This is the type of thing I want to see generative models used for, not chatbots or social media garbage or "art".
Something like this has to take far less energy and input to train because of the specific problem area, why is it so hard to get money flowing to this research?
The thesis lately is that the government should be funding little to no research and that private companies are motivated to do all of this, this seems like an area that even a few hundred million dollars has the potential to significantly impact potential developments and drive actual solutions.
Spending tens of billions of dollars on "AGI" or hypergeneralized models. Seems like it would be better focused and spent on hyperspecific problem spaces.
Maybe I'm wrong, I dunno
-I- meant all the plastic. Frankly I consider it a win.We told AI to clean up the plastic… we didn’t mean ALL the plastic
Nothing wrong with that approach at all. In fact, if the result is repeatable and useful in something other than a lab setting, it may be this AI project to the punch. But they are complementary approaches.So... whatever is wrong with using fungus? Too slow?
https://www.sciencealert.com/scient...can-break-down-tough-plastic-in-just-140-days
To be fair, research IS benefiting from everyone chasing chatbots.This is the type of thing I want to see generative models used for, not chatbots or social media garbage or "art".
A few years ago this article would have used ML instead of AI, and in my mind ML would still be a better fit. I'm not quite sure how forcing the AI to learn to go back a workable state is "generative AI" of the sort I normally think of as "Generative AI". Sure, this generates results, but so did any original ML algorithm. Random trees generate outputs, so is it a generative AI? The use of AI rather than ML, and especially generative AI, feels like more buzzword use rather than accurate description (but that's without reading the original paper).Of the 129 proteins designed by this software, only two of them resulted in any fluorescence. So the team decided they needed yet another AI. Called PLACER, the software was trained by taking all the known structures of proteins latched on to small molecules and randomizing some of their structure, forcing the AI to learn how to shift things back into a functional state (making it a generative AI).
To do that you'd need to make the precursor toxic to the bacteria, to "incentivize" it to clear it as quickly as possible. That's probably possible to do, but then the precursor wouldn't be polyester any more and the resulting enzyme might not be useful.-I- meant all the plastic. Frankly I consider it a win.
I'm with John here - the next obvious step is to encode it into some bacteria and do some forced evolution to really crank up the variations on the novel enzyme. Seems like a great way to get the small optimizations once the gross design is done.
Yesterday I watched a "Veritasium" video, "The Most Useful Thing AI Has Done", about using AI to design enzymes and proteins ... and I was both fascinated and scared by what might come of all this.This sort of development has "unintended consequence" written all over it.
Industrial scale mushrooms are a problem. Not insurmountable, but difficult. Industrial enzymes are also a problem but different ones.Thing is we could literally use mushrooms to eat plastic (see my previous post), basically free and it won't cost the trillions invested in Ai.
The only downside us that the plastic eating mushrooms are slower the upside is price and the fact thar under the right weather conditions you can set those plastic eating mushrooms anywhere.
There are hundreds, more likely many thousands, of enzymes which do this with a single protein. The basic chemistry is very simple, but the details are complex. The biggest problem for unnatural substrates is having the enzymes actually recognizing the molecules they are supposed to catalyze a reaction of. This is particularly true for plastics, which are long polymers, usually of very low water solubility, and from the perspective of enzymes largely featureless. A multi-enzyme complex would make the chemistry steps more complex, and you would have to get the various component enzymes to recognize one another. There are many such enzyme complexes in nature, but they are usually doing something much more sophisticated than simple ester hydrolysis.Curious whether it would work just as well to design multiple enzymes to facilitate that 4-step process. One "do it all" enzyme seems out of reach, but perhaps 2 enzymes can work together similarly? Maybe the amount of work to do that is the same or even more than trying to design the single enzyme...
