Three million cars’ worth of emissions could be cut by addressing inefficiency.
Read the whole story
Not feasible. If it was, they could (and should) skip the crypto and just generate electricity for more productive uses.At an oilfield in southern Louisiana, several flares were replaced by generators to power a crypto mining facility.
It's too bad methane-fueled fuel cells are so squirrely.I kind of know the answer, but it always impressed me that they didn't even try to capture a part of that fire. Put a coil of water pipes around and heat some water or something. It would still be an open flame, that you don't try to control, but at least you could try to recover some energy from it.
Cutting those emissions would require some sort of infrastructure investment; which means money would be spent on something that, while good for humanity as a whole, does not increase shareholder revenue.
Edit: Ninja'd by two. I would expect nothing less from Arsians - well done.
Injection of steam into the flare improves its burning efficiency.
Being able to sell the gas would definitely increase shareholder revenue, but the problem is it's really hard to build new gas pipelines. Just the permitting for it is a years-long process with no guarantee it will succeed. You can truck out oil or move it by train but the only way to economically move natural gas is with a pipeline.
If you have a reliable source of steam, you might as well generate power instead of flaring it.Injection of steam into the flare improves its burning efficiency.
At my college we ran a cogeneration power plant. It was powered by a combination of methane from the local dump, and natural gas. Because of the inconsistency in the supply, you had to feed it with a steady source to keep the power from going out unexpectedly. All the desktops had “save work often” signs on them for that reason. Couldn’t afford a UPS at every workstation. Cut the power bill in half, including the cost of the generation facility and having Siemens manage it professionally for us.
Steam is easy especially if you have gas you need to flare. High pressure and high quality steam is required to make useful power.If you have a reliable source of steam, you might as well generate power instead of flaring it.Injection of steam into the flare improves its burning efficiency.
I'm guessing it has to do with the temperature of the reactants. Hot methane is much closer to ignition than is cold methane. So it takes less time to ignite and therefore can't escape the ignition source before reacting.Injection of steam into the flare improves its burning efficiency.
Huh, why is that? Better mixing?
Unfortunately it probably is feasible depending on crypto price vs gas price vs local electricity price. Building an electric transmission line from the oil field to the local grid where power could be sold is probably a large percentage of the cost of the generating unit. A local crypto server farm and cogen possibly makes sense as all you need to export is data.Not feasible. If it was, they could (and should) skip the crypto and just generate electricity for more productive uses.At an oilfield in southern Louisiana, several flares were replaced by generators to power a crypto mining facility.
This article disagrees.
The location wasn't Louisiana, but that's not relevant to the point.
EDIT - link formatting
The flare stacks from the article here are at oil wells. The flares aren't at natural gas extraction sites.Here's a question: how much natural gas actually makes it to consuming devices in the US each year?
In comparison, how much natural gas is flared after extraction in the US each year?
And in comparison to THAT, how much natural gas is leaked after extraction in the US each year?
I currently don't have a concept of how these numbers compare to each other. While we definitely want to limit both methane AND CO2 emissions at all points, it would be useful to know where to focus the most attention.
Natural gas producers have lots of leaks but they're economically motivated to capture the leaking gas.
Ars ran an article about these emitters in March. Perhaps that has some information you'd find interesting.
Even just leaks of storage tanks can cause massive problems.With the attack on the Nordstream 1 and 2 pipelines, I think the timing for this article is rather poor.
But it's nice to know what it would take to compensate for that too.
The answer is in the article. These are oil wells releasing and flaring the methane. Oil wells don't necessarily have a gas pipeline nearby. Fracking extraction includes building pipelines to carry the gas that's released. Fracking is designed from the start to deal with gas. Oil extraction is designed to carry liquids.Just capure it and sell it ffs. Why frack when gas is literally being wasted?
But I'm not speaking from actual knowledge. I'm just trying to figure it out from context.
If the only reason for the gain in combustion efficiency is due to temperature, there's lots of ways to accomplish that with better-designed flaring hardware that don't require steam. The exhaust gas of the flare stack is hot after all. Some sort of EGR system could directly convert some of the combustion products into ignition enhancers or a counter flow heat exchanger could simply preheat the air.I'm guessing it has to do with the temperature of the reactants. Hot methane is much closer to ignition than is cold methane. So it takes less time to ignite and therefore can't escape the ignition source before reacting.Injection of steam into the flare improves its burning efficiency.
Even with the need for ignition close to the well site, I'd hate to think that putting an air-to-water heat exchanger in the existing flare stream to generate steam for a generator would be a hugely cost-prohibitive solution.
