The metal pins in the MagSafe charger are recessed, so they present less of a short circuit hazard. I'd also speculate that the Apple device has short protection circuitry that the Steam device clearly lacks.In theory this shouldn’t be much different than Apple’s longtime laptop MagSafe charging connector. Can anyone chime in on whether that’s less of a fire risk, and if so, how?
I don't know if the device is any smarter, but design wise, the pins are indented slightly below the magnet. The Steam controller's raised pins seems like a bad ideaIn theory this shouldn’t be much different than Apple’s longtime laptop MagSafe charging connector. Can anyone chime in on whether that’s less of a fire risk, and if so, how?
Looking at the physical pins in the photo, it does look different in one key way - Apple's laptop magsafe keeps the pins recessed in a lowered area inside the magnet, which prevents easy contact with the pins by a stray watch band.In theory this shouldn’t be much different than Apple’s longtime laptop MagSafe charging connector. Can anyone chime in on whether that’s less of a fire risk, and if so, how?
According to a quick Google the issue with hoverboard batteries hit 50+ complaints to the CPSC before any noted recalls were made.For everyone else, let this be a reminder to keep your Steam Controller puck away from any metallic or magnetically sensitive objects.
I dont understand how this is the advice and not a mass recall and a redesign to avoid this. How many houses will have to burn down or people die before this is addressed?
It's easier to take everyone at their word...Does Ars reach out to redditors to confirm their story? This all sounds plausible but it would be nice to read "we reached out to so and so..." rather than "they wrote on reddit...". It builds more confidence in the reporting.
No idea how the MagSafe charger works, but I am an electrical engineer, and if I were designing a connector like this, I'd have it have some sort of digital "handshake" before energizing the contacts as well as current sensing to ensure that any time the current abruptly drops (like when disconnected) it has to repeat the handshake before re-energizing the pins. Probably $0.20 in parts, tops.In theory this shouldn’t be much different than Apple’s longtime laptop MagSafe charging connector. Can anyone chime in on whether that’s less of a fire risk, and if so, how?
What happens if I put a lightning cable in my mouth? Does it send 15w to me or confirm Im an iphone?
Also an electrical engineer here. I don't think it's that simple if the link posted above by Quasarsaurus is also true.No idea how the MagSafe charger works, but I am an electrical engineer, and if I were designing a connector like this, I'd have it have some sort of digital "handshake" before energizing the contacts as well as current sensing to ensure that any time the current abruptly drops (like when disconnected) it has to repeat the handshake before re-energizing the pins. Probably $0.20 in parts, tops.
Bluntly, this is just bad engineering.
Scrolled back and read that. Agree that it looks like Valve did the right thing and something else is going on here.Also an electrical engineer here. I don't think it's that simple if the link posted above by Quasarsaurus is also true.
Agree. Which also extends to the physical design. It's pretty fundamental that the current carrying devices should not be the first thing to make contact.No idea how the MagSafe charger works, but I am an electrical engineer, and if I were designing a connector like this, I'd have it have some sort of digital "handshake" before energizing the contacts as well as current sensing to ensure that any time the current abruptly drops (like when disconnected) it has to repeat the handshake before re-energizing the pins. Probably $0.20 in parts, tops.
Lightning cables have a chip embedded in the connector that does authentication to prove it’s an officially approved cable. It seems a safe bet that there’s some current negotiation involved too. (It got cracked eventually.)I always assumed these types of things had some sort of smart logic that only sent any measurable power through after confirming it was properly seated. What happens if I put a lightning cable in my mouth? Does it send 15w to me or confirm Im an iphone?
A user on reddit tried to replicate it with a variety of metal objects and was unsuccessful. Its possible that OP's scenario was a fluke where his pixel watch was charging and somehow shorted through the puck.
View: https://www.reddit.com/r/SteamController/comments/1tkelu6/psa_puck_is_not_an_immediate_fire_hazard_but/
From the testing that sgasgy did, it has those circuits since he couldn't reproduce it. It is very likely it is an failure mode they were not aware of. It could be a software bug that left the charger in charging mode after the removing the steam controller. It could be a marginal reset circuit that is only problematic with a short cable. Or maybe a long cable causes issues. We are in the middle of part shortages(again) and I am sure Steam has to use contract manufactures. It is possible a key part was replaced with a counterfeit.No idea how the MagSafe charger works, but I am an electrical engineer, and if I were designing a connector like this, I'd have it have some sort of digital "handshake" before energizing the contacts as well as current sensing to ensure that any time the current abruptly drops (like when disconnected) it has to repeat the handshake before re-energizing the pins. Probably $0.20 in parts, tops.
