[url=http://meincmagazine.com/civis/viewtopic.php?p=28428693#p28428693:3cnzkwxp said:M-S-G[/url]":3cnzkwxp]Why would you spend 2x $ for PCIe SSD in a low performance setup like this?
Is there any benefit in a low-end environment like this one?
[url=http://meincmagazine.com/civis/viewtopic.php?p=28428693#p28428693:2y0szjt9 said:M-S-G[/url]":2y0szjt9]Why would you spend 2x $ for PCIe SSD in a low performance setup like this?
[url=http://meincmagazine.com/civis/viewtopic.php?p=28428839#p28428839:1jaocpnt said:Akemi[/url]":1jaocpnt][url=http://meincmagazine.com/civis/viewtopic.php?p=28428693#p28428693:1jaocpnt said:M-S-G[/url]":1jaocpnt]Why would you spend 2x $ for PCIe SSD in a low performance setup like this?
There's always a benefit to having an SSD over a traditional HDD. My mom's old laptop (purchased in 2006 - 1.66 GHz Core 2 Duo, 4GB RAM, and integrated Intel video) performs substantially better since I swapped her old HDD for a nice SSD.
Boot times are near instant, there's no pausing during page file usage, and of course read/write times are substantially improved. The biggest bottleneck in computers is the HDD.
[url=http://meincmagazine.com/civis/viewtopic.php?p=28428737#p28428737:qjs0hao0 said:thomsirveaux[/url]":qjs0hao0][url=http://meincmagazine.com/civis/viewtopic.php?p=28428693#p28428693:qjs0hao0 said:M-S-G[/url]":qjs0hao0]Why would you spend 2x $ for PCIe SSD in a low performance setup like this?
You do get quantifiably faster copy and loading speeds and things, though you're still going to have bottlenecks depending on where you're copying stuff from/to.
The implications are more interesting for higher-end systems, probably - I bet we'll see more desktop motherboards with M.2 connectors, and the 9-series chipsets are much more reliable about booting from M.2 cards mounted to PCIe cards.
[url=http://meincmagazine.com/civis/viewtopic.php?p=28428899#p28428899:32mesu52 said:thomsirveaux[/url]":32mesu52][url=http://meincmagazine.com/civis/viewtopic.php?p=28428839#p28428839:32mesu52 said:Akemi[/url]":32mesu52][url=http://meincmagazine.com/civis/viewtopic.php?p=28428693#p28428693:32mesu52 said:M-S-G[/url]":32mesu52]Why would you spend 2x $ for PCIe SSD in a low performance setup like this?
I think M-S-G was comparing PCIe SSDs to (somewhat slower, much cheaper) SATA SSDs, which you can also put in this thing.
[url=http://meincmagazine.com/civis/viewtopic.php?p=28428955#p28428955:7hv9evfs said:operagost[/url]":7hv9evfs]"There's a lot to unpack, starting with the fact that there's no such thing as "an M.2 connector" or "an M.2 card."
The next line:
"Above are four M.2 cards."
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429025#p28429025:7hv9evfs said:adipose[/url]":7hv9evfs]So, I am just being lazy, but does anyone know if my SSD card for my gen1 NUC is compatible with these slots?
Well, it's not a 970 (or even an advertised 760, I think the chipset is actually an 850?), but ... it's not impossible to get something a little bit closer than not...[url=http://meincmagazine.com/civis/viewtopic.php?p=28429027#p28429027:189ye0gt said:PapagenoF[/url]":189ye0gt]Now if I could only fit a GTX 970 in this thing...
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429061#p28429061:2ga9yn4u said:thomsirveaux[/url]":2ga9yn4u]"An" is singular, "cards" is plural.
[url=http://meincmagazine.com/civis/viewtopic.php?p=28428805#p28428805:twfotjy5 said:ElectricBlue[/url]":twfotjy5]Looks like these small form factor PCs have finally surpassed my 2009 laptop in all categories. I'm seriously considering turning one of these into a SteamPC/Media box for my TV. I know it won't be able to play Witcher 3 the way i'd want but I have a PS4 for those kind of games.
