I have a stupid question: does this mean we can't plug in a ~100W external battery / power bank to make it portable? It'd be cool to combine it with VR headset/AR glasses if it could.It has an internal power supply so it's doing its own AC to DC conversion.
Yes, you're right; I'd forgotten about that.I believe Apple's M-series iMacs have power bricks. I've not seen one myself, but that has the funny distinction of being where the ethernet port is, on so-equipped models.
I think the power button is a hassle no matter where it is when the machine is attached to the back of a monitor. As long as there is physical space to get your finger in there it shouldn't be that much worse than the back (bottom?) button.I guess the power button location is more likely to be an issue if you were hoping to mount the mini on the back of your monitor.
The power brick for the iMac is, however, inline. It doesn’t take up extra space at the outlet.Yes, you're right; I'd forgotten about that.
Right, the power button placement is weird but the scattered leaves on the desk are not.The bottom-mounted power button is weird but, honestly not a big deal.
Ironic, as some would consider it more aesthetically pleasing.Andrew Cunningham said:The ugly: Bottom-mounted power button, I guess?
You've got two typos towards the end, where a couple of paragraphs are just left hanging:
Bobby Womack said:Always leave them wanting more.
I would say get the base model. Then it can only go up from there.Great article. This is the one that's going to bring me over to getting a Mac. Those benchmarks are absolutely incredible. Now I have to decide if I want the base model (which looks like a great buy) or go absolutely bonkers. Would love some input from a Mac person!
According to the specs Apple provides, the power supply inside the unit can provide up to 155W of power --> https://www.apple.com/mac-mini/specs/Any particular reason why the Mac mini can't / shouldn't run via USB-C power input?
Wattage is no issue and it would be good to have one less power cable. Would also make the mini easier to mount on the back of a screen.
Why?I also power up my M1 Mini in the morning and down in the evening.
That's insane, what do they use that much of power for?According to the specs Apple provides, the power supply inside the unit can provide up to 155W of power --> https://www.apple.com/mac-mini/specs/
Likely headroom to support the USB/Thunderbolt power output specifications and not so much to drive the M4 chip.That's insane, what do they use that much of power for?
I'd guess they don't, but when you buy that many it makes your supply chain easier to have fewer SKUs - then you underuse it and run in a nice calm, clean power environment.That's insane, what do they use that much of power for?
Never pushing the power button on the Mac Mini would still work fine if you use your smart power strip. Just shut down the Mini from the menu option and then have the power/energy setting set to wake up on power connect. This way it will turn on when the power strip gives it power.I also power up my M1 Mini in the morning and down in the evening. Same thing with my previous desktops. Why make my master/slave power strip redundant by placing the power button on the bottom?
Yeah the upgrade prices are heinous, as is usual for Apple. The base model is really good for $499 on the edu store, though.Adding 16GB more RAM and 256GB more storage doubles the price?
You could get 2 of the base model for the same price as an upgraded version???
View attachment 95343View attachment 95335
Potential downstream power requirements of Thunderbolt 5 ports?That's insane, what do they use that much of power for?
Wow- my shipment had been scheduled for the 18th, then this morning it was the 15th... I saw your comment and reloaded the tracking page and now apparently it's tomorrow:This is really whetting my appetite, my MBP-max turns up tomorrow (despite being promised for next week) and if the M4 pro is this good…
(Warning: Anecdata ahead) I'm not too fussed about the location of the power button. It's something that I only touch very very rarely. Maybe less than 5 times a year.I think the power button is a hassle no matter where it is when the machine is attached to the back of a monitor. As long as there is physical space to get your finger in there it shouldn't be that much worse than the back (bottom?) button.
I would be fine with leaves, but they aren't leaves from an apple tree. Andrew missed an opportunity to build his PR art design portfolioRight, the power button placement is weird but the scattered leaves on the desk are not.
It's never a bad idea to have some buffer room.That's insane, what do they use that much of power for?
Evil plotting. That's what all us Apple fanbois do.That's insane, what do they use that much of power for?
Apple's warehouse to house logistics is pretty amazing.Wow- my shipment had been scheduled for the 18th, then this morning it was the 15th... I saw your comment and reloaded the tracking page and now apparently it's tomorrow:
China at noon with delivery the next day- that's a pretty tight margin. What a strange world we live in!
Because we don't want to use power when we don't have to? If We only use the thing for 40 hours a week, that's 6680 hours a year we're not using it, so why keep it using even standby power for the vast majority of the time?Why?
Imagine an Xgrid cluster of these!Adding 16GB more RAM and 256GB more storage doubles the price?
RAM is on a subcarrier bolted on the SoC package-- Nothing is going to beat that for pure access speed.There's no such thing as external RAM - but why not? Thunderbolt 5 runs at 80 Gbit or 10 GByte per second. An external RAM disk connected to Thunderbolt 5, used for swapping virtual memory, with 128, 256 or 512 GByte of the slowest RAM built in, should give a large portion of the advantages of "real" RAM in the computer for very little money. Without the wear and tear of an SSD drive used for swapping.
I'm not going to downvote you for it, but I disagree. We live in a world of overly confident (or in some contexts, alarmist) declarations and hyperbole. The result is that people become desensitized to extreme statements, which means that when something genuinely extreme/important comes along, it's hard to communicate that. So I'm fine with erring on the side of a little bit too much caution/nuance.I don't care if I get downvoted for this, but my pet peeve response has been activated: Does the word "probably" really need to be in the headline? Is it ever possible to definitively state something without hedging? If this isn't the best Mac Mini ever, I'd like to know what is.
I especially love when reviews say something is "probably one of the best", which is just about the most non-committal pronouncement you could make.
Same reason my TV isn't on when I'm not using itWhy?
That'd be too easy. I gotta go contemplate life for a while.Never pushing the power button on the Mac Mini would still work fine if you use your smart power strip. Just shut down the Mini from the menu option and then have the power/energy setting set to wake up on power connect. This way it will turn on when the power strip gives it power.
Close? The handbrake charts (perhaps not the best benchmark for such things) put it at the same performance as an M4 while using twice the energy? Or you can use an M4 Pro and get it done in half the time with 25% less energy?Whats this Ryzen thing (from a google)
https://www.amd.com/en/products/processors/laptop/ryzen/300-series/amd-ryzen-ai-9-hx-370.html
As in how the hell is it close to an apple ARM chip in Energy usage (last time I looked admittedly a long time ago, Apple was way way ahead)
Then you'd need a power brick. With it taking standard AC power, it becomes the power brick for other USB-C devices.Any particular reason why the Mac mini can't / shouldn't run via USB-C power input?
I think there’s a bit of “under-promise, over-deliver” going on as well. I was fine with a delivery of next week, but I’m really happy it’ll be here tomorrow!Apple's warehouse to house logistics is pretty amazing.
Yeah it's UPS or it's FedEx but Apple is paying for it to be this good, as opposed to some places where their logistics is "lol whatever".
