Always fun to see people make technical statements that contradict themselves. Hint: Look up what WinPhone apps are written in.[url=http://meincmagazine.com/civis/viewtopic.php?p=26046009#p26046009:4ggpb6w2 said:StarKruzr[/url]":4ggpb6w2]* It will be faster than Android on the same hardware in the same way that iOS or Windows Phone is, because it will be running executable code rather than interpreted.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:4ggpb6w2 said:TimtheTaxMan[/url]":4ggpb6w2]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
Well, except those custom frontends are generally much easier to access and use then the website, so I will have to disagree with you on that.[url=http://meincmagazine.com/civis/viewtopic.php?p=26044959#p26044959:3r2rsqc4 said:null_interface[/url]":3r2rsqc4]Given that some huge percentage of apps are just custom frontends to websites and indeed offer no additional functionality, the lack of apps may not necessarily be a bad thing.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26046009#p26046009:166ovhwp said:StarKruzr[/url]":166ovhwp]There are a couple of points.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:166ovhwp said:TimtheTaxMan[/url]":166ovhwp]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
* There is an existing, large, enthusiastic developer and software base for Linux.
That performance-per-clock difference might be worth it all by itself.
Agreed, I'm just not sure Canonical can deliver. I hope they succeed, but over the last few years the company has come across to me as a bunch of adolescents entranced with the latest shiny toy only to discard it a few months later when a new shiny comes along.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045433#p26045433:3n2n5i9m said:Caffarius[/url]":3n2n5i9m]That's basically what I want, "just another Linux based smartphone" but without the all seeing hand of Google in the mix.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:3n2n5i9m said:TimtheTaxMan[/url]":3n2n5i9m]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26044959#p26044959:2oqvzp1u said:null_interface[/url]":2oqvzp1u]Given that some huge percentage of apps are just custom frontends to websites and indeed offer no additional functionality, the lack of apps may not necessarily be a bad thing.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26046009#p26046009:263oz55i said:StarKruzr[/url]":263oz55i]There are a couple of points.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:263oz55i said:TimtheTaxMan[/url]":263oz55i]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
Not exactly, but somewhat. If I understand correctly from what I've read (and I could be dead wrong), you're talking about ART, the new android runtime that isn't officially supported yet. Dalvik uses JIT compilation to run apps, leading to considerably overhead; this is where most android performance issues come from (as far as I understand it). The premise of ART is to pre-compile the java bytecode into machine language immediately upon installation, which means it doesn't have to be interpreted every time an app is run. As of now, it can also really break your apps[url=http://meincmagazine.com/civis/viewtopic.php?p=26047013#p26047013:3hzz9409 said:SheldonRoss[/url]":3hzz9409][url=http://meincmagazine.com/civis/viewtopic.php?p=26046009#p26046009:3hzz9409 said:StarKruzr[/url]":3hzz9409]There are a couple of points.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:3hzz9409 said:TimtheTaxMan[/url]":3hzz9409]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
I was under the impression that recent versions of Android where moving over to native code execution. I seem to remember reading that somewhere...
[url=http://meincmagazine.com/civis/viewtopic.php?p=26045127#p26045127:k8kg0lbr said:ws3[/url]":k8kg0lbr][url=http://meincmagazine.com/civis/viewtopic.php?p=26045103#p26045103:k8kg0lbr said:beebee[/url]":k8kg0lbr][url=http://meincmagazine.com/civis/viewtopic.php?p=26044857#p26044857:k8kg0lbr said:Ostracus[/url]":k8kg0lbr]Canonical: Ideal Ubuntu phone user is someone who doesn't need a lot of apps.
Buy a BB.![]()
Except BlackBerry BB10 can run Android apps.
BlackBerry's approach to Android is similar to WINE. But in the future, as processors get more powerful, Ubuntu can simply run Android in a VM.
Ubuntu can run BB10 in a VM and then you can run your Android apps on the virtualized BB10 on Ubuntu.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26044883#p26044883:3e7c7yqc said:jdale[/url]":3e7c7yqc][url=http://meincmagazine.com/civis/viewtopic.php?p=26044857#p26044857:3e7c7yqc said:Ostracus[/url]":3e7c7yqc]Canonical: Ideal Ubuntu phone user is someone who doesn't need a lot of apps.
