant. If instead you're just using a bunch of these to replace a single larger core in the same size plant, now you've just multiplied all of your failure points.
What makes you think these will lower energy bills?If we can get smaller modular reactors out in use, and peoples energy bills lower, perhaps public perception of nuclear can change and we can expand more and more.
I don't know about the nuscale - but some newer reactor designs are showing LCOE numbers that are competitive to fossil or renewable plus storage
https://en.wikipedia.org/wiki/Stable_salt_reactor
Economics
The capital cost of the stable salt reactor was estimated at $1,950/kW by an independent UK nuclear engineering firm.[4] For comparison, the capital cost of a modern pulverised coal power station in the United States is $3,250/kW and the cost of large-scale nuclear is $5,500/kW.[5] Further reductions to this overnight cost are expected for modular factory-based construction.
This low capital cost results in a levelised cost of electricity (LCOE) of $44.64/MWh with substantial potential for further reductions, because of the greater simplicity and intrinsic safety of the SSR.
Personally, I'm rooting for TAE technology's fusion play. H + Boron is coolness.
I think storage is something a lot of people forget to consider. If you want 100% renewable then you have to have enough storage to cover the load when there's no sun AND no wind for hours, or days at a time. So even if this was 3-4 times as expensive as Wind or Solar it would provide consistent output regardless what the weather was doing, so it might be on par or cheaper than Wind or Solar once you include a reasonable amount of storage (say 24 hours minimum).
Green energy accounts for a small enough percentage of the total energy grid right now that storage isn't really needed. We have base load being provided by Hydro, coal, gas. So fluctuations in weather are annoying but not devastating. When there's zero base load power being generated and the power from wind and solar can randomly drop to zero then that's a big problem.
Literally *NO ONE* actually doing renewable work is 'forgetting to consider storage.' There are two issues, both of which already have solutions that work just fine, and both help with baseload management. You have short-term localized weather issues, which even a modicum of storage can handle just fine by smoothing over the production dips. And then you have longer, regional weather issues, which HVDC interconnects handle just fine, by allowing the mass transmission of power from separate and unaffected weather regions.
You'll notice, there are no further 'issues' with renewables beyond those two. The scapegoats that anti-renewable complainers keep trotting out are tired, idiotic arguments that were barely relevant in the first place and are the hallmark of someone completely clueless of the industry now. Solar and wind are both fully capable of supporting all of humanity's power needs. What's *lacking* is the production of the hardware on a scale large enough to meet our insatiable power appetites.
HVDC is doing a lot of work in this scenario- I mean I’m not necessarily against it but it’s going to take a lot of work to get the cross region HVDC capacity to deal with seasonal fluctuations with 90+% renewable grids and we’ve barely started. In some cases the capital buildout required might make nuclear cheaper in some places
Yes, but we don't know how much power is being used to turn the screws. That 50-200 MWe output is only the electrical output, so we don't know what the total output is. I suppose we could compare the thermal output of a NuScale and a navy reactor, but then you have problems of the turbine's efficiency. Which could be significantly different.It's not like electrical generators are particularly inefficient. A turbine is going to be capable of the same output whether it's driving a screw or a generator.If that a fair comparison? I thought carriers used some of the mechanical power directly, so they get more benefit than the electric power output implies.I think naval reactors are around 50 MWe to 200 MWeI am curious how this compares in size to the nuclear reactors onboard carriers and subs. Also, this would be even better if we had good solutions for used fuel disposal.
I picked a fine week toquit sniffing glueread "Midnight In Chernobyl" by Adam Higginbotham.
With the first of these scheduled to go online in, maybe, 8 years, we could see this "at scale" in 10-15-20 years?Would have been even better 20 years ago. But then again, so would EVERY non-fossil fuel-based power source being rolled out at scale. We're just so late on everything, and most of the blame lies with politicians allergic to governing and rich, subsidized industry allergic to changing.
Also, you say the blame lies with govt and industry, but neglect to mention the reason the article mentions about why even this first proposed reactor might not get built: money.
On your last, unlikely. Succeed maybe. But Gates and I think Berkshire are backing NuScales first power plant. Not sure if they are planning a single SMR or if they are planning several at the site (I think several). I am pretty confident now that nuscale has the approval the project will succeed in so far as the first reactors will get built and installed. Whether multiple power plants and many reactors happen or not remains to be seen.