I'm thinking size is the main factor for using an M.2 drive in this model. The article mentions that the motherboard has a SATA port on it for using a more standard 2.5" drive in a larger enclosure.[url=http://meincmagazine.com/civis/viewtopic.php?p=28428693#p28428693:1v1myoe3 said:M-S-G[/url]":1v1myoe3]Why would you spend 2x $ for PCIe SSD in a low performance setup like this?
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429061#p28429061:252um3qx said:thomsirveaux[/url]":252um3qx][url=http://meincmagazine.com/civis/viewtopic.php?p=28428955#p28428955:252um3qx said:operagost[/url]":252um3qx]"There's a lot to unpack, starting with the fact that there's no such thing as "an M.2 connector" or "an M.2 card."
The next line:
"An" is singular, "cards" is plural. If you just say "this laptop takes an M.2 card" you've conveyed about a third of the information you actually need to have.
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429025#p28429025:252um3qx said:adipose[/url]":252um3qx]So, I am just being lazy, but does anyone know if my SSD card for my gen1 NUC is compatible with these slots?
Nope. mSATA cards won't fit.
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429101#p28429101:2mw589sc said:JustQuestions[/url]":2mw589sc]I'd actually be curious to know what these things weigh (with a single SSD).
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429061#p28429061:2mw589sc said:thomsirveaux[/url]":2mw589sc]"An" is singular, "cards" is plural.
So...It was a grammatical joke? Kind of like saying, "there is no such thing as an PCIe card?"
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429405#p28429405:38hb6jd3 said:DyDx[/url]":38hb6jd3][url=http://meincmagazine.com/civis/viewtopic.php?p=28429101#p28429101:38hb6jd3 said:JustQuestions[/url]":38hb6jd3]I'd actually be curious to know what these things weigh (with a single SSD).
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429061#p28429061:38hb6jd3 said:thomsirveaux[/url]":38hb6jd3]"An" is singular, "cards" is plural.
No, Andrew is saying that there's no such thing as "an" M.2 card, but there is such a thing as an A-keyed M.2 card, an M-keyed M.2 card, etc. Referring to "an M.2 card" is meaningless without the key information because there is no singular "M.2 card" but rather a variety of them. I don't think it was meant as a joke, though it's understandably a little unclear.
Leaving aside the question of whether anyone still has honest-to-goodness LAN parties in the year 2015
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429423#p28429423:1ugyyyqz said:JustQuestions[/url]":1ugyyyqz][url=http://meincmagazine.com/civis/viewtopic.php?p=28429405#p28429405:1ugyyyqz said:DyDx[/url]":1ugyyyqz][url=http://meincmagazine.com/civis/viewtopic.php?p=28429101#p28429101:1ugyyyqz said:JustQuestions[/url]":1ugyyyqz]I'd actually be curious to know what these things weigh (with a single SSD).
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429061#p28429061:1ugyyyqz said:thomsirveaux[/url]":1ugyyyqz]"An" is singular, "cards" is plural.
Thanks for that, although I'm more interested in what the box weighs than discussing grammar.
Also, you could say the same about PCIe since there is x1, x2, x4, x16
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429427#p28429427:if1h7cem said:ChrisSD[/url]":if1h7cem]How does the Intel HD Graphics 6000 compare with something like the GTX 750 Ti? I'm wondering if the use case for the 750 is going to become very narrow as more efficient integrated graphics get more powerful.
[url=http://meincmagazine.com/civis/viewtopic.php?p=28429533#p28429533:2la7p5kq said:nehinks[/url]":2la7p5kq]I didn't realize the 5200 was that much better than the others - impressive. Stick that 6200 with integrated eDRAM in, and I'm sold. I know you mentioned the chip was coming at some point - was there any mention of whether it might be available in one of these?
