I totally sympathise with you."A well-known example is that the flu makes people more susceptible to a secondary bacterial infection."
I'd never heard of this before, but it explains why I had a cold that wasn't getting better for weeks and then prescribed antibiotics helped. I might even go back to work next week.
That's not comforting in any way.In addition to plain interference, viruses can interact - their replicative/packaging machinery can crossover within the cell, producing weird chimeras - not the scary "super mutant virus" type, but more similar to Brundlefly-Telepod fusion creature in The Fly.
Ars' CMS seems to sometimes hiccup when reprinting Knowable articles. Note that the original has several SVG graphs and illustrations that are sadly absent here. The white ⍰ box is a missing SVG logo asset linked from the original, probably hot‑linked or something. No idea why some browsers render it as a big ugly full‑width box and some don't, but it must have inherited the text column width.And what's with the bright white box?
This phenomenon may be good for, if the immune system holds out well, but very bad if you pretty much overcome the blocking virus, but at the cost of a temporary exhaustion of the immune system, allowing one of the blocked pathogens to superinfect an already weakened immune system. It makes me wonder how much frailty in the elderly (now a somewhat personal interest) is due to the slow decline of the immune system with time, so that instead of the 1 or 2 punch, as time goes by you are much more likely to get the one-two punch.
Welcome to the Virusdome. Two viruses enter. Three viruses leave.In addition to plain interference, viruses can interact - their replicative/packaging machinery can crossover within the cell, producing weird chimeras - not the scary "super mutant virus" type, but more similar to Brundlefly-Telepod fusion creature in The Fly.
Who knew! And I thought that the idea that when you are sick of the flu you can't get another illness was a maid tale.
I've been wondering the same thing. It's well known (whether it's true or not) that teachers and nurses get very sick in their first year in the job, and then become immune to almost everything.Makes you wonder if we should be deliberately infecting ourselves with a mild cold in the event of a really nasty bug doing the rounds...
The immune system doesn’t work that way. It doesn’t get “used up”. If anything, it gets kicked into high gear. It’s not unusual for a bout of flu to also cause the immune system to finally take care of some other infection. Personally, I once had a wart that resisted all treatment, but sloughed off the first day I had the flu, never to return.This phenomenon may be good for, if the immune system holds out well, but very bad if you pretty much overcome the blocking virus, but at the cost of a temporary exhaustion of the immune system, allowing one of the blocked pathogens to superinfect an already weakened immune system. It makes me wonder how much frailty in the elderly (now a somewhat personal interest) is due to the slow decline of the immune system with time, so that instead of the 1 or 2 punch, as time goes by you are much more likely to get the one-two punch.
I'm pretty certain that's not true. Maybe it doesn't get "used up" per se, but it certainly uses a lot of resources, which you don't have an infinite supply of. It can also be weakened and leave you susceptible to a secondary infection.The immune system doesn’t work that way. It doesn’t get “used up”. If anything, it gets kicked into high gear. It’s not unusual for a bout of flu to also cause the immune system to finally take care of some other infection. Personally, I once had a wart that resisted all treatment, but sloughed off the first day I had the flu, never to return.
Or, and this may seem radical, but you could try using N95 masks, social distancing, and hand washing.Makes you wonder if we should be deliberately infecting ourselves with a mild cold in the event of a really nasty bug doing the rounds...
medical.mit.edu says this isn't the way our immune system works: https://medical.mit.edu/covid-19-updates/2020/05/all-social-distancing-weakening-our-immune-systemsI've been wondering the same thing. It's well known (whether it's true or not) that teachers and nurses get very sick in their first year in the job, and then become immune to almost everything.
Should we keep isolating and masking, risking our immune system weakening
But while your immune system won’t have any specific “memory” of the virus, it will mount an immune response if you are infected — because that’s how your immune system works. Coming into contact with germs spurs an immune response, but it doesn’t do anything to make your immune system stronger. And this current period of contact with fewer germs does nothing to weaken the immune response you will be able to mount, as needed, in the future.
But that doesn’t mean social distancing will have no effect on your immune system. The psychological effects of social isolation can affect your immune system. The culprits are loneliness and stress.
Research shows that our anti-viral response is suppressed when we feel lonely.
Tell that to every opportunistic infection, which are quiet common.The immune system doesn’t work that way. It doesn’t get “used up”. If anything, it gets kicked into high gear. It’s not unusual for a bout of flu to also cause the immune system to finally take care of some other infection. Personally, I once had a wart that resisted all treatment, but sloughed off the first day I had the flu, never to return.