Initial estimates have it within a few percentage points of natural gas in price per megawatt, both from the manufacturer and the operator of the first project these are supposed to go into.100% Dead On Arrival. I do not expect to see a single one of these delivered at a cost-competitive basis to combined cycle natural gas or renewables.
It actually is possible for LWR's to load follow within limits, they just can't afford to because their economics rely on 24/7 operation to pay off their loans and/or upgrades where they've been fully paid off but are older designs. I think that's likely to apply to just about any form of nuclear, whether LWR SMR's or molten salt or anything else.That's only true when you are talking about legacy nuclear. LWR cannot load follow (salt can), traditional custom LWR has very high capital costs (SMR's do not). You didn't throw in safety issues but go ahead and include them - they have big safety issues.
Economics
You are mostly right though I’d like to point out that it’s not so much base load that we need to complement renewables, as much as it is flexible load. Traditional base load is slow to start and stop, has high capital costs and low operating costs. This doesn’t complement renewables well which also have high capital costs versus fixed costs, and need plants to pick up rapidly for them.
Unfortunately this means renewables and nuclear don’t complement each other very well.
If you want to argue that old style, expensive LWR's are not competitive to *anything* you're probably right. But those arguments are really only valid against the older generations. The newer reactors designs, especially the newer salt designs, (assuming they get approved) don't have those shortcomings.
People used to argue that PEV's would never work because they were expensive, the technology was not developed, batteries were heavy and would never last. And all of that is true of the older generations of electric vehicles at that time. Glad there were people that were able to read newer publications as they developed and updated their thinking. Technology evolves, don't get stuck in the 70's.
HVDC does indeed do a lot of work. And not just the 'transmission' role. It also makes the grid easier to manage and much, MUCH more robust. Studies have already been done on this issue and its largely a settled topic (outside of fossil-fuel lobbying circles). HVDC interconnects are worth far more than they cost at nearly any kind of scale relevant to the issue of renewable intermittency. Nothing you could spend those dollars on will do more for the grid and delivering electricity to businesses and homes. But it has same problem as solar and wind -- actual hardware production is woefully short of the power industry's demand. Lots of very, very long waiting lines.
Also, while gas may be a bargain in the U.S. at present, they're doing all they can to build terminals and tankers so they can sell more LNG to Europe. If you don't think that will make gas more expensive here, then you don't understand the law of supply and demand.Also, look at cost of electricity in natural gas dependent Europe right now. It may be cheap for us in the US right now, but we are fortunate to be in a position where an asshole running a third world country can't affect our energy production as much as elsewhere in the world. A lot of people across the world would be quite happy with this type of energy production even at slightly higher prices.Initial estimates have it within a few percentage points of natural gas in price per megawatt, both from the manufacturer and the operator of the first project these are supposed to go into.100% Dead On Arrival. I do not expect to see a single one of these delivered at a cost-competitive basis to combined cycle natural gas or renewables.
Personally, I think this type of design has a far better chance of being on budget than traditional nuclear construction.
You can't always assume that there will _be_ natural gas infrastructure or even cost effective renewables where these things can be deployed. There have been many discussions about using small scale reactors in Alaska where in most of the state we do not have natural gas available nor are most renewables a cost effective fit. Instead, we have a bunch of coal or naptha/diesel fired generators. There are firm plans to place a small scale reactor up here at Eielson AFB instead of their coal fired plant for meeting the needs of the base.
Many of the interior Alaska villages also have to bring all the fuel for their generators they need for the whole year up by barge in the early spring and that makes their electricity really, really expensive. Something like a small scale reactor might be great for a consortium of two or three communities and the amount of power it would put out would be just about right.
Just out of curiosity, what's the efficiency of a modern HVDC converter? It used to be pretty low, but a quick search turned up numbers above 90%, which seems pretty high.