Buy a BB.![]()
As a current WebOS user, I'm just what he has in mind.![]()
Using a z10 running 10.2.1 right now, I have to disagree with this; android support has been getting consistently better, but the performance is still spotty depending on which apps you're running. Some apps perform absolutely fantastic (kobo, netflix) while others have substantial stutter (Kindle, Tumblr)[url=http://meincmagazine.com/civis/viewtopic.php?p=26047919#p26047919:1me1oi7p said:beebee[/url]":1me1oi7p]On BB10, the Android apps run as fast as native apps, much like running Window on WINE has no speed issues. Often you can't tell it was an Android app other than it uses the "back" swipe that I have a hard time doing. On bb10, you can swipe up to get a "back" key added to the bottom of the screen.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045127#p26045127:1me1oi7p said:ws3[/url]":1me1oi7p][url=http://meincmagazine.com/civis/viewtopic.php?p=26045103#p26045103:1me1oi7p said:beebee[/url]":1me1oi7p][url=http://meincmagazine.com/civis/viewtopic.php?p=26044857#p26044857:1me1oi7p said:Ostracus[/url]":1me1oi7p]Canonical: Ideal Ubuntu phone user is someone who doesn't need a lot of apps.
Buy a BB.![]()
[url=http://meincmagazine.com/civis/viewtopic.php?p=26045115#p26045115:1xnoye1h said:ws3[/url]":1xnoye1h][url=http://meincmagazine.com/civis/viewtopic.php?p=26045031#p26045031:1xnoye1h said:Merkoth[/url]":1xnoye1h][url=http://meincmagazine.com/civis/viewtopic.php?p=26044917#p26044917:1xnoye1h said:ws3[/url]":1xnoye1h]Canonical: Ideal Ubuntu phone user is someone who doesn't need a lot of apps.
... and who likes to compile their own kernels and fiddle with configuration files when stuff goes wrong.
Is this really a thing that happens to people? Last time I was forced to compile a kernel was many, many years ago.
I don't know. I don't use Linux anymore because I grew to dislike compiling kernels and fiddling with configuration files.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26047919#p26047919:aje40v99 said:beebee[/url]":aje40v99]If it wasn't for the fact that linux has less than 2% of the desktop market, MS would probably put out a hit on the WINE developers.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26045433#p26045433:4g2qnhlo said:Caffarius[/url]":4g2qnhlo]That's basically what I want, "just another Linux based smartphone" but without the all seeing hand of Google in the mix.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:4g2qnhlo said:TimtheTaxMan[/url]":4g2qnhlo]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26046833#p26046833:1rgtq8z2 said:PhilGil[/url]":1rgtq8z2]Agreed, I'm just not sure Canonical can deliver. I hope they succeed, but over the last few years the company has come across to me as a bunch of adolescents entranced with the latest shiny toy only to discard it a few months later when a new shiny comes along.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045433#p26045433:1rgtq8z2 said:Caffarius[/url]":1rgtq8z2]That's basically what I want, "just another Linux based smartphone" but without the all seeing hand of Google in the mix.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:1rgtq8z2 said:TimtheTaxMan[/url]":1rgtq8z2]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
Maybe Firefox OS has a chance, at least it's shipping on real hardware.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26047167#p26047167:r2ejtbgd said:Sajuuk[/url]":r2ejtbgd]Not exactly, but somewhat. If I understand correctly from what I've read (and I could be dead wrong), you're talking about ART, the new android runtime that isn't officially supported yet. Dalvik uses JIT compilation to run apps, leading to considerably overhead; this is where most android performance issues come from (as far as I understand it). The premise of ART is to pre-compile the java bytecode into machine language immediately upon installation, which means it doesn't have to be interpreted every time an app is run. As of now, it can also really break your apps[url=http://meincmagazine.com/civis/viewtopic.php?p=26047013#p26047013:r2ejtbgd said:SheldonRoss[/url]":r2ejtbgd][url=http://meincmagazine.com/civis/viewtopic.php?p=26046009#p26046009:r2ejtbgd said:StarKruzr[/url]":r2ejtbgd]There are a couple of points.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:r2ejtbgd said:TimtheTaxMan[/url]":r2ejtbgd]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26046287#p26046287:2eok1sf4 said:daneren2005[/url]":2eok1sf4]Well, except those custom frontends are generally much easier to access and use then the website, so I will have to disagree with you on that.[url=http://meincmagazine.com/civis/viewtopic.php?p=26044959#p26044959:2eok1sf4 said:null_interface[/url]":2eok1sf4]Given that some huge percentage of apps are just custom frontends to websites and indeed offer no additional functionality, the lack of apps may not necessarily be a bad thing.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26048079#p26048079:10su564d said:Sajuuk[/url]":10su564d]Using a z10 running 10.2.1 right now, I have to disagree with this; android support has been getting consistently better, but the performance is still spotty depending on which apps you're running. Some apps perform absolutely fantastic (kobo, netflix) while others have substantial stutter (Kindle, Tumblr)[url=http://meincmagazine.com/civis/viewtopic.php?p=26047919#p26047919:10su564d said:beebee[/url]":10su564d]On BB10, the Android apps run as fast as native apps, much like running Window on WINE has no speed issues. Often you can't tell it was an Android app other than it uses the "back" swipe that I have a hard time doing. On bb10, you can swipe up to get a "back" key added to the bottom of the screen.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045127#p26045127:10su564d said:ws3[/url]":10su564d][url=http://meincmagazine.com/civis/viewtopic.php?p=26045103#p26045103:10su564d said:beebee[/url]":10su564d][url=http://meincmagazine.com/civis/viewtopic.php?p=26044857#p26044857:10su564d said:Ostracus[/url]":10su564d]Canonical: Ideal Ubuntu phone user is someone who doesn't need a lot of apps.
