Apple supplier says new tech has 100 times the capacity of its current batteries.
30% might be achievable under ideal conditions, but gasoline motors generally only reach peak efficiency at one speed and load. In practice, it's going to be a lot less efficient than that.I would also add, that while ICE engines are about %30 efficient for motion, they also give 'free' heat using a few percentage of the wasted 70% heat, so on cold days when you are running the heat anyhow, technically the efficiency might end up being more like 35-40% (depending on how cold it it/how high you are running the heater) overall, because heating the cabin and windows, melting ice, etc is making use of that energy.
For reference, gasoline has about 9,000 Wh/l.
Which is an utterly useless comparison given the technology is intended to be used in small batteries for electronics.
Honestly, every article about new battery tech should be required to come with a spider graph like this one:Do I believe them? Yes. But I also believe there are negative tradeoffs they are not mentioning. There are so many battery performance factors to balance to make a worthwhile commercial battery, and almost any time somebody claims a huge jump in a single one, they are decreasing other important ones.
The process of taking dead dinosaur juice from caverns under the sea, getting it on shore, processing it, delivering it to a readybuilt distribution point for consumers to fill up their cars has been happening for so long, that nobody really thinks about the complexity of it.It's also extremely difficult to recharge.
I don’t understand.I was in a delightful discussion at a pub, about how everything is cyclic. And while the curious was asking how so, I said, "well, we had electric cars at the turn of the century, but the failure of acceptance was the battery or lack of reliable technology and chemistry. And then the combustion engine with cheap fuel and monopoly of car maker, tire maker and gas company would end any further pursuit. "
Of the 4 cycles (a) air fuel mixture in, (b) air fuel mixture compress, (c) combustion, (d) exhaust, only (c) gives any motive energy output (Force x distance = J). The distance is set by the compression ratio ( e.g Prius 14:1).Good point!
And just to clarify, I did not mean to say these advances are hopeless, just pointing out what competition battery tech is up against. Or, from a more positive perspective, what kind of energy density is possible. Taking efficiency into account like you did, I guess we are getting there.
With 3000Wh/l usable via internal combustion engines ;-)For reference, gasoline has about 9,000 Wh/l.
While I agree that I'd rather be hit by a 3-4k pound object than one that is 6-9k pounds, if I had to choose between just those two options, that does feel a bit apples-to-oranges.Reducing the weight has the benefit of lowering the harmful impact in a crash. I'd much rather be hit by a vehicle in the 3,000-4,000-lb range than one in the 6,000-9,000 lb range. (of course, I'd rather not be hit at all) All other safety factors being equal, lowering the weight can help the physics in a crash.
Yes, but gasoline isn't rechargeable.For reference, gasoline has about 9,000 Wh/l.
Still, it's quite impressive to see a battery possibly get less than one order of magnitude away from this!For reference, gasoline has about 9,000 Wh/l.
One potentially big savings from less weight in electric cars will be better tire longevity. Current EV burn through tires very fast. My nephew has a Rivian truck and his last set of P-Zeros lasted 20K miles. My friends with Teslas say it's about the same for them.Most of the energy loss in an EV is air drag, which depends on size but not weight. Making the car lighter reduces the energy needed to accelerate but also reduces the energy recovered by the regen braking proportionally so the gains aren't so large like they are with ICE vehicles where all the extra weight is directly wasting energy.
If you want longer range what you need is cheaper batteries. That or to be more wealthy so you can buy a bigger battery pack. But ideally cheaper, even if they don't get lighter.
It's 100x more than their currently in-production battery. TDK's competitors have fielded(?) the 50wh/l batteries. I had to re-read that paragraph a couple times before grokking the difference, though.I’m confused how 1,000 is a hundred times more than 50.
Hand-cranked by orphans is about as artisanal as it gets.How do you source your artisanal electricity that isn't dead-dinosaur powered?
in OP's defense, this overloaded it tripped me up for a moment:2.5x.
20x. And the 50 is their competitors. Their own old tech is 10, apparently.
2020 was when their old tech came out.
which is about 100 times greater than TDK’s current battery in mass production. Since TDK introduced it in 2020, competitors have moved forward,
EVs are indisputably the way we need to go, however, in a big and diverse country like the US, 400-450 miles is plenty of range for ICE vehicles because fueling stations are ubiquitous and reliable. That's not the case for charging infrastructure yet, so vastly increasing the range with new battery tech would be a game-changer for people who are challenged by the current state of charging infrastructure, whether because of geography, or people living in high-density housing where charging at home isn't feasible. This becomes less of an issue if a vehicle could go 900 miles between charges, for example.“Industry experts believe the most significant use case for solid-state batteries could be in electric cars by enabling greater driving range.”
industry experts are clowns. The goal is to make vehicles lighter. Today, batteries add a lot of weight to the car to get to 400miles range. If you could reduce that weight by 50 or 75% you’ll have improved vehicle performance. Most gas cars have a range of 400 miles, so EVs at 400-450 miles is plenty - weight is the big issue today.
Er, they are trying to get the cheapest usable wh/$ possible. Density is one part of that, because it enables more use cases, which means higher demand and therefore higher production volume and thus lower production costs.Sure, but that’s not the direction the research is going. They aren’t trying to get the cheapest possible battery, they’re trying to get the densest, which allows use in a number of applications where cost is somewhat secondary.
The hundred times is more than their best current product while the 50 is what their competitors are selling.I’m confused how 1,000 is a hundred times more than 50.
Well it does it's 100 times less than 1000 Wh/l.If you're referring to this:
You misunderstood. Competing batteries are producing 50 Wh/l. The article doesn't say what TDK's best are.
