Aww man, it’s ok to call him out on it, but don’t drag Doritos down with him!lol what a classic armchair response.
1. Read headline and a few words from the intro
2. Recognize something you're vaguely familiar with
3. Remember something you heard the words you recognized in step 2
4. Drop a "well achksually" in a sad attempt to look smart.
Were you eating doritos while you wrote this drivel?
Don't answer that, I don't care.
Yeah I got myself an oil siphon and the top mounted filters on the TDI were great for easy changes. No need to get under the car.Real world me: how accessible is the oil filter? Is changing my oil going to be annoying?
Looking at the about us page, I do not think they can just do this themselves easily.It's a great design that is held back by their insistence on licensing it instead of producing it. They're hoping manufacturers will gamble on their engine.
I always really wanted an RX-8 in college and thought I'd buy one when I graduated and got a real job.
Instead I kept my 2002 Saturn until 2015 and then bought a Subaru because it was more practical.
Younger me: omg I want a cool car
(Answer, on a Subaru, the filter is right there when you open the hood. Fuck removing quarter panels to change your oil)
Correct, but there's no more seal to maintain. Hence, increased efficiency and no more required rebuilds after some number of miles (in a car context). That's a meaningful improvement.
While cool, it really messes up one of my favorite explainers for how rotary engines work. (I still would like to drive an RX-7 or RX-8 in anger someday.)
They have been working on it for a while, and can produce in some small volume, but that is not a huge manufacturing facility. They probably do not have that kind of expertise (or money).
The idea is a good one, and the cycle should be efficient in a few ways, but competing engines have seen a very large amount of refinement in general. It still will not be easy to bring this to market, especially for something with reliability requirements like a passenger vehicle.
Most modern submarines are moving to pumpjets. They're actually less efficient, but they significantly solve the cavitation issue.First thing that comes to mind are submarines. Their biggest thing is noise. They actually move slower than they are capable due to cavitation, and other similar things around noise.
There is a huge space of possible engine designs that have not yet been explored. A great many more possible designs were explored in the early days of engine design, but either failed to catch on, or died out entirely. When was the last time you saw a Napier Deltic engine, or anything with sleeve valves?Surely every imaginable geometry has been tried in the last 150 years of internal combustion engine development. There has always been a demand for lighter, smaller, and more fuel-efficient engines. Is there more to this than just a novel chamber and rotor? If it's so good, why wasn't it done long ago?
Boats would be a good market, especially if it's multi-fuel and can sustain continuous-duty operation. When the engine gets installed and rigged before the deck and superstructure are added, it's easy to forget about the importance of access....Now I'm salivating over the idea of replacing the engines in our boat with something substantially smaller yet equal in power. Pleasure craft engine compartments are seemingly designed to be about 80% the size of the engines they cram in there. Things like replacing spark plugs or even adding oil require being a contortionist and doing things by feel alone. Looking at the size differential in the story photo, doing any work on that engine would be a breeze.
Of course, boat manufacturers will immediately reduce the engine compartment size to compensate and be right back to forcing people to be double-jointed. But existing boat owners will definitely rejoice.
Exactly what I was also curious about. Seems like you can have any number of chambers, why did they choose three?What about a three-lobed piston in a four-lobed chamber? Would it make it better or worse?
With two rotors, you just invert one. Have the intakes on the ends, and a common exhaust in the center. With more than two, you would need a significantly heavier side-ported shaft, and a plenum to feed it.Can they stack-connect? Like a 2 or 3 wankle/rotary, can these be nested in pairs or more? or does the intake/exhaust limitation mean...no?
Modern US Navy submarines do. Royal Navy submarines have been using them for, well, decades longer, and a lot of torpedoes used them long before that.Modern submarines use pump jet propulsion not traditional screws.
It sounds like they're trying to get around this by getting funding for manufacturing from DARPA, which gives them a relatively low-risk way to build a manufacturing base and not dilute their ownership by issuing stock. Not a bad start-up method (albeit slow), presuming your employees don't revolt over working for the military.It's a great design that is held back by their insistence on licensing it instead of producing it. They're hoping manufacturers will gamble on their engine.
That's where most radically new engines die. Getting it to work on the bench is hard and expensive. Getting it to work for 8,000 hours under real-world loads without self destruction is obscenely hard and absurdly expensive.I've seen this a year... or maybe more ago?
They certainly have some great ideas that should make the rotary better. But it looks like they're still in the "get funding" stage. Unfortunately with a lot of engine designs, you can only really tell if it's any good when the rubber hits the road, so to speak.
Run a dozen of them for 100,000km in real conditions and let's see what happens. Things that should have been solved can turn out to not be, and new issues will pop up. Nobody tries to make a bad engine but even major manufacturers screw up basic I4 deigns.
Novation Analytics figured that Nissan's VC-Turbo variable compression scheme was good for an 11% improvement in fuel economy in the QX50 versus a fixed-compression equivalent.Nissan and Mazda themselves had some really cool ideas with variable compression ratios and and compression gas engines, they did make it into production and seem to actually work, but yet they haven't taken over. In reality the benefit might not be worht it. I do hope it works great, of coure. Just been burned before.
