As temperatures rise, some creatures pick fights while others struggle to learn.
None of this negates the results of the study, nor do they establish your claim, without any study of your own, that heat does NOT muddle thinking.Yes, we adapt to heat, and those are among the ways we do it, but not the only ones.
In the '80s I worked with a Somalian girl and I remember noticing how when hot May weather had Irish people staggering around in their shirts gasping for air and babbling about the excessive heat (it would probably have been all of 28C) she would still be wearing her woolly jumper. It's not genetic - or not much - lots of people from Africa wear similar amounts of clothing at the same temperature as the Irish. She was just used to heat. [Granted she was tall and thin, which is arguably adaptational - but tall thin people exist in every climate.]
Thanks for this! I was wondering that myself, so you saved me some trouble.I couldn’t tell from the article if in hot weather they became equally scared of both items, or just became equally less scared of both the genet and the box.
I looked at the research paper so you don’t have to, and it appears to be the latter. Due to the heat, they became less reactive to both items.
The authors speculate that vigilance and reacting also has an energetic cost, which is more difficult to sustain in hot weather. So it might be that, or the impact on the brain from the heat, or a combination of both.
They are already, they are doing it Insitu while he's in office...Are there there plans to further research Florida Man?
Ironically, your high intelligence has failed to recognized that the equatorial regions actually tend to be milder than the temperate regions, since they lack the significant day/night duration differences that go with seasonality. Summers in the temperate zones get hotter because they spend more time under direct sunlight and less time in the dark, whereas equatorial regions remain at evenly distributed day/night durations.I don't like how your post (and others in this thread) also implies that people in countries closer to the equator, who are predominantly black and brown, are stupider than people in countries towards the poles, who are predominately white. Or are you intentionally saying things like, for example, Somalians are stupider than British?
There's an old legend of a time way back when there was a heat wave on the plains. It got so hot that corn on the stalk in the fields began to pop. All the white fluffy popped corn coated the ground around the fields and pastures, the local cattle thought it was snow and many of them froze to death.I 100% relate to this. When it’s too hot for me I can’t even do 1+1. My brains just freezes, of all things.
Do they have any teeth left? Is this how it’s served regionally?A common misconception. It's actually caused by the nauseatingly high volume of sugar in the five gallons of sweet tea they drink each day.
It’s pretty hard to have a lot of economic activity when you’re limited to the banks of the Nile and a couple coastal regions.There is some research on this. I am not familiar with it. I found this paper from a search.
https://pmc.ncbi.nlm.nih.gov/articles/PMC9616493/ Globally unequal effect of extreme heat on economic growth (published by NBER)
https://www.nber.org/papers/w21119 Goldilocks Economies? Temperature Stress and the Direct Impacts of Climate Change (published by NBER)
I remember seeing that most economic activity on Earth is in the temperate zone, but I don't have the source, and this is more of a hypothesis than a theory because there are counterexamples that aren't explained (although it seems to be mostly true).
Say what you will about the southern end of the US (and I have a lot of unkind things to say), I do appreciate that they distinguish between Iced Tea (served plain) and Sweet Tea. As opposed to the North and Canada where all iced tea is assumed to be at least a little sweetened.A common misconception. It's actually caused by the nauseatingly high volume of sugar in the five gallons of sweet tea they drink each day.
There is a hypothesis for why the USA southeast is at the bottom of basically all quality of life metrics in the USA because of bad climate: hurricanes, tornados, heat and humidity. Catastrophic weather events destroy infrastructure more often than other geographies, resulting in the area constantly trying to catch back up. Life expectancy from East Texas to the Carolinas is almost 10 years lower than the Northeast, Midwest or West coast because of it.Is this why most Americans in the south are so stupid? It might also explain why most of the people in Queensland, AU are also stupid.
Please elaborate. Is the 1:10, sugar to tea-water ratio? If so, do you account for ice by making it a stronger concentration?Note: the proper way to drink sweet tea is about a 1:10 ratio in my not-so humble, non-Southern Floridian brain. Ask any Southerner: only north Florida is part of the South. In my Floridian opinion more than 1:10 ratio is icky!
Only at noon. The sun always spends most of it's time at an angle from the vertical. And in the temperate zone in the summer, the sun spends more time at a high angle.Torrid and frigid zones misnamed? [Edit: and of course temperate] I think not.
You forget that even if the days are shorter in the tropical summer, the sun is more directly overhead.
That's true, but humidity is so variable across landscapes that it's hard to form generalizations. The grassy plains of equatorial east Africa, where humanity evolved, has low humidities, which is why sweat cooling and hairless skin is so effective there. The temperate Deep South of the United States suffers both sweltering heat and debilitating humidity at the same time. The Southwestern Deserts can be even hotter, but as they say, it's a dry heat, and that does make a notable difference.Temperatures quoted without humidity levels fail to account for various creatures responses. Having walked in the deserts and jungles on the Equator in South America, live in both Florida and New Hampshire, and grew up in UK, I can attest to the fact that the temperature alone does not define how our bodies react. Of course I understand why, but it seems many don't.