Neat. Although it bugs me how NCA is missing a side to close its polygon.Honestly, every article about new battery tech should be required to come with a spider graph like this one:
That's still a ~30% increase in energy density, which equates to either more range for the same volume of battery or the same range with a significant decrease in the mass of the battery. Even reducing the volume and mass of the battery, keeping the same capacity means an increase in range.It's certainly not 100x the at least 700Wh/l you get from a bog-standard 18650 or 2170 cells, not to mention special high-density polymer cells used in phones and watches. What the have in effect announced is that their previous solid-state efforts were so atrocious that they managed to improve it by 100x to barely matching cheap mass-produced cells when carefully assembled in a laboratory without any other performance specifications.
solid state battery. Sounds like solid states are really only used in nice applications today, but this density could make it feasible as an alternative to some of the existing battery tech you mention, meeting or exceeding those.This article is very confusing and misleading. Let’s look at the following approximated energy density numbers for various battery types:
Given these numbers, the claim that TDK’s new battery is “about 100 times greater” in energy density compared to their current battery suggests an implausibly low starting point. If their current battery truly had an energy density of only 10 Wh/L, it would be far below the typical range for any commercially viable battery technology, even those used in niche applications.
- Lead Acid Batteries: 50-100 Wh/L
- Nickel-Cadmium (Ni-Cd): 100-150 Wh/L
- Nickel-Metal Hydride (Ni-MH): 140-300 Wh/L
- Lithium Polymer (Li-Poly): 250-300 Wh/L
- Lithium Iron Phosphate (LiFePO₄): 200-300 Wh/L
- Lithium Cobalt Oxide (LiCoO₂): 250-300 Wh/L (most common in smartphones)
For context, even the lower-performing lead-acid batteries, which are among the oldest and least energy-dense rechargeable batteries, have energy densities well above 10 Wh/L. This discrepancy indicates either an error in the claim or that TDK is referring to a very specific, low-density type of battery that is not representative of the broader market.
Furthermore, achieving 1,000 Wh/L would be a groundbreaking advancement, far surpassing the energy densities of current lithium-ion batteries, which are generally around 250-300 Wh/L for the types used in consumer electronics. This level of improvement would revolutionize the industry, but it also requires a careful examination of the specific technologies and use cases involved.
In summary, the article’s claims need to be clarified and contextualized to avoid misleading readers about the current state and potential advancements in battery technology. The numbers presented in the article should be compared with typical energy densities to provide a more accurate and understandable perspective.
True, but it seems like it'd be easier to protect smaller pieces of ceramic, or at least isolate them from shocks. For example, I'd think that 144 1-inch discs embedded in a flexible sheet with tiny gaps between them would be easier to protect than a single foot-diameter ceramic disc, as more of the deformation could be handled by the supporting flexible material, but I'm not sure how accurate that actually is.They're worried about the structural stability of the ceramic. So if you hit a molar-rattling pothole, you'll also break the ceramics in the battery. Could also be a problem for things like dropped cell phones, but cars are generally subject to a lot more bouncing around.
There's no edge for NCA between Cost and Specific Energy. That's driving me insane.Honestly, every article about new battery tech should be required to come with a spider graph like this one:
That's because P-Zeros are performance tires and use a soft, grippy compound.One potentially big savings from less weight in electric cars will be better tire longevity. Current EV burn through tires very fast. My nephew has a Rivian truck and his last set of P-Zeros lasted 20K miles. My friends with Teslas say it's about the same for them.
It would have been nice to see more comparative numbers for perspective, I did some quick math based on the stated capacity and dimensions for the first batteries to pop up on their website which came in at 10.3 Wh/L. A cursory glace seems to be their focus on sealed, small, stable batteries that can last a lot of cycles. Specifically, wearables, sensors, and "energy harvesting."This article is very confusing and misleading. Let’s look at the following approximated energy density numbers for various battery types:
My singular gripe (and it's a common one) with the Watch Ultra 2 is the size and weight, but I love the battery life. I'm pretty sure if they could pack all those features into something with the thickness of the regular Watch, they would do so. Or maybe I just lack the imagination to think of what else they could pack into something of that size without some major breakthroughs.Will this lead to an Apple Watch with >7 days operation between charges, or will Apple make the cell and watch smaller or use the space savings for other features?
It will let them make the watch thinner.
P-zeros don't have a long life. And if that Rivian was running in conserve mode, they're absolutely eating their tires.One potentially big savings from less weight in electric cars will be better tire longevity. Current EV burn through tires very fast. My nephew has a Rivian truck and his last set of P-Zeros lasted 20K miles. My friends with Teslas say it's about the same for them.
It's an FT article so not really up to usual ars standards. I hate being too nit-picky so I'll apologize in advance. The article specifically transitions to a larger discussion of solid state batteries as a goal for EV's and then about why specifically TDK's battery is unsuited to an EV application. If there'd been a statement by TDK that automotive cells using this tech were on their roadmap then sure, but there's nothing like that in there. So, gasoline vs battery for my wireless earbuds? Not really a useful comparison. In addition the energy density of gasoline thing tends to get thrown around as a red herring in anti EV commentary so it's just injecting pointless strawmen into the conversation. Instead if we want to have a discussion on comparative energy density then the OP could have linked to a chart comparing all sorts of energy sources. In fact, here's one right now in handy table form: Energy Density ReferenceI respectfully disagree, for these reasons, that it's "utterly useless".
- The article itself brings in the topic of vehicle batteries.
- A fair number of comments are discussing vehicles, despite the use case for the reported break-through being small electronics.
- A comparison of energy density values in a standardized measurement, regardless of use case, is an interesting and useful fact in its own right.
https://meincmagazine.com/gadgets/202...-to-chasing-thinness-in-its-hardware-designs/It will let them make the watch thinner.
