Interesting because I never think of PD products as ever being cost competitive. I do happen to own one of their mechanical pencils but, yeah, I paid too much. lol
What's the next size up with similar specs? I want this type of monitor but larger than 32". Currently using a crummy old 42" 4k without HDR or high-quality panel.
Alienware sells a 34-inch, ultrawide OLED monitor for $1300. That makes this panel interesting but less appealing by comparison.
The PPI on that will be significantly lower than the Porsche listed here; which is already pretty low (4k @ 32 inches) - the Dell is 109 to the Porsche's 141. Compare that to the new Apple display which is sitting at 217. Each of these devices certainly has their market, but I don't think you can really compare them at all (the Dell is clearly for gamers, the Apple clearly for designers, the Porsche… for … uh… someone?).
(PPI are rough estimates, probably off by a few percent as we don't have exact figures)
Accompanying the latter is a pair of hooks that extend out of the monitor's left and side to give you a place to hang your headset.
Maybe it's just me, but these seem like a cheap afterthought some designer threw in.
Those were all mini LED monitors?You know, most 32" 4K monitors run between $300-$500 today (after checking prices at Amazon).
I'm hoping OLED and mini LED monitors drop to under $1000 in the coming years. For now, there's still an early adopter tax to be paid.
This Alienware only has a vertical resolution of 1400 pixels. Not really comparable to a 4k monitor. If this Porsche monitor was 27" I'd be into it. But 32" is too big for me.
Add to that the fact that unless they are reasonably easy to remove and reinstall, don't even think of using these in a multi-monitor setup. (Although I admit that 32", regardless of aspect ratio, would make a massive setup if used side by side.)
Well, it at least looks like Porsche put at least a small amount more thought into the design of this than they did the early LaCie hard drives, which were basically brushed stainless blocks with small notches and an LED light in them.
And at least you can (remove / retract / fold back / hide) the Frankenstein style headset hooks . . . right?
I'm a computer tech that's been working in the consumer space for 15+ years now, and I've encountered Porsche Design computer equipment exactly once in that time.
A client brought 2 USB hard drives in. 3.5" form factor, completely dead. The 12v power supplies with them tested fine. I pulled the internal drives out of the USB enclosures. They were standard 3.5" SATA HDDs, I think Toshiba, but they may have been Hitachi or Western Digital. I don't remember.
I connected them to a bench desktop configured for SATA hot swap. I've used the system hundreds of times before and since without incident. I was holding the drive in my hand, PCB up to avoid touching it. As I connected the power, one of the chips burst into flame.
Yes, the drive literally burst into flame in my hand.
Granted, it only burned for a second, and it certainly didn't harm me in any way (though the smoke was pretty acrid).
After getting over the sheer shock, I connected a drive I didn't care about to the same connectors. Worked fine, no issues at all.
Then I tried the next Porsche drive. It ALSO burst into flames, exact same chip.
I never did figure out who made the USB controller. I'm not sure if the client did something truly crazy to the drives, or what may have actually happened. I'm not sure if I should blame Porsche Design for sourcing bad parts, or the drive maker or what. But its never happened to me before or since. Some cursory web searches revealed no similar incidents occurring, so it was probably an isolated incident.
But still, it left a rather strong impression of Porsche Design on me.
Why?But 32" is too big for me.
They can luckily co-exist as you say
I would always pick the higher pixels per inch personally as I don't really game but stare at the screen for work. 4K on a 32" monitor at normal viewing distance would look like a blurry mess to me at this point though.
Who would buy this over an OLED, either the AW or the LG C2.
Someone who doesn't want burn-in anxiety? Or needs a brighter-room solution. The LG OLEDs are great, but they struggle in bright rooms.
It's possible the drives in question were doing some funny business with the 5V and 3.3V lines. Traditional hard drives from the IDE era only ever had access to 12V and 5V since that's what was on the 4-pin molex connector, so drives were designed to use only 12V (for the motor, typically) and 5V (for the logic).I'm a computer tech that's been working in the consumer space for 15+ years now, and I've encountered Porsche Design computer equipment exactly once in that time.