Most of the Earth's landmass is in the temperate zone. That's all the explanation you need.There is some research on this. I am not familiar with it. I found this paper from a search.
Oh it's 1 part sweet tea:10 parts unsweet tea.Please elaborate. Is the 1:10, sugar to tea-water ratio? If so, do you account for ice by making it a stronger concentration?
Wait, I'm confused. Are you making let's say 11 parts of unsweetened tea, then separating out 1 part to boil saturated sugar into (essentially creating a tea-syrup), then remixing the sweetened tea back into the other remaining 10 parts? Would it not be easier to just make one batch and boil the correct amount of sugar into it?Oh it's 1 part sweet tea:10 parts unsweet tea.
As far as the ratio of sugar: no idea. Typically you heat the tea and add sugar till it almost stops dissolving, and then cool it.
Yup.Wait, I'm confused. Are you making let's say 11 parts of unsweetened tea, then separating out 1 part to boil saturated sugar into (essentially creating a tea-syrup), then remixing the sweetened tea back into the other remaining 10 parts? Would it not be easier to just make one batch and boil the correct amount of sugar into it?
Australia seems to have the same range of temperatures as the same latitudes in Africa and South AmericaHere's a graph of global mean daily temperature by month, year round: https://openclimatemap.org/
Australia punches above its weight for a high latitude country, but I think it's obvious that the highest monthly temperatures are mostly found in the tropics. Not just the highest year round average.
The angle is quite a bit higher for much of the day. Outside the tropics the sun is never directly overhead.
That's a nice map, and it really is illustrative. One thing I miss on it is a latitude scale. The first thing I notice is that the actual equatorial temperatures do stay pretty mild all year long. They never rise to the extremes seen either in the far tropics or the lower temperate zones. Maybe I'm jaded from living in the desert, but I'd hardly call temperatures in the upper 70s to low 90s F "torrid." Looking at July temperatures in the northern hemisphere, where the highest temperatures occur is in the desert regions of the Sahara, the Arabian and Indian deserts, and even further north in the U.S. Southwest. In fact, the highest temperatures of all, in Iraq just north of the Persian Gulf, occur at a latitude of near 31º N, well above the Tropic of Cancer. In the Southern hemisphere, in December and January, the highest temperatures occur in the Sahel region of Africa, which interestingly enough is north of the equator, and in far western Australia, which is near the southern limit of the Tropic of Capricorn.Here's a graph of global mean daily temperature by month, year round: https://openclimatemap.org/
I'm the same (i grew up in Oklahoma) and those 100 degree days were killers. I do like the cold though. Now my dad is the opposite. If it gets below 70 he's complaining about the cold. If it's above 90 he wants to go outside and do things. I swear he wanted to kill me as kid in the summer.I handle heat extremely poorly, always have; I can't think straight, I can't focus even the little I normally can and I'm pissed as a bear that got shot in the bum. I basically just completely shut down every summer until my husband and I moved to our current home and got an AC. 23°C is already too much for me.
I assume my inability to deal with heat stems from autism, but I can't say for certain.
The lesson here, I think, is that sun angle is probably just a secondary influence on temperature. Cloud cover, humidity, and air currents from the oceans or the near-polar regions play a greater role as long as the latitudes are not too extreme. But in general, except in a few regions, I don't see much concern about temperatures frying the brain, and where they do occur, it's generally not at the equator.
The highest temperatures ever recorded on Earth occurred at Death Valley, Latitude 36.4º N, Kuwait, 29.5º N, and in British Palestine in 1942, at roughly 32º N. None of these are in the tropics.
I prefer adding sweetener (in limited amount, often as part of lemonade), to taste, to my unsweetened tea, rather than trying to dilute something that's already 1/2 corn sweetener to a drinkable concentration. The titration just seems to work a little better than way.Please elaborate. Is the 1:10, sugar to tea-water ratio? If so, do you account for ice by making it a stronger concentration?
Thank you! All I remembered about that one was the first line.Mad dogs and Englishmen go out in the midday sun.
The Japanese don't care to, the Chinese wouldn't dare to,
Hindus and Argentines sleep firmly from twelve to one,
But Englishmen detest a siesta,
In the Philippines there are lovely screens,
to protect you from the glare,
In the Malay states there are hats like plates,
which the Britishers won't wear,
At twelve noon the natives swoon, and
no further work is done -
But Mad Dogs and Englishmen go out in the midday sun.