Unfortunately, it is not infection which gradually uses up the immune system, but anno domini. As those telomeres shorten, stem cells get less prolific, and even the craftiest of immune systems begins to run out of steam. Or the ability to produce plentiful foot soldiers. Although it seems an extreme interpretation to me, some people are claiming that the high power relationship of cancers to age comes more from a slow fall off in efficacy of immune surveillance and repression than from accumulated mutations producing more, and more highly transformed, early tumor cells. And yes under certain circumstances persistent infection can deplete the immune system. Surface switching parasites like sleeping sickness rely on that. By the third or fourth immunogenic switch the immune system is much weakened.The immune system doesn’t work that way. It doesn’t get “used up”. If anything, it gets kicked into high gear. It’s not unusual for a bout of flu to also cause the immune system to finally take care of some other infection. Personally, I once had a wart that resisted all treatment, but sloughed off the first day I had the flu, never to return.
I would guess that the strength of the immune response would be proportional to the total volume of mRNA, not the number of viral strains it protects against. Anyone who actually knows something care to weigh in?Well there is a broad spectum Flu vaccine in trials at the moment. It's mRNA but I guess we'll see what the trial says.
https://www.pennmedicine.org/news/news-releases/2022/november/penn-develops-mrna-flu-vaccine
Not that I'll be first in the queue.
Edit: should have said that it is showing promsie in animal models; human trials are being designed but appears to illicit strong immune response to 20 sub types of flu which were designed into the vaccine. There's for sure a bit of icky factor here, and I'm not sure I'd be brave enough to find out what an immune response feels like to 20 versions of flu - we shall see I guess.
While the immune system doesn't get "used up" it does loose effectiveness as we age. T lymphocytes undergo several maturation processes in a gland in the mediastinum called the thymus. The thymus is a bizarre little gland in that it grows from childhood into adolescence - and then gradually shrinks (atrophies) for the rest of your life. As we age, the maturation and training of new T lymphocytes becomes problematic and eventually stops.The immune system doesn’t work that way. It doesn’t get “used up”. If anything, it gets kicked into high gear. It’s not unusual for a bout of flu to also cause the immune system to finally take care of some other infection. Personally, I once had a wart that resisted all treatment, but sloughed off the first day I had the flu, never to return.
Personally, I find that 3 masks are sufficient.Don't ask these kinds of questions, there are plenty of experts on this site that will shame you for suggesting that not wearing a mask may help expose your immune system to other bacteria and viruses and therefore, make it a little stronger. If you ask 100 people how and why COVID spreads in relation to RSV and the flu, I guarantee you will get 100 different answers. Different viruses affect people differently. Some people seem to get sick all the time and others don't seem to get sick more than once or twice a year. Why?? NOBODY KNOWS OR CAN SAY FOR SURE WHAT THE REASON IS. But they will not stop reminding you to get your booster and wear 5 masks or you will die.
Annnd... now you have lost him/her. Now we are back to the "let's spit on each other" theory.Personally, I find that 3 masks are sufficient.
/s
Yes, different viruses affect different people differently. But as far as the reason some people get sick and some don't? It's complicated.
Virions are antigens, or antibody generating factors, that can mobilize antibodies. Thing is, each antigen can have multiple epitopes, or areas that can mobilize different populations of antibodies. One person's immune system might recognize one or two epitopes while person number two's immune system can recognize and mobilize twelve different populations of antibodies - all from the same virion antigen. Or their system might not recognize any of those epitopes. Some unlucky ones might not even be able to make antibodies to those epitopes at all if they don't have a naïve immunocompetent lymphocyte or three already hanging around in secondary lymphatic tissues. It's a bit of a crap shoot sometimes.
And then there's the idea that each different population may be at a different stage of response. Population A-F antibodies (arbitrarily named for epitope response) might be in a stacked secondary response with lots of B memory cells just waiting to kick ass, whereas populations G-L could be in the primary response and need a week to get their shit together.
We haven't even gotten to how antibodies actually do their thing, which depends on Ig class, binding affinity, titers, the state of your free macrophages, etc. And antibodies are only a small part of the overall immune system. There's several populations of leukocytes including PNKs, B and T lymphocytes (several subcategories each), and of course the entire passive side of the immune system of which interferon is part. /mild rant
Sure, it's complicated with literally hundreds if not thousands or interrelating variables. But complaining about wearing masks or vaccines is like bitching about wearing seat belts or having car insurance because it's literally too hard to figure out if you'll be in an accident on any given day. There's hundreds of factors involved there too, but most people don't throw their hands up and say that wearing seat belts is stupid or claim that wearing a belt is stupid because they knew a guy who died while wearing a seatbelt so obviously they don't matter.