Well, not everyone. I go by the "extraordinary claims require extraordinary evidence" doctrine. If someone says they have a cat, I believe them wholeheartedly unless I'm given reason to doubt it. If someone says they have a goat, I might have some questions about how difficult that must be or if they live on farmland, but that's just curiosity. I don't really doubt that. If someone says they own a dinosaur, now I'm going to have to ask for some evidence. If they provide a picture of a crocodillian, I'll say "touche salesman" and move on. If they say they own a unicorn, not only do I doubt them, I simply leave the conversation.It's easier to take everyone at their word...
I must have seen a dozen YouTube videos of Americans heaping praise on the Type G plugs we have in the UK. They have at least five safety features, except one to stop you standing on them in bare feet, which hurts. Imagine standing on an errant Lego brick then multiply that by three.For example, MagSafe recessed connectors as has already been mentioned, or (well designed) electrical plugs where the earth connection is the first connection before the live one.
Because then it stops looking like a smiley face.By the by, I’ve often wondered why American sockets aren’t installed upside down. Having the earth pin at the top would stop the rare instances of something conductive falling onto a half-inserted plug and shorting live and neutral.
Deep down I always knew this was the reason.Because then it stops looking like a smiley face.
Oh, now I'm triggered. My house has upside-down outlets to indicate half the outlet is controlled by a wall switch. I freaking hate these outlets because I use flat-plug power strips (where the wire is supposed to go straight down flat against the wall), but on those outlets the wire goes straight up putting tons of strain on the plug.By the by, I’ve often wondered why American sockets aren’t installed upside down. Having the earth pin at the top would stop the rare instances of something conductive falling onto a half-inserted plug and shorting live and neutral.
Because that failure mode basically never happens. If the pins are exposed enough for that to matter then the plug has basically fallen out of the outlet at that point. A loose outlet in practice exposes maybe a millimeter of conductor, and that's with a heavy cord and a very worn receptacleI must have seen a dozen YouTube videos of Americans heaping praise on the Type G plugs we have in the UK. They have at least five safety features, except one to stop you standing on them in bare feet, which hurts. Imagine standing on an errant Lego brick then multiply that by three.
- Earth pin is longer so is always the first connection.
- L and N pins are covered in plastic for most of their length so by the time they are connected there is no exposed metal.
- Plugs have a fuse rated for the appliance; there’s no need for a table lamp to draw more than 3A, so that’s what the fuse is.
- If you somehow manage to pull hard enough to rip the cord out of the plug the wires inside are cut to different lengths, such that the live wire is the first to be disconnected.
- The L and N connections in the socket are behind plastic doors that are opened by the earth pin, so it’s pretty much impossible for a child to stick anything into a socket that doesn’t belong there.
That plug is one of the most over-engineered plugs in existence. The UK is unique in that it allowed "ring circuits" for AC power, when every other country used branch wiring, so the safety fusing had to be integrated into every plug as well as the fusebox, and this made the UK plugs so huge to accommodation room for a fuse.I must have seen a dozen YouTube videos of Americans heaping praise on the Type G plugs we have in the UK. They have at least five safety features, except one to stop you standing on them in bare feet, which hurts. Imagine standing on an errant Lego brick then multiply that by three.
That's common in commercial wiring now, to the extent that outlets sold/designed for commercial use have the markings "upside-down" relative to outlets sold for residential use.By the by, I’ve often wondered why American sockets aren’t installed upside down. Having the earth pin at the top would stop the rare instances of something conductive falling onto a half-inserted plug and shorting live and neutral.
What ground loop? The Pixel charger uses inductive charging.Another EE here, based on the reddit link above it looks like it might have been caused by a ground loop. The power itself maybe not have been directly generated by the controller puck or the pixel charger, but a circuit forming between the two. If that was the case, it's possible that the voltage and power going through the watch band was much higher than either charger could produce. Like others have mentioned US home power layout can have issues that places a voltage potential on what should be a neutral or grounded line. The cavate here is that good chargers should isolate everything on the low voltage side, but like most things that is a should and not a 100% do. Isolation of grounds is not always a given simply due to the nature of what a ground is expected to do.
I've looked through this thread several times and ctrl-F'd for coonwhiz, I'm not seeing this comment/link that is being referred to.EDIT: Please see @coonwhiz 's link, it seems it could be more complicated that just at a glance.