Buy a BB.![]()
I concur. You won't catch me dead running Ubuntu on my desktop because of some of the choices the dev team has made since 11.10.[url=http://meincmagazine.com/civis/viewtopic.php?p=26046833#p26046833:26lxi6sn said:PhilGil[/url]":26lxi6sn]Agreed, I'm just not sure Canonical can deliver. I hope they succeed, but over the last few years the company has come across to me as a bunch of adolescents entranced with the latest shiny toy only to discard it a few months later when a new shiny comes along.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045433#p26045433:26lxi6sn said:Caffarius[/url]":26lxi6sn]That's basically what I want, "just another Linux based smartphone" but without the all seeing hand of Google in the mix.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:26lxi6sn said:TimtheTaxMan[/url]":26lxi6sn]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26049511#p26049511:22sg1ujz said:Caffarius[/url]":22sg1ujz]I concur. You won't catch me dead running Ubuntu on my desktop because of some of the choices the dev team has made since 11.10.[url=http://meincmagazine.com/civis/viewtopic.php?p=26046833#p26046833:22sg1ujz said:PhilGil[/url]":22sg1ujz]Agreed, I'm just not sure Canonical can deliver. I hope they succeed, but over the last few years the company has come across to me as a bunch of adolescents entranced with the latest shiny toy only to discard it a few months later when a new shiny comes along.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045433#p26045433:22sg1ujz said:Caffarius[/url]":22sg1ujz]That's basically what I want, "just another Linux based smartphone" but without the all seeing hand of Google in the mix.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:22sg1ujz said:TimtheTaxMan[/url]":22sg1ujz]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
What I think most people are forgetting is that it's Linux. We don't really need Canonical for it to succeed, just a starting point. The work can be forked, the proprietary blobs replaced with open code, etc etc. OEMs don't produce Ubuntu phones? Buy an Android phone and replace the OS. I'm not excited about a particular piece of hardware or a list of apps. I'm excited because it's the first time in the mobile sector where we're offered honest to $DIETY choices in how the device operates instead of being locked into $COMPANY's paradigm of the month.
Some people want a simple platform that handles everything for them and programs are installed at the touch of a button. You already have a plethora of options for that. This could be a platform for the person who's waiting to spend a weekend tearing their OS apart and get it working in exactly the fashion they'd like. Or maybe they want to see how ZFS acts on eMMC for giggles. Or how handy it could be to hop on the WiFi and use a real Samba client to move files from their Windows desktop to their phone without some silly proprietary sync app. Or maybe Intel does crack into the smartphone market and you want to see how Steam does. The possibilities are almost endless without an app store.![]()
[url=http://meincmagazine.com/civis/viewtopic.php?p=26045433#p26045433:27i6nsdg said:Caffarius[/url]":27i6nsdg]That's basically what I want, "just another Linux based smartphone" but without the all seeing hand of Google in the mix.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:27i6nsdg said:TimtheTaxMan[/url]":27i6nsdg]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
You have been able to compile native code on Android for years now using the official NDK. You can even mix and match, if you have speed critical sections those can be written in native code while the rest is in java/dalvik.[url=http://meincmagazine.com/civis/viewtopic.php?p=26047013#p26047013:d1uj6hpk said:SheldonRoss[/url]":d1uj6hpk][url=http://meincmagazine.com/civis/viewtopic.php?p=26046009#p26046009:d1uj6hpk said:StarKruzr[/url]":d1uj6hpk]There are a couple of points.[url=http://meincmagazine.com/civis/viewtopic.php?p=26045227#p26045227:d1uj6hpk said:TimtheTaxMan[/url]":d1uj6hpk]Not that I'm opposed to this, but I fail to see the point. Unless the phone is 100% FOSS, you might as well stick with Android. Otherwise you just have another Linux based smartphone with way fewer apps and no greater freedom or transparency.
[url=http://meincmagazine.com/civis/viewtopic.php?p=26052031#p26052031:3q9724xy said:BajaPaul[/url]":3q9724xy]We will have Android on the desktop before Ubuntu on the phone. that is probably what has MS a bit worried deep down.
