Millen's time is the fastest for an EV, but still almost a minute off the outright course record, set in 2013 by nine-times World Rally Champion Sebastian Loeb and his fire-breathing Peugeot 208 T16 Pikes Peak
[url=http://meincmagazine.com/civis/viewtopic.php?p=29305821#p29305821:12c5127n said:amp88[/url]":12c5127n]Should be Drive eO PP03 (source).Rhys Millen took his Drive oE PP03 to the top of the mountain in 9:07.022, beating rival Nobuhiro "Monster" Tajima by more than 20 seconds.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29305877#p29305877:3bx4r905 said:neffo[/url]":3bx4r905]Interesting... a couple of things I noticed, for one they have a siren on the car (presumably for safety), and secondly it looks like the driver has his own oxygen supply. Is that normal for Pikes Peak runs?
[url=http://meincmagazine.com/civis/viewtopic.php?p=29305853#p29305853:yvof2d7z said:DinoosaurJones[/url]":yvof2d7z]A little off-topic, but if the race allows that much flexibility in technologies, what about a car that carries its own oxygen for the higher altitude bits?
I don't know how many vehicles have used a pure oxygen supply to increase the oxygen content going to the engine, but in the past numerous entries have used nitrous oxide.[url=http://meincmagazine.com/civis/viewtopic.php?p=29305853#p29305853:1mrx5ys2 said:DinoosaurJones[/url]":1mrx5ys2]A little off-topic, but if the race allows that much flexibility in technologies, what about a car that carries its own oxygen for the higher altitude bits?
It's not mandatory, but many (especially in the quicker machinery) elect to run with an oxygen supply. Interestingly, for an episode of a TV series (called Speed with Guy Martin) he took part in PPIHC, and won his class. Since he wasn't using an oxygen supply for the run, as part of his preparation he built a hypoxic cell in his house so he could control the oxygen content in the air to simulate the levels at Pikes Peak. To demonstrate the low oxygen content, they showed that a match would not remain lit once struck in the room. If you're outside the UK you should be able to watch the documentary here.[url=http://meincmagazine.com/civis/viewtopic.php?p=29305877#p29305877:1mrx5ys2 said:neffo[/url]":1mrx5ys2]it looks like the driver has his own oxygen supply. Is that normal for Pikes Peak runs?
[url=http://meincmagazine.com/civis/viewtopic.php?p=29305939#p29305939:28w4b71s said:ShuggyCoUk[/url]":28w4b71s][url=http://meincmagazine.com/civis/viewtopic.php?p=29305877#p29305877:28w4b71s said:neffo[/url]":28w4b71s]Interesting... a couple of things I noticed, for one they have a siren on the car (presumably for safety), and secondly it looks like the driver has his own oxygen supply. Is that normal for Pikes Peak runs?
According to Wikipedia cabin pressurization (or one presumes a regulated air supply) in an aircraft is required at 3800m, the top of pike's peak is reasonably well past that.
Given the effective ascent rate, and quite extreme physical and psychological exertions the drivers perform it doesn't surprise me that oxygen is supplied
[url=http://meincmagazine.com/civis/viewtopic.php?p=29305971#p29305971:2et07ui2 said:amp88[/url]":2et07ui2]I don't know how many vehicles have used a pure oxygen supply to increase the oxygen content going to the engine, but in the past numerous entries have used nitrous oxide.[url=http://meincmagazine.com/civis/viewtopic.php?p=29305853#p29305853:2et07ui2 said:DinoosaurJones[/url]":2et07ui2]A little off-topic, but if the race allows that much flexibility in technologies, what about a car that carries its own oxygen for the higher altitude bits?
It's not mandatory, but many (especially in the quicker machinery) elect to run with an oxygen supply. Interestingly, for an episode of a TV series (called Speed with Guy Martin) he took part in PPIHC, and won his class. Since he wasn't using an oxygen supply for the run, as part of his preparation he built a hypoxic cell in his house so he could control the oxygen content in the air to simulate the levels at Pikes Peak. To demonstrate the low oxygen content, they showed that a match would not remain lit once struck in the room. If you're outside the UK you should be able to watch the documentary here.[url=http://meincmagazine.com/civis/viewtopic.php?p=29305877#p29305877:2et07ui2 said:neffo[/url]":2et07ui2]it looks like the driver has his own oxygen supply. Is that normal for Pikes Peak runs?
That's why Bob Unser's still the king.[url=http://meincmagazine.com/civis/viewtopic.php?p=29305809#p29305809:bg2twrtv said:VidasDuday[/url]":bg2twrtv]Wait wut? The road is now paved?
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306077#p29306077:1nte87iw said:Shavano[/url]":1nte87iw]So I was looking at the car specs from the article "A 50kWh lithium-ion battery feeds those motors, giving the PP03 1,368hp (1,020kW) and 1,593lb-ft (2,160 Nm) at its disposal. "
At full power, it only has 50kWh/1020kW = 2.9 minutes worth of charge? But it took 9 minutes to do the course. Is the article wrong? Is it one battery per axle? One per wheel? Or did the driver have to carefully manage his power to make sure he didn't run out of charge before he got to the finish line?
