It’s hard to say definitively why nearly all of the major TV manufacturers (LG, Samsung, Sony) switched from calling their TVs from 4K to Ultra HD, but we have some guesses. As 4K makes the transition from “wildly expensive product of the distant future” to “regular consumer purchase,” 4K may be a bit hard to parse for the average customer.
Topevoli":7j0tu2wg said:When do we get uncompressed HD? Most "HD" Stations looks like utter crap. I shouldn't be seeing artifacts at the price they charge for cable/fios.
Not quite. Industry standards call for one added descriptor/adjective per generation. Next one would be the Limited Edition Ultra HD, followed by the Deluxe Limited Edition Ultra HD, and so forth. The TV you described would be an eighth generation unit if factored for Standard Definition and HD.Dilbert":b586h87e said:What will they call the next standard after that? Super Awesome Exclusive Deluxe Limited Edition Ultra HD?
mkuch90":2cevtd97 said:The problem I'm going to have with the transition to UltraHD / 4K is the required viewing distance is uncomfortable. I have a 55" TV and I need to be prohibitively close to be able to see the pixels.
http://www.marseilleinc.com/recommended ... resolution
Spungy":btxe2zel said:I still can't tell the difference between 720p and 1080p. My eyes are crap.
JTD121":16rcdyv8 said:Awesome. No one really cares, because there is no content, and the ridiculous re-tooling of all our infrastructure is just not going to happen nearly as fast as the ITU (or whomever) is bumping TV set resolutions.....
trappera":1sfriy0d said:I still prefer projectors...
TV's just take up to much space, even hanging on the wall.
I don't care all that much about quality after a certain point and projectors always seem to give me way more bang for my buck.
xryancat":kvl7l56w said:Ars wrote an excellent piece on 4k resolution TVs and the perceivable difference it has on movies and television last summer.
fizzlefist":3qg7fmgg said:Damn near impossible to see a difference between 1080p and 4k without having a large set and sitting far closer than you'd ever comfortably want to at home. When you're pushing the limits of what the human eye is capable of detecting, I think it's time to pack it in.
jdale":tg0yl07v said:mkuch90":tg0yl07v said:The problem I'm going to have with the transition to UltraHD / 4K is the required viewing distance is uncomfortable. I have a 55" TV and I need to be prohibitively close to be able to see the pixels.
Isn't the goal to not see the pixels? There is a distance beyond which you will not see the difference between 720 and 1080, and likewise a distance beyond which you will not see the difference between 1080 and 4K, but that's not about image quality, it's about getting value for expense.
We have the TV too far away, which has the result that the viewed image is smaller as a proportion of field of view, but it looks clear enough.
Topevoli":2ylde3s4 said:When do we get uncompressed HD? Most "HD" Stations looks like utter crap. I shouldn't be seeing artifacts at the price they charge for cable/fios.
cervier":1osnr7s6 said:VashTheStampede":1osnr7s6 said:We need more than just higher resolutions for TVs. The Hobbit is being shown at 48FPS, while Avatar sequels will be 60FPS. People *can* see the differences and many will prefer the higher frame rates on their programming.
Whatever the updated delivery mechanism (physical or streaming) to these higher resolutions should also include higher frame rate possibilities as well.
I thought that human eyes were not able to see the difference with framerate over 25-30 fps? In the case of the Hobbit I think the 48 fps is for 3D.
