Fusion energy breakthrough by US scientists boosts clean power hopes
mhalpern
There is this strange paragraph in that article:
I feel like there needs to be a clear fusion milestone list like there is with autonomous driving 1-5. Perhaps that article means it made more energy than it took to create the hydrogen fuel while this one created more energy than making the fuel + the energy in the lasers?
Enjoying the commentary on all this. Hopefully more comes to light during the full announcement tomorrow.
current reactors dont even attempt to extract energy, just measure it, so the milestone is "break even" and duration of reaction
archtop
This site has electricity generation for the UK https://gridwatch.co.uk/ and renewables are basically dead as the wind has stopped blowing and due to it being winter solar is also dead and both have been for the last 39 hours.
How much battery capacity and how big an area of land would be needed to power the UK for that length of time using the 35.5 to 38.5GW's average electricity usage?
Because currently we are just burning lots of natural gas with some coal and biomass.
This is with the UK having 25GW of installed capacity for wind power and 14GW of solar.
We need fusion to become usable a lot faster than it is going to be.
Wow . . . "the wind has stopped blowing".
rojcowles
It won't have to compete with solar and wind. Solar and wind alone are not going to be what powers the grid. Likely where Fusion will have a home is in helping to provide the last few percent of power to the grid, which is going to cost significantly more per kW-hr than the first 95% of production.
Huh, hadn't thought of that. Thanks!
Did read an article that suggested that space based solar could be economically viable, despite the sky high capital costs, horrific maintenance challenges for the space based components and massive conversion inefficiencies, if it also is viewed as the way to close the gap on the final few percentage points of demand that can't be met through renewables+storage so we can eventually decommission every thermal power plant.
Electricity non-expert here. How does 0.4 megajoules surplus map to kWs & kWhs? It looks like you have to know how long the experiment ran for — i.e. how much time that 0.4 mJ output is spread over? Anyone know / know if I'm on the right track?
The conversion to kWh is direct. 0.4 MJ equals 0.111 kWh.
Uragan
Or just build more fission reactors instead of waiting for the possibility of fusion being a reality.
Statistical
It is confusing because there are two different terms and they are often conflated.
Ignition is a self sustaining fusion reaction without any additional energy required once ignition happens. Ignition doesn't necessarily mean more energy in and energy output. The NIF achieved ignition in 2021 but it had a 70% return on energy.
Break even is just that energy out equals energy in but a self sustaining isn't a requirement although it certainly help. In the prior article it was modeled not actually achieved. Other near break even events (JTER) have happened but they required outside energy to sustain the fusion reaction (no ignition).
Both are separate and equally important milestones but they are often conflated into one. This event is the first one that does both. It achieved ignition something your linked event did not and it also produced more energy than was input something that didn't happen in the 2021 event.
Veritas super omens
Yeah because solar panels and wind turbines are so difficult to damage. Lithium batteries never catch fire
It is much harder to damage tens of thousands of small plants sited all over the place than it is to drone one central facility that is makin ALL of the power for a region.
Niemand
There is the second problem: Even with net energy gain, can that energy be collected and converted to electricity with a net gain?
The usual answer is to use the energy to heat some working fluid (turning water into steam, for example) and use standard turbines like fission and coal plants.
There has been discussion of direct conversion of the kinetic energy of the particles "somehow," but those particles would need to be charged. If you've got a lot of neutrons and gamma rays they would just heat up the containment blanket.
The particles that come out of the reaction depend on what isotopes of hydrogen they're using. Deuterium fusion produces helium, neutrons and gamma rays, so I'd guess thermal conversion is required.
So, boiling water. A fusion-powered steam engine, in other words.
Ozy
I don't think this will result in inertial confinement power plants. The cool thing will be if they can figure out why this experiment over performed expectations and use it in magnetically confined reactors.
There are completely different physics going on, so it's unlikely to help much.
Ralf The Dog
Something unexpected is happening in the physics. I am not saying it's rewrite the books kind of unexpected. I am saying there is probably some kind of interaction happening that we were not expecting. Understand that and, who knows?
Demosthenes642
This is what happened with the fusion experiment. The calculated the raw amount of energy the laser theoretically imparted into the reaction, and that was bigger than the amount they got out, just like turning a key "produces" energy at only the cost of a few of your muscles moving. In the case of this experiment, they ignored the literal energy it took to power the laser and the power it took to run the fusion system. They ONLY counted the exact amount of energy the laser imparted in that moment. It also ignores the fact that they couldn't extract any of the energy for useful work, and that this system can't run continuously.
Don't get me wrong, this is a great experiment taking a step forward, but it was a small step and not getting us anywhere near real fusion power.
The NIF isn't a power plant, it's a research facility designed for flexibility and instrumentation. The input energy and efficiency of the NIF's laser driver system is immaterial as it has little relation to the systems that would be used in a power station. By the same token the NIF isn't designed to extract energy from the fusion process or to run continuously so complaining that it didn't is fatuous.