Natural gas is by far the cheapest generation source by capital costs, which means most of the overall cost is fuel. That's why it gets along so well with renewable intermittency, it's the only kind of generation capacity anyone can afford to idle. On the other hand when natural gas is expensive it can be ruinously expensive, which can happen due to external events like war, or natural disasters like the Texas storm last year. Depending on your point of view you might not care about that, because a power plant operator can easily shut down when natural gas is too expensive for them to run profitable. But as we learned in Texas that can run into problems when the natural gas infrastructure needs electricity to keep the gas flowing. Seems to me from a societal perspective there's a lot of value in a generation source that's not subject to extremes of this kind, it's just a question of whether we can create the right signals that it's worth it for utilities to plan accordingly.Initial estimates have it within a few percentage points of natural gas in price per megawatt, both from the manufacturer and the operator of the first project these are supposed to go into.100% Dead On Arrival. I do not expect to see a single one of these delivered at a cost-competitive basis to combined cycle natural gas or renewables.
This is outrageously wrong. NuScale's own cost estimate for an "nth-of-a-kind" reactor (i.e. after costs have come down due to scale effects) is 3,600 $/kW. This is about three times the current capital cost of a natural gas plant, which the US Energy Information Administrates puts at 1000-1200 $/kW.
Sources:
https://www.nuscalepower.com/newsletter ... ompetitive
https://www.eia.gov/outlooks/aeo/assump ... le_8.2.pdf
Economics
Eliminating regulatory agencies might be the only way to save the planet.
People say this a lot, but if you look at the fuel cycle it is not so great.Still think a thorium salt reactor makes way more sense.
By definition there is never a day that doesn't have sun. For PV solar you only need to store power overnight; most of which will be used in the first four hours of darkness.
I do this as an off-grid home owner, so I do have to have enough panels to produce sufficient energy during cloudy days in the height of winter.
Once you scale up to the continental level there is never a time when there are clouds over all panels. The challenge then is the underlying grid, and the politics around sharing power across a continent.
[...] a few percentage points of natural gas in price per megawatt [...]100% Dead On Arrival. I do not expect to see a single one of these delivered at a cost-competitive basis to combined cycle natural gas or renewables.
I wish someone would work as hard on making photo- or wind- generated water electrolysis happen, and a safe way to store the hydrogen without it all leaking out. Imagine being able to use wind or solar panels to power your house in the day while also electrolysing leftover water. Then when it's dark or still, you flip a switch, which burns the electrolyzed hydrogen for fuel and produces nothing but pure water as waste =\.
Good first step. Now repeat the process with thorium as the reactive material.
...until you realize that's a standard 1m tall safety railing along the top.These look like cute little cylinders....
I think what you are looking for is a hydrogen fuel cell. That already exists, but I'm not sure how it compares to batteries at this point.
Since the Union of Concerned Scientists is, by policy, against just about everything nuclear, I can't consider that tweet to be unbiased or reliable.
60-70% each way, so <<50% round trip, compared to most decent battery chemistries at >85%.I think storage is something a lot of people forget to consider. If you want 100% renewable then you have to have enough storage to cover the load when there's no sun AND no wind for hours, or days at a time. So even if this was 3-4 times as expensive as Wind or Solar it would provide consistent output regardless what the weather was doing, so it might be on par or cheaper than Wind or Solar once you include a reasonable amount of storage (say 24 hours minimum).
Like many modern breakthroughs I've heard about, it seems there's potential when using graphene. Too bad it's apparently about as cheap as unobtanium to get...I wish someone would work as hard on making photo- or wind- generated water electrolysis happen, and a safe way to store the hydrogen without it all leaking out. Imagine being able to use wind or solar panels to power your house in the day while also electrolysing leftover water. Then when it's dark or still, you flip a switch, which burns the electrolyzed hydrogen for fuel and produces nothing but pure water as waste =\.
Also, a *LOT* of people have been working on those problems, for quite a few years. One of my undergrad lecturers back 20 odd years ago (oh god, that hurts to say) was working on metal hydrides as a storage tech for instance, and that wasn't something he'd just started on. The reason that there's still no good storage solutions for hydrogen is that it's a very hard problem, and there may simply not be any good solutions.
The Oil and Green lobbies shrieked a shriek of rage and pain today... good to see the nuclear power revolution underway. I feel the solar and wind deals are too muddied and contaminated by politics at this point...
not "bad", but it benefited from subsidies, dereg, and policies that nuclear should have been benefiting from when people realized our policy is *literally* the main reason form most of the negatives... that and "radiation scary".
Either we are interested in finding a solution to fossils or not. The anti nuke group needs to make up their minds.
Plus, these won't care if the wind is blowing, night time, or rely on nonexistant battery tech which many places do care about... these are HERE, let's use them at least (until fusion in 20 years).
structured in a way to allow passive safety, where no operator actions are necessary to shut the reactor down if problems occur.
