You must have missed the part of ever cheaper and the current trajectory of implementation. It’s getting done. All of the battery installs in my part of country went onto already utility owned land that wasn’t being used for anything. Regardless, installations aren’t that big and the issue of physical space is not a concern. Sourcing materials? The number of global manufacturers and the growing battery output from them tells me sourcing materials is not an issue.Storage is storage, but when you need 1000x the current capacity you start running into limits about cost, physical space and sourcing materials. If you can find something that's 10-100x cheaper then the numbers stack up somewhat better.
During the last dunkelflaute, Germany had to import around 1 TWh. This led to a price spike on the electricity market and some unpleasant comments from politicians from Sweden and Norway (where electricity is imported from and where prices also rose).about the dreaded battery storage issue. Look, California is getting it done
So can you build a battery to store 10TWh economically? That's the UK requirements for a two week dunkelflaute on current demand (most heating being from natural gas).You must have missed the part of ever cheaper and the current trajectory of implementation. It’s getting done. All of the battery installs in my part of country went onto already utility owned land that wasn’t being used for anything. Regardless, installations aren’t that big and the issue of physical space is not a concern. Sourcing materials? The number of global manufacturers and the growing battery output from them tells me sourcing materials is not an issue.
You're also competing with food stock for land, fertilizer, and water if you want to do it economically. I mean the US can probably do it by continuing to produce ethanol from corn after we transition to EVs for transportation, not sure if our annual production is sufficient to power Europe's backup needs?Sure. It's a minor change to move natural gas plants that mostly burn methane to hydrogen.
But it's a lot cheaper to transport and store liquid hydrocarbons than hydrogen. And if you're using the sun to provide most of the energy for your biofuel, you're investing a lot less grid power in your feed stock.
It’s shining and blustery as hell someplace else. Also the tide and waves are always going and geothermal vents don’t take days off. That’s why you put a whole bunch of things in a network and then some of them are always making plenty of power right?When the Sun doesn't shine and the wind is calm
On an article focused on cost ... saying the most expensive option by orders of magnitude is "the solution" is clown-level hilarious.Nuclear is and has been the answer to most of our energy problems for decades. There's too much pearl clutching about nuclear fuel in the US that makes us generate and hang onto gobs of nuclear waste. Build fast breeder reactors and tell the public to get bent. The cats out of the bag plutonium is everywhere. If india and Russia can run them without them going boom the US can as well.
The article also doesn't mention the potential for V2G charging from EV batteries, which for a large portion of the population spend most of their time at home or parked at work. If we could financially incentivize the use of, say, 20-30% of pack capacity in those vehicles, it could be used in several different ways. Even this amount of vehicular capacity would be equivalent to 1-2 Powerwalls each and Tesla has demonstrated great results with their virtual power plant solutions in several states.As battery costs become cheaper and cheaper, there’s absolutely no reason to not install a surplus 3x, 5x or more of actual on-paper needed capacity. Any situation should be readily covered.
The problem here is political rather than technical - but nonetheless very real. The "someplace else" might be unwilling to sell you the energy when you need it - or hike the prices, or whatever.It’s shining and blustery as hell someplace else. Also the tide and waves are always going and geothermal vents don’t take days off. That’s why you put a whole bunch of things in a network and then some of them are always making plenty of power right?
There are 100s of studies saying he's right, what's needed more than storage are grids that can get electricity where it's needed more efficiently and reliably than they do now. It's pretty rare to have a completely still, windless night across a whole country. Don't get me wrong storage has a part to play, particularly as you say to keep solar farms going through the night, but this idea we need billions of dollars of batteries or other storage, or dozens of nuke plants to deal with intermittency is just wrong.Tony Seba, who has a good history of accurate predictions as a futurist, says the solution to the problem of renewable to energy storage can mostly be extrapolated from trends. Solar keeps getting much more efficient at lower light levels - it used to be worthless when it's cloudy, now the output falls a lot but is still significant. This keeps improving. Plus solar keeps getting much cheaper, really fast. By his calculations, for most places, for most needs, large grids to send power around + massively overbuilt solar is the cheapest solution to provide enough energy all the time. Not even taking CO2 emissions into account - it will simply be the cheapest, even compared to fossil fuels. Storage only needs sufficient to handle nights, not long stretches of clouds.