The gain from the reaction itself is what matters because that determines the efficiency floor for all the other systems to make a power plant based around that reaction economically viable. It might be that ICF is never viable but the wall plug draw of the NIF will have nothing to do with that determination.
Or there's a measurement error.
It's worth validating, it's not worth jumping to conclusions.
Ozy
Given the understanding of plasma confinement and turbulence is low to begin with, it's not at all surprising that 'unexpected' results show up. However, given the differences in plasma regimes (density/temperature), confinement mechanisms (inertial vs. magnetic), and heating mechanisms (laser/radiation vs. ohmic/neutral particles/RF), the chances of any understanding of what's happening here being relevant to magnetically confined plasmas is low.
Chuckstar
Do you have a cite for that because I can't find any articles or cites to support that claim. There were papers published in 2022 confirming the 2021 ignition.
They achieved ignition in 2021 however 1) the energy output was only 70% of the energy input and 2) despite trying to replicate it for a year they couldn't. So to replicate ignition again and not produce the same 70% output but a claimed 120% is a pretty big and unexpected deal.
The sequence of events was
August 2021 - achieve first ignition with 70% yield (1.4 MJ on 1.92 MJ shot)
Rest of 2021 and through Nov 2022 - multiple attempts to replicate but zero successful ignitions.
Dec 2022 - achieve second successful ignition but with 70% yield but a 120% yield (2.5 MJ on 2.1 MJ shot).
Maybe that sequence of events was perfectly predictable to you but it was surprising to me, surprising to plenty of people around the world and given the damage to the facility I am going to presume surprisingly to the people doing it.
Sorry, meant last year. Feels like earlier this year, though, considering how time’s been flying.
All that the damage to the facility means is that they didn’t expect this on this round of shots, not that they didn’t think the method/facility was capable of it. There’s a huge difference between the two.
Like I said, they’ve had consistency issues, so pointing out they’ve had consistency issues is hardly telling me anything new.
mhalpern
No. Since this is effectively weapons research disguising as energy production research. Not to mention that this is most likely net positive energy for plasma itself (i.e. more energy out of plasma than was fed into it) which is far removed from net positive for the actual system. Lasers, energy transfer to plasma, energy extraction out of plasma and so on are nowhere near 100% efficient so they will drop the actual ROI by at least an order of magnitude.
It's a fluff piece and nothing else.
It is energy production research, just it's research that assumes that in a working system, the input energy would be fission and the output wouldn't be concerned with electricity.
co-lee
This is very cool. I'd love to see the fusion dream of cheap zero carbon easily available energy come true.
But, I suspect, given who is doing this research and what looks like very very high costs to ever get this working, that fusion like fission will become the domain of large military industrial contractors for whom success is not particularly important as long as the dollars keep flowing.
Would love to see it play out differently....
Veritas super omens
More useless knowledge. /S
as someone once posted "All knowledge is useless, until its not."
Chuckstar
This is the real issue with NIF as a fusion experiment. It’s not really directly applicable to what anyone but Los Alamos is trying to do with fusion. It always had a reasonable likelihood of reaching this threshold before anyone else, but at what utility to the technology of fusion power?
Without doing so all you have is a very large, very expensive space heater. Born in the 1950's the promise of fusion breakthroughs has been always ten years away. This is a milestone, not the end goal.
All this work on fusion and we still do not focus as much energy on the already existing fusion reactor we have, the Sun.
I have been reading that fusion is "just around the corner" or "10/20 years away" and that has been said since before the Pons/Fleishman debacle. Fusion would still need to be converted somehow into energy and today we convert the sun's fusion reaction into energy via photovoltaics and wind turbines. I'd rather see more money put into increasing solar collection capabilities and storage than this potential always down the road fusion program.
Though not quite related, I also feel we do not do enough to tap into Earth's own internal energy source, geo-thermal. Iceland is doing good work there, but here again, if we put more money (and science) into how to tap geo-thermal when it is not as close to the surface, humanity taps into pretty much a forever power source.
Fusion is not a hoax, but its potential for changing the path of humanity's destruction on this planet is too long term and limited (ie it will never be cheap). Solar, microwave beaming, hydro, tidal, wind, and geo-thermal make the most sense in removing humanity from fossil fuels, because we not only can do that today, there is large room for growth.
edit: corrections
ColdWetDog
yup. and yes it is our way around the nuclear test ban
Can someone explain this? Are the reactions so similar to the physics in fusion weapons that the simulations come across? Does it help with new weapons development or is somehow related to checking how fusion bombs 'age'?
Boskone
One watt is 1 joule per second.
I'm not sure how to measure this cycle (e.g. just the actual pulse phase, the entire thing from accumulation to fusion, etc), so no clue in this case how to make the conversion.
I think we'd a sustained reaction to make watt-hours meaningful.
ranthog
More so I think it may be cheaper than the necessary storage to cover rarer events which stress an entire interconnect like storm that almost took down Texas' power grid. Where you have wide spread high usage over the course of a week. So we might just be talking about 1% of power generation here.
I do think that renewables and storage are perfectly viable especially by the time we need to build it out. So we won't need fusion, but fusion may still offer some economic benefits.
