Hard to believe I'd ever rally for Iran... but I want that bratty orange bully humiliated! Yes, that means siding against my own country - but if that will finally cut the Republican fascists down - it's well worth it to me. Sigh...
Two things can be true and bad.Hard to believe I'd ever rally for Iran... but I want that bratty orange bully humiliated! Yes, that means siding against my own country - but if that will finally cut the Republican fascists down - it's well worth it to me. Sigh...
Isn't this rather a bad design? If your sprinklers stop the fire but destroy all the computers, what's the point?The document also detailed flooding and water damage from the activation of fire suppression systems
You're not siding against your country. You're siding against a fascist authoritarian who happens to run your country right now. Big difference. Your conscience should be clear.Hard to believe I'd ever rally for Iran... but I want that bratty orange bully humiliated! Yes, that means siding against my own country - but if that will finally cut the Republican fascists down - it's well worth it to me. Sigh...
Better than having the entire structure AND all the computers burned to the groundIsn't this rather a bad design? If your sprinklers stop the fire but destroy all the computers, what's the point?
Yeah I always thought datacenters used halon or other gases to get rid of the oxygen without dousing everything inside. I guess if it was a big enough fire or if there was a hole in the building (likely, given a drone strike), that wouldn't work.Isn't this rather a bad design? If your sprinklers stop the fire but destroy all the computers, what's the point?
They probably didn't account for a drone strike when they designed the system. Also OhNoAnyway.jpgIsn't this rather a bad design? If your sprinklers stop the fire but destroy all the computers, what's the point?
IIRC, the gas-based suppression systems have issues with the extremely loud noise of their activation causing head crashes in HDDsYeah I always thought datacenters used halon or other gases to get rid of the oxygen without dousing everything inside. I guess if it was a big enough fire or if there was a hole in the building (likely, given a drone strike), that wouldn't work.
Gone are the days of Halon, It's the structure that's been worth more. I've only seen a Halon system activate once. And that was when they used to glass window a room in a university to make the room look cool.Isn't this rather a bad design? If your sprinklers stop the fire but destroy all the computers, what's the point?
Counterpoint: I think the time period is more linked to the lack of safe transport of replacement parts and service personnel than the actual level of damage caused.The fact that AWS expects the full restoration of cloud services to potentially take half a year speaks to the damage inflicted by the Iranian drone strikes.
That's the least issue. It's traditionally datacenters were in rich countries with lawyers and when your fire suppression system outright can kill the worker. Issues can arise. Granted fire and water with electricity also isn't safe. But it's way slower than taking all the oxygen out of the air.IIRC, the gas-based suppression systems have issues with the extremely loud noise of their activation causing head crashes in HDDs
do you think fire stops after it's done burning all the computersIsn't this rather a bad design? If your sprinklers stop the fire but destroy all the computers, what's the point?
Is halon no longer a thing?Isn't this rather a bad design? If your sprinklers stop the fire but destroy all the computers, what's the point?
Fiber is extremely resilient. Shockwave will kill other components like large CPU dies first.What are the chances that tons of fiber was also shattered by explosive shock? There's probably a ton of damage that's not easily visible
Sometimes water sprinklers are required by local fire codes -- the last corporate server room I managed required water sprinklers. They had dry pipes and it was a "preaction" system where it took both a sprinkler head activation and smoke and/or secondary heat sensor to trigger the sprinkler heads.Isn't this rather a bad design? If your sprinklers stop the fire but destroy all the computers, what's the point?
I'm for the troops, I want them to not face harm for the greed of oil company execs pocket. I'm for troops, I want them to be able to rotate home to their loved ones, not spend the longest tour of duty since ww2 because our president wants to distract from his pedophile history. I'm for troops, I want them to be fed proper meals, not sub prison rations because we went into a conflict with zero preparation because the tail was wagging the dog.You're not siding against your country. You're siding against a fascist authoritarian who happens to run your country right now. Big difference. Your conscience should be clear.
They try this verbiage all the time... "You're against the troops." "You're not a true patriot." It's all BS to get you to just go along with the fascism.
There is something of a "I didn't think he's eat MY face" vibe to all this.So, Amazon, I guess handing out money to that guy ain't working out too well for ya?
/oh no anyway
That's a lot of smoke and damage from some debris.caused by debris after interception of a drone
Might I suggest anyone looking to relax this weekend take this opportunity to watch a magnificent video about someone making a rowboat out of Jeff Bezos' head?
View: https://www.youtube.com/watch?v=VGhcSupkNs8
Then we can feel like he has some kind of value to offer to world.
Yeah. After Iran's protest massacres, I could've theoretically gotten behind a principled and well-planned attempt at regime change, but it was never going to be principled or well-planned with Trump and Hegseth in charge. (Meanwhile, a Democrat wouldn't have gone in, and Republicans would've screamed bloody murder forever if they tried.)Two things can be true and bad.
1) Iran’s autocratic government is a repressive theocracy that sucks shit.
2) Invading sovereign nations you are actively negotiating with, for no genuine political objective or end goal, is how you kick off global instability and who knows, maybe a fucking world war?!
Bonus laughs: all the allied repressive theocracies that are goading the US into destroying Iran for being a regressive theocracy!
I see from other comments that these fire systems aren't generally set up to soak and ruin all the equipment, only the part that's actually on fire, so it seems like there is a middle ground between "burn the whole building" and "destroy all the computers with water."Better than having the entire structure AND all the computers burned to the ground