Ok, sure. But where are all the enzymes that this 'old' process kicked out? Genuinely curious since Google, at least, has been trying to figure out how to make enzymes on demand for some time. And even if the 'old' system worked, perhaps the LLMs would do better? No idea, not in my wheelhouse. Not even the same boat. But different approaches to the same problem are often useful.A few years ago this article would have used ML instead of AI, and in my mind ML would still be a better fit. I'm not quite sure how forcing the AI to learn to go back a workable state is "generative AI" of the sort I normally think of as "Generative AI". Sure, this generates results, but so did any original ML algorithm. Random trees generate outputs, so is it a generative AI? The use of AI rather than ML, and especially generative AI, feels like more buzzword use rather than accurate description (but that's without reading the original paper).
Oh, just give it a few billion years.......There are hundreds, more likely many thousands, of enzymes which do this with a single protein. The basic chemistry is very simple, but the details are complex. The biggest problem for unnatural substrates is having the enzymes actually recognizing the molecules they are supposed to catalyze a reaction of. This is particularly true for plastics, which are long polymers, usually of very low water solubility, and from the perspective of enzymes largely featureless. A multi-enzyme complex would make the chemistry steps more complex, and you would have to get the various component enzymes to recognize one another. There are many such enzyme complexes in nature, but they are usually doing something much more sophisticated than simple ester hydrolysis.
According to that article:So... whatever is wrong with using fungus? Too slow?
I just think that machine learning is a better, less loaded term.A few years ago this article would have used ML instead of AI, and in my mind ML would still be a better fit. I'm not quite sure how forcing the AI to learn to go back a workable state is "generative AI" of the sort I normally think of as "Generative AI". Sure, this generates results, but so did any original ML algorithm. Random trees generate outputs, so is it a generative AI? The use of AI rather than ML, and especially generative AI, feels like more buzzword use rather than accurate description (but that's without reading the original paper).
A bit of both. Yes, there are organisms that can use their existing enzymes to digest plastics, but that may require using the whole organism in order to retain the activity, which might not be optimal for industrial scale processing. Live bacteria as used in bioreactors, for example, require care and feeding beyond simply chucking in finely ground pop bottles. A single enzyme that doesn't require much else in order to function (maybe a buffer and a controlled temperature) simplifies things considerably, as long as you can produce it in the required quantities.According to that article:
“More than 400 microorganisms have so far been found to degrade plastic naturally, with fungi attracting a fair bit of attention for their versatility and ability to degrade all sorts of synthetic substrates with a powerful concoction of enzymes.”
Yet in the Ars article:
“Unfortunately, there isn't an enzyme for many reactions we would sorely like to catalyze—things like digesting plastics.”
So which is it?
The fungi that can process plastics likely use a multi enzyme pathway, probably attached to a cell membrane to work. And, being fungi, the process is slow (they don't care, they don't have to). Doing a quick search about molecular mechanisms of fungal plastic degradation doesn't yield anything I can either read or access (anybody got some references?). My WAG is that fungal biochemistry isn't well studied* and the particular metabolic pathways even less so.According to that article:
So which is it?
The advantage of doing this step by step outside an organism is you can (probably) control it. You don't have to make CO2, maybe CH4 (which is useful) or octanol or butanol or whatever. We're pretty far away from this but if you can control the enzymatic pathway with that degree of precision, the world is your oyster. Or hydrocarbon.Something like:
We finally decomposed all the hydrocarbons in our landfills!..
And released gigatonnes of CO2 in the process..?
The answer is profits.This is the type of thing I want to see generative models used for, not chatbots or social media garbage or "art".
Machine learning is Artificial Intelligence and Artificial Intelligence is Machine Learning.A few years ago this article would have used ML instead of AI, and in my mind ML would still be a better fit. I'm not quite sure how forcing the AI to learn to go back a workable state is "generative AI" of the sort I normally think of as "Generative AI". Sure, this generates results, but so did any original ML algorithm. Random trees generate outputs, so is it a generative AI? The use of AI rather than ML, and especially generative AI, feels like more buzzword use rather than accurate description (but that's without reading the original paper).
What doesn't at this point?This sort of development has "unintended consequence" written all over it.