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306077#p29306077:1ga86kje said:Shavano[/url]":1ga86kje]So I was looking at the car specs from the article "A 50kWh lithium-ion battery feeds those motors, giving the PP03 1,368hp (1,020kW) and 1,593lb-ft (2,160 Nm) at its disposal. "
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306027#p29306027:3bvksg71 said:Shavano[/url]":3bvksg71][url=http://meincmagazine.com/civis/viewtopic.php?p=29305939#p29305939:3bvksg71 said:ShuggyCoUk[/url]":3bvksg71][url=http://meincmagazine.com/civis/viewtopic.php?p=29305877#p29305877:3bvksg71 said:neffo[/url]":3bvksg71]Interesting... a couple of things I noticed, for one they have a siren on the car (presumably for safety), and secondly it looks like the driver has his own oxygen supply. Is that normal for Pikes Peak runs?
Most drivers would not have trouble going to that altitude that fast. The vertical ascent is only 4720 feet according to Wikipedia. The chance of altitude sickness in a person who lives at sea level is significant at 14,110 feet (end of the race). A person living at 5000-6000 feet as most Colorado people do is unlikely to have trouble. But if your driver DID have trouble, he'd be going over the side.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306241#p29306241:utz354wa said:BigAssRat[/url]":utz354wa][url=http://meincmagazine.com/civis/viewtopic.php?p=29306027#p29306027:utz354wa said:Shavano[/url]":utz354wa][url=http://meincmagazine.com/civis/viewtopic.php?p=29305939#p29305939:utz354wa said:ShuggyCoUk[/url]":utz354wa][url=http://meincmagazine.com/civis/viewtopic.php?p=29305877#p29305877:utz354wa said:neffo[/url]":utz354wa]Interesting... a couple of things I noticed, for one they have a siren on the car (presumably for safety), and secondly it looks like the driver has his own oxygen supply. Is that normal for Pikes Peak runs?
I have lived in Parker, CO for 15 years (5900ft above sea level), and I work out regularly, running 4 miles a couple of times a week. I still get headaches and a slight shortness of breath when when I go to the top of PP. I also snowboard, and don't have much issue at 10k to 12k. There is something magical about 14k though, at least for me. Also, I believe, while I haven't done any, the major difficulty of doing the 14'er peaks is the lack of air, especially when doing any kind of rigorous activity.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306291#p29306291:ohwca25i said:andrewb610[/url]"hwca25i]Electric Cars are great, but when it comes to the major issue they're supposed to help solve, they won't help until we can generate power in a cleaner way overall (and by 'we' I mean the world)
That being said, if you're going to do both things, obviously you need to do one first.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306111#p29306111:2i5mr5ra said:El Guapo[/url]":2i5mr5ra][url=http://meincmagazine.com/civis/viewtopic.php?p=29306077#p29306077:2i5mr5ra said:Shavano[/url]":2i5mr5ra]So I was looking at the car specs from the article "A 50kWh lithium-ion battery feeds those motors, giving the PP03 1,368hp (1,020kW) and 1,593lb-ft (2,160 Nm) at its disposal. "
The motors won't be drawing the full 1020kW the entire race. Once you are up to speed and not accelerating (in straight stretches) you only draw enough power to overcome aerodynamic drag, rolling resistance, and lifting the mass of the vehicle. You certainly won't be going WOT around every corner either.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306291#p29306291:jjo2eoxg said:andrewb610[/url]":jjo2eoxg]Electric Cars are great, but when it comes to the major issue they're supposed to help solve, they won't help until we can generate power in a cleaner way overall (and by 'we' I mean the world)
[url=http://meincmagazine.com/civis/viewtopic.php?p=29305813#p29305813:2im75yrh said:amp88[/url]":2im75yrh]Onboard of the winning run.
Interesting to note that the car dropped to half power before halfway through the course (listen to the interview at the end of that video; Millen claims it should have been 30 seconds faster).