The RX-7 is a lot of fun to drive. Light, perfectly balanced, rear wheel drive. Unfortunately, it doesn't produce much horsepower unless it's in the top half of the tachometer. And even then, only maxes out at 180ish for a '87 turbo. Also, I found it's not very forgiving if you don't correct oversteer quickly (at least, that what my ham-handed driving skills found).While cool, it really messes up one of my favorite explainers for how rotary engines work. (I still would like to drive an RX-7 or RX-8 in anger someday.)
yeah, this thing has both apex seals and face seals, but since the apex seals don’t have to traverse the open port holes as in a traditional wankel, apex seals will wear less. The problem still remains with the face seals though. So, this engine is likely to be less reliable long term compared to a regular piston engine but probably quite a bit better than a traditional Wankel.Its not that there are no seals. Its that the seals are now in the engine housing instead of in the rotor. Getting oil to the rotor (and out the seals mounted there) was very tricky. Getting oil to the seals in the engine housing will be easier and more-efficient.
HOWEVER, the seals will still be a wear item and there's no way to avoid some oil-burn due to the arrangement of seals swiping across the "piston" surface. Of course, typically reciprocating engines also have a little bit of oil burn (as the oil-control rings on the sides of the pistons allow a little bit of oil to leak by). The question is whether the seal wear and the oil-burn are both low-enough (and the new shape's compression-ratio & thermodynamic efficiency high-enough) to make it competitive with small reciprocating engines.
This X-engine is probably rpm limited, the article is silent. But the low hp test variants are telling. It is pollution constrained in the article. Small 8% efficiency is 0 benefit .v. BEV. It’s that 75% weight reduction that’s its real MVP, as you surmise.Not sure how relevant this is for cars, but improving generators may be HUGE. I'm not quite clear about what the actual improvements will be. Hopefully, it will at least be lighter and cleaner.
We just had our fourth 8-hour power outage of the year, and it's just the beginning of outage season. Dealing with a traditional generator is a PITA, even though they have improved.
I also miss my RX-8, and largely for the same reasons.I had an RX-8. It was a blast and surprisingly capable. The weight balance was perfect and you could toss it around super easily. I miss it somewhat regularly. I don’t miss the maintenance and the terrible fuel economy.
Even a low-RPM Stirling?Any combustion engine, including this one, is really noisy.
Marine engineer here...These seem like a great idea for large ocean-going ships with slow-speed direct-drive engines (no gearbox.) Most other commercial vessels use variable-pitch/constant speed propellers, which to me look fundamentally incompatible with the toroidal design. These have two major advantages; they dramatically reduce the complexity of the gearbox and clutch (no need for a reversing gear), and they allow allow ships to make electricity from a simple PTO off the main reduction gear driving a generator. (WToroidal props blow me away. How many item designs have been fully overlooked like props? And how large do they scale? It seems like they should be retrofitted to every ship out there if the gains work out on large industrial props.
I expect putting the seals in the housing means you could make much taller seals, with a longer wear life before needing replacement.Its not that there are no seals. Its that the seals are now in the engine housing instead of in the rotor. Getting oil to the rotor (and out the seals mounted there) was very tricky. Getting oil to the seals in the engine housing will be easier and more-efficient.
So the key is that the ignition is still in 3 places, and the inside still rotates, it's just oval and the outside is triangular, so it's inverted. I don't see why this is considered 'stationary' except perhaps with a Wankel, did it detonate anywhere along the inside of the oval, then? I don't think so, the spark plugs were still in fixed spots.
The video is brilliant, in fact, very clear. I'm just struggling with the explanation to see if I'm missing something. It looks like they changed the shapes, nothing more?
It's all fun and games changing the oil filter on a Subaru, but god forbid you want to change a bog-standard headlight. At least on the Outback, you're fumbling around up to your shoulder through the unbolted plastic liner of the f'ing wheel well from underneath. To change a regular low-beam. WUfff.I always really wanted an RX-8 in college and thought I'd buy one when I graduated and got a real job.
So who put their money on post #57 for the "ICE are a dead end, the world is burning" non-sequitur?
Way too many modern cars need you to remove the whole bumper to change a light.It's all fun and games changing the oil filter on a Subaru, but god forbid you want to change a bog-standard headlight. At least on the Outback, you're fumbling around up to your shoulder through the unbolted plastic liner of the f'ing wheel well from underneath. To change a regular low-beam. WUfff.
Elsewhere, there's an i between the u and the d.On the left, LiqudPiston's High Efficiency Hybrid Cycle engine
How sure are you he wasn't saying "sealing" surface?metering tiny amounts of oil... right to the ceiling surface," Shkolnik said.
Toroidal propellers are beautiful, aesthetically pleasing pieces of engineering, that are even more satisfying on a fuel cost analysis spreadsheet than they are to the machinist's eye.Marine engineer here...These seem like a great idea for large ocean-going ships with slow-speed direct-drive engines (no gearbox.) Most other commercial vessels use variable-pitch/constant speed propellers, which to me look fundamentally incompatible with the toroidal design. These have two major advantages; they dramatically reduce the complexity of the gearbox and clutch (no need for a reversing gear), and they allow allow ships to make electricity from a simple PTO off the main reduction gear driving a generator. (W
My 1988 RX-7 also got 16 mpg. Loved the car otherwise though.I also miss my RX-8, and largely for the same reasons.
I also don't miss constantly feeding it oil and only getting 16mpg no matter how I drove it lol.
I got popped in the RX-8 on the expressway one time doing triple digits (I was admittedly being dumb but there were no other commuters around at the time). I was sure I was going to jail that afternoon but I got off with a failure to obey a traffic control device and a stern lecture. To this day I'm not sure why he let me go.My 1988 RX-7 also got 16 mpg. Loved the car otherwise though.
Also got a speeding ticket for the record books with that car. Bought a boring car after that.