This solution also has the upsides that if you want to build something to capitalize on intermittent massive energy excesses, you're going to have those a lot, if the system is so overbuilt as to provide for base load when you have long stretches of clouds.
I don't know if he's right, but it's interesting.
I would think the solution would be more R&D into nuclear energy.
Works great along lakes as well. https://en.wikipedia.org/wiki/Ludington_Pumped_Storage_Power_PlantThat was addressed in the article. That only works well in mountainous areas. With droughts expected to be more common in the future, one cannot expect to use the massive volumes of water for energy storage that would be required without a large elevation change.
Looking at how several of the bigger dams in the US have their lakes under their designed levels, you probably have some cheap storage already available, just let those dams get back to their designed levels. Either by using them less during the day, when the winds is blowing. Or by allowing them to cut the flow a little more for weeks to downriver.I grew up somewhere with LOTS of hydro dams. I have a soft spot for them! But the reality is, building a hydro dam is a bit of an ecological disaster. Pumped storage just makes that worse, really, because it's all the downsides of expense and ecological destruction with only storage capability, none of the new power generating capacity.
As far as "somebody just has to pay," I mean, yeah. If everything were free storage would be easy.
You can have cheap or you can have reliable. They don't go hand in hand. Anyone that says otherwise is clown level hilarious. There's no reason not to boost renewables. However, there's also a need for continuous reliable power. Unless you like rolling blackouts?On an article focused on cost ... saying the most expensive option by orders of magnitude is "the solution" is clown-level hilarious.
I don't think this is a good idea. Didn't downvote it because it's something worth discussing.. but:Why no commentary on using excess power to create biofuels to feed the existing power plants? It seems that if you've already got a massive infrastructure for boilers and power generation that converting them to operate on bio-derived fuels is a much lower infrastructure option than any of the ones mentioned.
Yup! Not just cheap, but plentiful and economically efficient to mine: modern lead mining recovers more than 90% of the lead in the ore. Compare that to rare earths where the recovery is something like half to two thirds of the REEs in the ore.Is lead actually cheap, when you start needing to store GWh or TWh? Won't supply and demand raise the price when you buy that much?
The problem is most of them are below design level due to drought. There's no water to refill them.Looking at how several of the bigger dams in the US have their lakes under their designed levels, you probably have some cheap storage already available, just let those dams get back to their designed levels.
Nuclear plants haven't proven especially reliable in recent years. They're always offline for one reason or another, meanwhile ratepayers are still paying the bill for their construction costs.You can have cheap or you can have reliable. They don't go hand in hand. Anyone that says otherwise is clown level hilarious. There's no reason not to boost renewables. However, there's also a need for continuous reliable power. Unless you like rolling blackouts?
Each flywheel can store 32 kilowatt-hours of energy, close to the daily electricity demand of an average American household.
I am also a huge fan of space elevators, the main issue is we don't currently have a cable material strong enough. But yes, having a space elevator (or more ideally, a series of them) anchored to a massive asteroid covered in solar panels and recovering the vast majority of energy required to send the attached containers/passenger vehicles up to the anchor point when sending a counter weight down would solve a lot of issuesSpace elevators. The answer is always space elevators.
When electricity is cheap, send mass into geosynchronous orbit. When electricity is expensive, bring it back down.
I believe the minimum energy required is about 100MJ / KG to take mass from surface to geosynchronous, costing maybe $10 / KG in electricity required. In other words, about $10,000/ton. Could be a lot more or a lot less. Then you can recover that electricity by bringing the mass back down, on a 35,000 mile trip from geosync back to the Earth's surface.