360 degree video of part of a practice run.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306477#p29306477:90jlzsie said:Jeffro-Tull[/url]":90jlzsie][url=http://meincmagazine.com/civis/viewtopic.php?p=29306111#p29306111:90jlzsie said:El Guapo[/url]":90jlzsie][url=http://meincmagazine.com/civis/viewtopic.php?p=29306077#p29306077:90jlzsie said:Shavano[/url]":90jlzsie]So I was looking at the car specs from the article "A 50kWh lithium-ion battery feeds those motors, giving the PP03 1,368hp (1,020kW) and 1,593lb-ft (2,160 Nm) at its disposal. "
You're right, but have you seen Pikes Peak? 156 turns and 4,470 feet of elevation change. There's not a lot of straight line coasting going on in the climb.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306547#p29306547:7sduo9qn said:Errum[/url]":7sduo9qn][url=http://meincmagazine.com/civis/viewtopic.php?p=29306477#p29306477:7sduo9qn said:Jeffro-Tull[/url]":7sduo9qn][url=http://meincmagazine.com/civis/viewtopic.php?p=29306111#p29306111:7sduo9qn said:El Guapo[/url]":7sduo9qn][url=http://meincmagazine.com/civis/viewtopic.php?p=29306077#p29306077:7sduo9qn said:Shavano[/url]":7sduo9qn]So I was looking at the car specs from the article "A 50kWh lithium-ion battery feeds those motors, giving the PP03 1,368hp (1,020kW) and 1,593lb-ft (2,160 Nm) at its disposal. "
In racing there's no straight line coasting, period. However that doesn't mean you're on full throttle any time you're not on the brakes. The average power draw is going to be some lower percentage of maximum, depending on the nature of the track. An electric race car will normally recover a fair amount of energy through regenerative braking, but Pike's Peak is of course an unusual case, since it's so massively uphill.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306027#p29306027:1m9lk80x said:Shavano[/url]":1m9lk80x][url=http://meincmagazine.com/civis/viewtopic.php?p=29305939#p29305939:1m9lk80x said:ShuggyCoUk[/url]":1m9lk80x][url=http://meincmagazine.com/civis/viewtopic.php?p=29305877#p29305877:1m9lk80x said:neffo[/url]":1m9lk80x]Interesting... a couple of things I noticed, for one they have a siren on the car (presumably for safety), and secondly it looks like the driver has his own oxygen supply. Is that normal for Pikes Peak runs?
Yes, there is. The "lift and coast" technique has been a key fuel saving strategy for decades in motorsport.[url=http://meincmagazine.com/civis/viewtopic.php?p=29306547#p29306547:38wwji0k said:Errum[/url]":38wwji0k]In racing there's no straight line coasting, period.
In addition to what everyone else said, it has separate sets of motors for the front and back, so as road conditions change it may provide more power to one half and less to the other for maximum efficiency. Even at full open throttle the car may not actually be using 1MW. Then there's what's recovered from regenerative breaking, if any.[url=http://meincmagazine.com/civis/viewtopic.php?p=29306077#p29306077:3oprt56t said:Shavano[/url]":3oprt56t]So I was looking at the car specs from the article "A 50kWh lithium-ion battery feeds those motors, giving the PP03 1,368hp (1,020kW) and 1,593lb-ft (2,160 Nm) at its disposal. "
As a sea-level creature, I drove up Pike's Peak once on a cross-country drive for the experience. I think there was a warning about not proceeding without a half-tank of gas (since they were probably tired of tourists running out all the time.) This was before they paved the road so there was a sense of adventure, and the endless left-right turns start to get tiresome when you're also trying to sight-see.[url=http://meincmagazine.com/civis/viewtopic.php?p=29306321#p29306321:qdv9rk8g said:Mazzicc[/url]":qdv9rk8g]I happened to hike Pikes Peak on Saturday, and have now done 12 of the Colorado 14ers. At the trailheads between 9 and 11k, you can feel how quickly you get short of breath, simply by running to the bathroom when you get up there. Around 13k, my pulse never drops much below 90-100bmp, even if I'm not breathing hard.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306657#p29306657:2ohe7vnl said:amp88[/url]":2ohe7vnl]Yes, there is. The "lift and coast" technique has been a key fuel saving strategy for decades in motorsport.[url=http://meincmagazine.com/civis/viewtopic.php?p=29306547#p29306547:2ohe7vnl said:Errum[/url]":2ohe7vnl]In racing there's no straight line coasting, period.
Explain that to the 12- and 24-hour racers where pit stops matter.[url=http://meincmagazine.com/civis/viewtopic.php?p=29306795#p29306795:3gq79cnd said:Errum[/url]":3gq79cnd]Fuel saving isn't racing.
[url=http://meincmagazine.com/civis/viewtopic.php?p=29306809#p29306809:w8cad9ld said:dlux[/url]":w8cad9ld]Explain that to the 12- and 24-hour racers where pit stops matter.[url=http://meincmagazine.com/civis/viewtopic.php?p=29306795#p29306795:w8cad9ld said:Errum[/url]":w8cad9ld]Fuel saving isn't racing.
Your statement was "In racing there's no straight line coasting, period.", not "In competition at Pikes Peak there's no straight line coasting, period.".[url=http://meincmagazine.com/civis/viewtopic.php?p=29306795#p29306795:2je40eex said:Errum[/url]":2je40eex][url=http://meincmagazine.com/civis/viewtopic.php?p=29306657#p29306657:2je40eex said:amp88[/url]":2je40eex]Yes, there is. The "lift and coast" technique has been a key fuel saving strategy for decades in motorsport.[url=http://meincmagazine.com/civis/viewtopic.php?p=29306547#p29306547:2je40eex said:Errum[/url]":2je40eex]In racing there's no straight line coasting, period.
Fuel saving isn't racing, and in any case doesn't apply in a short duration time trial such is Pike's Peak.