All this work on fusion and we still do not focus as much energy on the already existing fusion reactor we haver, the Sun.
That isn't even close to true though. If everyone was spending trillions of dollars on fusion and nobody building/researching PV panels you might have a valid point. Except the opposite is true. Nearly nothing (relatively speaking on global economy scales) is spent on fusion power. This facility only got greenlighted for the value in modeling nuclear weapons. If that didn't exist exactly $0 would have been spent.
The PV power market is $180B annually expected to grow to $290B by the end of the decade. Fusion research is a rounding error on that.
https://www.globenewswire.com/en/ne...-18-Billion-Globally-by-2028-at-6-9-CAGR.html
So we are doing both and the vast majority of the money is going towards the more immediate practical power source.
A small step, but a very important small step. Assuming it all holds up on review, they just proved that the process is viable. Now it's just a matter of refining and improving it.
...and finding a viable source for Tritium that does not involve constructing a bunch of fission reactors to feed the fusion reactors.
Sabotage won’t do anything because economics promotes use of cheaper energy sources. Coal use has been falling for years even under friendly administrations. It’s not economical to use and there isn’t a damn thing Texas can do to change that calculation.
https://www.eia.gov/energyexplained/coal/use-of-coal.php
Natural gas use has gone up as have renewables. An energy source like fusion would quickly put natural gas in a similar position as coal.
https://www.eia.gov/energyexplained...y-in-the-us-generation-capacity-and-sales.php
Believe it or not electric companies don’t like paying more than they have to either and will quickly switch to cheaper energy sources.
Edit: Wording
After the Texas freeze a couple years ago, Texas literally put forward a state bill to ban companies who create electricity using clean energy sources or other smaller providers from being on ERCOT's Board of Directors. ERCOT, who manages their grid and dictates who can provide power to it.
Read that again: They essentially made it so ERCOT, the governing body who controls Texas' grid, made it so no one outside giant companies that operate in fossil fuels can be on it.
It lasted nanonseconds. Still a huge amount of energy in a small time period can be buffered by a heat transfer fluid. To visualize imagine a tank of water with a supersized gas burner heating it. It blasts the tank for one second every 10 seconds. Using the water as a "heat battery" you could produce steam and run that steam through a turbine and produce continual power from an intermittent source. Now would you do that with natural gas burner. No because it would be simpler and easier to use a burner 1/10th the output and run it continually.
Chuckstar
The weapons-related experiments at NIF relate to how the materials work — mostly, but not exclusively, targeted at changes due to age. The idea is to improve the assumptions used in the computer models of bombs, so we can fine-tune the shelf-life assumptions. The publicly-announced data is essentially bonus science that can be done with the same setup (or greenwashing, if one views weapons stewardship more cynically).
mhalpern
fission induced fusion is expected to be similar to inertial confinement fusion with the physics involved.
winwaed
Excellent, but usually they report the Q_plasma( or Q_laser, in this case), namely, the ratio between the energy carried by the lasers into the actual fusion material and the heat produced. This is all good, but the true goal is to have a ratio for the TOTAL energy used versus the useful energy extracted.
This means: on one side the energy for the lasers (In this case, a factor of 10 conservatively), cooling, etc.. and on the other side the energy after conversion from heat to mechanical or electrical.
There is a YouTube video of Sabine Hossenfelder which explains this well (much better than me here).
Don‘t get me wrong; this is a breakthrough. But it is mostly psychological and not quite practical yet. Hopefully it is one less rung in the ladder towards viability.
That was essentially my reading (although the article is a little sketchy). A breakthrough for laser ignition but still ~30yrs behind tokamaks.
(JET had more out than in, sustained for a few seconds, in the early 90s - of course it took a lot more energy to get it fired up!)
fzammetti
I agree. However, if the reports of them getting more out than expected are true, that's actually more interesting to me than simply achieving break-even. The best words you can ever hear from a scientist on stuff like this is "woah, I didn't expect that" because it's possible there's some mechanism there that we didn't know about and which could yield a breakthrough, or just make progress faster. I'm really interested in hearing those details, what they think is the reason for more energy produced than expected (if that's true at all). It could always just be a "oh, we forgot the carry the one" somewhere, but these are smart people, so I feel safe in assuming there's more to it than that, and I'm hopeful whatever it is winds up being a very useful bit of gained knowledge that accelerates fusion research generally.
We do have one proof of concept for fusion come to think of it. Solar (and a little less directly, wind) already harvest the product of an utterly massive self sustaining fusion reaction. It's just that way more of it's energy is lost due to the tiny defect of most of the sun's light missing the earth. Then again maybe that's also for the best... A sun-laser aiming all of the sun's energy output at earth might overload the grid.
raschumacher
That's nice, but by this late date there is no plausible path for fusion energy to stop, or even slow, the ongoing global warming catastrophe. To do that we would have to replace all the world's fossil fuel uses with every non-fossil energy source now in hand: wind, Solar, and nuclear fission, along with the transmission, storage, and artificial fuels technologies needed to make full use of them.