If we have a zero-gravity marshalling yard / storage at the top of the elevator, say, able to store a megaton (1 million tons) of mass, that's roughly $10 billion of electricity storage available at the top.
Plus there may be one or two other rather nice things possible when you have a space elevator(s), but I leave that as an exercise for the advanced reader.
A quick back of the envelope. There were 4.5 million tonnes of lead mined in 2023. Let's say it takes 10kg to make a 1kWh battery (12V 83Ah). The annual global production of lead would make 450GWh of batteries, which is enough to run the UK for 15 hours. That's not nothing, but the UK would need about 10x as much, and other countries might have similar demands.Yup! Not just cheap, but plentiful and economically efficient to mine: modern lead mining recovers more than 90% of the lead in the ore. Compare that to rare earths where the recovery is something like half to two thirds of the REEs in the ore.
It's so cheap, that's why they used to make pipes out of it and put it as an additive in gasoline. Also it is easy to weld and soft, which makes it easy to machine, which is partly why it is so toxic because it is volatile and requires extra care to avoid exposure.
I'm hopeful about nuclear, but so far the data I've seen shows that it has been very expensive compared to other power sources. And historically it has only made sense for larger power plants.We've had the answer to non-fossil fuel based energy and non-greenhouse gas emitting energy for 70 years: nuclear power. The modern environmental movement has done immense damage to their own cause by their irrational hatred of nuclear power
It appears to be 2-3x the cost of current home battery systems of similar capacity.How does the cost for one of these compare to a home battery, and can I get one buried in my backyard?
When you need to store two weeks worth of energy, chemical batteries are very expensive compared to things like compressed air or hydrogen or gravity-based storage.As battery costs become cheaper and cheaper, there’s absolutely no reason to not install a surplus 3x, 5x or more of actual on-paper needed capacity. Any situation should be readily covered.
That's the problem. We need it yesterday and building it takes 30 years. Then it's shut down a lot of the time for maintenance and recertification.It's baffling how this is even a controversial opinion. We need nuclear, and we need it yesterday.
Two years ago we had no wind for roughly a week across a thousand km of Canadian prairie. (And it was winter so the days were short and power consumption was near the annual maximum.) You'd need either very long transmission lines or very large amounts of energy storage to cover that.It’s shining and blustery as hell someplace else. Also the tide and waves are always going and geothermal vents don’t take days off. That’s why you put a whole bunch of things in a network and then some of them are always making plenty of power right?
We need to rapidly lower atmospheric CO2. Not add to it.Why no commentary on using excess power to create biofuels to feed the existing power plants? It seems that if you've already got a massive infrastructure for boilers and power generation that converting them to operate on bio-derived fuels is a much lower infrastructure option than any of the ones mentioned.
Wouldn’t Canada need pretty long transmission lines anyway?Two years ago we had no wind for roughly a week across a thousand km of Canadian prairie. (And it was winter so the days were short.) You'd need either very long transmission lines or very large amounts of energy storage to cover that.
Presumable the carbon in bio derived fuels would have already come from the atmosphere -- that's where the bio part comes in.We need to rapidly lower atmospheric CO2. Not add to it.
I also think the authors missed this one. If you are building massive, expensive infrastructure, such as compressed air storage can't you build pumped hydro in a similar manner?Where does Pumped Storage Hydropower fit into the picture? It's already in some use in a number of countries, including a number in the US. I guess one big question is whether there are good geographic locations to build out more of them.
Isn't the only benefit of hydrogen as an energy storage medium that you can transport it? Like, if Egypt has an excess of energy they can store it in hydrogen and sell it to Germany.
Throwing some DC cables between Egypt and the European grid would probably be more efficient in the long term.
EDIT: It's 400 miles between Egypt and mainland Greece. I don't know of Crete is connected to the main EU grid or not. But that could be a side benefit of this.