If not mentioned before, this sure looks like a problem in of itself.
Um... You know, normally I'd agree, but in this case, the reason why we went with the current design is because of the Arms Race. Non-modular and custom designs were required because of the locations and using the local means of cooling the plants (plus water table issues, and stuff in case of a meltdown).Would have been even better 20 years ago. But then again, so would EVERY non-fossil fuel-based power source being rolled out at scale. We're just so late on everything, and most of the blame lies with politicians allergic to governing and rich, subsidized industry allergic to changing.
One of the reasons why Chernobyl exploded was that the control rods wouldn't go back into the pile as the reaction began to run away. The sleeves for them had been compromised by the heat, so they couldn't even be forced back into the pile to dampen the reaction. Had they gone back in, the odds favor that the reactor wouldn't have exploded.Its operator-free safety features include setting the entire reactor in a large pool of water, control rods that are inserted into the reactor by gravity in the case of a power cut, and convection-driven cooling from an external water source.
That's not true. The fuel cycles used in power reactors are useless for weapons grade materials. The reason for this is that while they do generate Plutonium 239, they also run on long fueling cycles which makes a fraction of the Plutonium absorb another neutron to become Plutonium 240 which has a high spontaneous neutron rate and therefore causes a bomb to "fizzle" rather than do an efficient nuclear detonation. Weapons reactors have fuel channels that allow them to constantly rotate fuel through the core to avoid this. Some civilian designs have the theoretical possibility of being abused for weapons breeders, like CANDU, but anything where the core is bolted closed and run for 18+ months on the same fuel load will produce unacceptably high Pu-240. The two isotopes are extremely difficult to separate from each other, much more difficult than U235 and U238, so if you have the centrifuges etc to do it, you'll just skip the reactor and make a Uranium bomb.The spend fuel could be refined to make weapons-grade plutonium, which the other radioactive salt reactors didn't provide.
So it was more of a military/national security decision than it was an economic one.
That's incorrect. The rods stuck part way in because heating warped the tracks. The real problem was that the control rods had a carbon layer at their lower end, which was supposed to make them slide in more smoothly. But that meant that, until they were all the way in, the carbon was acting as a moderator and increasing the reactor's reaction rate. Which, actually, was known from a previous and less serious incident. But not communicated because a very senior official had been one of the inventors of that reactor design, one of its long-standing proponents, and in the Soviet Union, you didn't distribute information which said a very senior official was wrong.I do have a question about this, though:
In most designs, the control rods are neutron absorbers. You lower them into the reactor, they absorb neutrons, and the reaction slows. In RBMKs, the control rods were dual purpose and promoted reactivity. Water in the cooling channels itself absorbed neutrons, and the control rods had a section of carbon that displaced the water. At Chernobyl, the act of re-inserting the control rods significantly accelerated the reaction.One of the reasons why Chernobyl exploded was that the control rods wouldn't go back into the pile as the reaction began to run away. The sleeves for them had been compromised by the heat, so they couldn't even be forced back into the pile to dampen the reaction. Had they gone back in, the odds favor that the reactor wouldn't have exploded.Its operator-free safety features include setting the entire reactor in a large pool of water, control rods that are inserted into the reactor by gravity in the case of a power cut, and convection-driven cooling from an external water source.
You're speaking of the reactors of today.That's not true. The fuel cycles used in power reactors are useless for weapons grade materials. The reason for this is that while they do generate Plutonium 239, they also run on long fueling cycles which makes a fraction of the Plutonium absorb another neutron to become Plutonium 240 which has a high spontaneous neutron rate and therefore causes a bomb to "fizzle" rather than do an efficient nuclear detonation. Weapons reactors have fuel channels that allow them to constantly rotate fuel through the core to avoid this. Some civilian designs have the theoretical possibility of being abused for weapons breeders, like CANDU, but anything where the core is bolted closed and run for 18+ months on the same fuel load will produce unacceptably high Pu-240. The two isotopes are extremely difficult to separate from each other, much more difficult than U235 and U238, so if you have the centrifuges etc to do it, you'll just skip the reactor and make a Uranium bomb.The spend fuel could be refined to make weapons-grade plutonium, which the other radioactive salt reactors didn't provide.
