Probably the last big updates we'll see before the next versions appear at WWDC.
Liquid Glass and enlarged radiuses will continue until morale improves.Is it possible to disable Liquid Glass or to reduce window corner radii?
That's exactly the feature everyone is waiting for. More ads in places that shouldn't have them. Thanks for the premium experience apple! Wish there was a way to get rid of them if possible. Google maps ads have been becoming more egregious lately and I had mostly shifted to apple maps.and some of the initial work needed to support ads in the Apple Maps app
It’s hard to say what to expect from the 27 releases, except that we’re still waiting on an updated AI-backed version of Siri
The online safety act does exist and the verification crap was put in due to pressure from ofcom over the that legislation. To get it ripped out this act needs to be repealed which would require different politicians.Not that you will be able to really know, but have they ripped out the age verification crap for UK where no such laws actually exists?
Here is hoping that one of the options is "none of the above". So far we've been able to turn some of the AI features off, which limits the space usage by them but it's not uniform....users will be able to choose the AI models they want to use for Apple Intelligence’s writing and image-generation tools...
Read The Fine Article to find out.So will all my RCS chats now be encrypted to my Android friends or does my carrier have to support it along with Google
They do now.Those support links, as of yet, do not reference 26.5.
[snipped away parts i'm not replying to, hope that's okay]Overall I am mostly happy with where iOS 26 and MacOS 26 ended up, though I do suspect a large part of why I don't hate them is because I had the newest (or new enough) hardware to run them without them running into the resource hogging issues they are seemingly running into on phones and laptops even a few years old, that were otherwise perfectly functional prior to this update. Hopefully Apple does something about getting those devices up and running properly, as they should be.
Yeah, this is definitely a fair shout out, there is no getting around how bloated iOS has gotten over the last decade in terms of file size. And I mean it makes sense on some levels, there's a lot of generalized code included in it now to make sure it can function across all the devices it supports, but I do miss the days iOS being super lightweight and snappy. Of course, it was also a lot less capable and robust then than it is now, so I realize this is all a matter of tradeoffs, but even so, I wish Apple wouldn't lose sight of the devices this OS is primarily meant for (battery powered, low specced devices with storage and memory at a premium).[snipped away parts i'm not replying to, hope that's okay]
Overall, I think my 13 Pro Max has settled into iOS 26 in terms of performance, and I think I've gotten used to the odd case of hitching and apps randomly freezing. The one big problem I still have with 26 is that it definitely uses a lot more disk space than iOS 18 did, and it continues to be a source of nearly-constant frustration with my now-paltry 128 GB of on-board storage.
Case in point: I can't take the 26.5 update because my storage is full. Barely even four gigabytes of space is available, and the updater wants more than thirteen. (My attached screenshot was hastily stitched together to simplify uploading and viewing.)
Last night, I was asking Siri for the scores in the Montreal Canadiens and Anaheim Ducks games.There is really only one Siri feature I want. Sometimes, when I ask it to play a particular song/playlist/album, I get something completely random, no matter how clearly I enunciate or repeat myself. I want:
- An option to jump into a log and see if Siri identified what I said correctly
- If it didn't, provide a correction in text
- If it did, then the ability to specify what I actually bloody wanted to happen. An interface similar to the Shortcuts interface would work nicely.
Fuck right off you greedy fucking cunts.some of the initial work needed to support ads in the Apple Maps app
When I worked on RCS, it was possible to encrypt from client to server and vice versa, but wasn’t necessarily encrypted on the servers.So will all my RCS chats now be encrypted to my Android friends or does my carrier have to support it along with Google
I absolutely second that! It’s the only thing I use Siri for and only when I’m driving.. I’ve ended up switching the stereo off a few times when I just can’t get it to play the music I’ve asked it for (mostly politely) about 10 timesThere is really only one Siri feature I want. Sometimes, when I ask it to play a particular song/playlist/album, I get something completely random, no matter how clearly I enunciate or repeat myself. I want:
Have you got it set to offload apps you don’t regularly use? That made all the difference on mine (also binning a load of apps that I’d forgotten about helped too!)[snipped away parts i'm not replying to, hope that's okay]
Its behavior under low storage should probably also mean prompting the user well before it's actually at zero storage, as it gets sketchy and starts doing weird things well before thatHave you got it set to offload apps you don’t regularly use? That made all the difference on mine (also binning a load of apps that I’d forgotten about helped too!)
Geronimoooooooooooooooo....................................................................
I did just that when iOS26 made my iPad Pro unusably slow. I bought an M3 iPad Air that came with iOS 18 and turned off auto upgrade.Buy an Apple product that came with an earlier O/S and reinstall as needed.
My system data is only 11GB, so it seems like something is wrong there. Maybe do a full hardware reboot and see if the caches clear and leave you with enough space?Case in point: I can't take the 26.5 update because my storage is full. Barely even four gigabytes of space is available, and the updater wants more than thirteen. (My attached screenshot was hastily stitched together to simplify uploading and viewing.)
The RCS migration has been…a letdown.Good to see encrypted RCS coming along nicely, especially in light of all the FUD and complaining about RCS when Apple first added support for it at all.
image playground is probably the most disappointing piece of demo ware that Apple has ever shipped.In macOS, the stub for the "image playground" app is not uninstall-able unless you disable the system integrity protection. I'm not begrudging Apple for making it, but why isn't this an optional app? It's hardly something critical to the functioning of the operating system.
The main issue I've seen on my end for cross iOS and Android RCS (once I switched from Samsung Messages to Google Messages) is not getting read receipts from iOS. This happens on both group and 121.The RCS migration has been…a letdown.
the android ecosystem is so full of workarounds, it feels like 90% of my friends get full resolution pictures, and a few others get nothing but pixelated garbage.
“Android to Android works great!”
That’s nice, and I don’t necessarily believe it. Why is Apple’s adherence to the standard breaking messaging on -some- Android phones but not others? Who knows?
What a mess.
Oh yes, it should disappear. It needs to be killed with fire.… I don't particularly care for AI, but Apple advertised it as a core pillar for over a year, it shouldn't just be allowed to disappear without them delivering on it.
