As aquifers dry up, some Midwest communities are looking to the region’s natural resources.
Is that really cruel? We're not talking about letting people die, we're talking about letting cities where there isn't a local source of water for the city that they can legally access, die, because, you know, maybe there shouldn't be a city where there's not enough water for the population.Or perhaps in someone’s cruel view, they just let Joliet whither and die. That’ll show ‘em.
/s
Many responses here to this situation are so naive as to be labeled unbelievable.
I suspect that once people realize how bad climate change is about to get, midwest cities are going to start seeing major population inflow.So urban sprawl is to blame?
One of the biggest problems that would need to be addressed is quantifying that recharge rate. We can measure how much water comes down as precipitation with decent accuracy. Figuring out how much precipitation actually reaches your target aquifer is another matter. Plants get in the way and intercept some of the water, evaporation removes some as well, and water can only infiltrate so quickly into the subsurface before it turns to runoff. Trying to quantify all those different influences is a very active area for scientific research. And that's not getting into the geology portion that tries to identify where recharge is even happening.While the story discussed the legal issues involved in taking water from Lake Michigan, I felt no one mentioned the 800 lbs elephant in the room, which is why does a city think it will be able to use groundwater at a higher rate than it's being recharged?
A recent NYT study on the use of groundwater by municipalities should give pause to anyone who gets their water from such sources.
going to run too dry to support the city by 2030...
...the intent to have water flowing to residents by 2030
That was Chicago's solution in the 1800's. Since then they added sewage treatment, along with everybody else.The fact that we take so much freshwater, use it once, and then pollute other bodies of freshwater with the sewage is silly. Being responsible, and cleaning up our waste historically was more expensive than simply sending it downstream, but as water availability is going to be increasingly difficult, I don't see how the alternatives are going to be cheaper. Might as well start the program now, so that in 20 years we avoid some dystopian water-wars future.
Agreed. There has been some suggestion that the IL-MI area will get increased rainfall as a result of global warming. We have had the occasional drought and the occasional flooding, but overall it hasn't been unusually dry in northern Illinois.Not everything is due to climate change*. In this case, seems more likely that doubling the Joliet population from 1990 ~ 76,800 to 2020 ~ 150,300, has far more to do with the aquifers running short.
*not doubting climate change, just getting tired of it being blamed for almost every problem.
Actually there is water available - Joliet is on a river and could just treat that water, but I guess Lake Michigan water is cheaper to treat? Or maybe better quantity, especially in the occasional drought.Is that really cruel? We're not talking about letting people die, we're talking about letting cities where there isn't a local source of water for the city that they can legally access, die, because, you know, maybe there shouldn't be a city where there's not enough water for the population.
Chicago has an exemption. Ever since they built the canal and reversed the Chicago River, that water is flowing into the Illinois River and into the Mississippi, not the Great Lakes basin. So there is an important difference.Seems kind of dumb to tell people that instead of allowing water to be moved to where the people are, the people need to move to where the water is, and they use the water anyhow. Although, getting back to a previous discussion where several people mentioned that if you are using water in the basin, it will be returned to the basin after treatment - but it sounds like Joliet will be doing that too, so what's the diff?
I work in an office building in the Chicago area and can attest by looking out the window, it indeed appears to be very flat here.I'm not super familiar with Illinois topography, but I kind of thought it was sort of flattish? So, I was pretty surprised to learn from this article that Joliet, only 30 miles from the lake, was not part of the basin.
I went and found a map of the Great Lakes Basin, and I can see why Illinois demands special treatment, a little bit. . .
Apparently, there's some fluke of topography where there's some, I don't know, hill line or high ridge line?, very close to the lake, which cuts off almost the entire state of Illinois from being in the basin - there's like a teeny, tiny strip, very long, but very, very thin along IL's shore that is part of the basin, but overall, IL gets very little surface area that's in the basin even though it's right along the shore of the lake.
Joliet is on the Des Plaines River. The city of Des Plaines is also on the Des Plaines River. They get their drinking water from Lake Michigan through Chicago. And Des Plaines the city is upstream form where Chicago dumps its treated sewage, while Joliet is downstream. I can't find any documentation form any town getting drinking water form the Des Plaines River, or why they don't.Actually there is water available - Joliet is on a river and could just treat that water, but I guess Lake Michigan water is cheaper to treat? Or maybe better quantity, especially in the occasional drought.
Frankly, we should make it damn clear that after a point, there will be no bailouts. If you can't afford to build something that will withstand storms and flooding, then you can't afford to live in most of Florida. I do think people who've been there a long time, and who bought in before the risks of climate change were clear should probably get a bailout. Maybe track it and say every property in the state can get a one time bailout, and then that's it.I suspect that once people realize how bad climate change is about to get, midwest cities are going to start seeing major population inflow.
Certainly it's better to have those people living in Illinois than to have them living in Florida and getting bailed out by taxpayers every few years each time their homes are destroyed.
Well, not exactly profit as Chicago is $40 Billion in debt.So Chicago was given extra water to help stop it polluting everyone else’s share back in the 1800s and is now turning that allocation to profit.
Well, there's another aspect to be considered here as well. The Compact assumes that the water is, for the most part, staying within the basin. So after the water is used, it returns to the same water system (or evaporates into the same weather system).It sounds like the legal justification for Joliet getting Lake Michigan water is that the Great Lakes Compact sets out the allocation for each nearby state, and Illinois/Chicago can decide how to use its allocation.
What that leaves me wondering in the long term is -- are the allocations set out in the Great Lakes Compact sustainable?
If yes, this can work. If no, it won't.
It's not $40 billion in debt on the water supply.Well, not exactly profit as Chicago is $40 Billion in debt.
With these places outside the basin, a question I've got is: where does the used water go? Do they have a post-treatment basin return planned, or is this all going to flow somewhere else, like was done with Chicago? Because that will change the rate calculations and be outside of what the Compact planned for.
Given the population dynamics of the Chicago area over the past few decades, I suspect that a significant fraction of the population in Joliet has moved from areas previously served by Lake Michigan water — which probably reduces the net impact of this over time. Still, I'd hope to see some limits on growth in the exemption areas to make it clear that it's a solution for existing homes, not a blank check to build new ones.
It shows how perilously close the great lakes were/are to dumping out into the Mississippi River Basin instead of the St. Lawrence.Apparently, there's some fluke of topography where there's some, I don't know, hill line or high ridge line?, very close to the lake, which cuts off almost the entire state of Illinois from being in the basin - there's like a teeny, tiny strip, very long, but very, very thin along IL's shore that is part of the basin, but overall, IL gets very little surface area that's in the basin even though it's right along the shore of the lake.
I'd assume just general population growth water use (domestic and the associated everyday commercial/industrial users that come with more population). Agricultural practices vary widely region to region- while agriculture, specifically crop irrigation, may be the dominant water consumer in the arid west, large scale irrigation is much less common in the upper midwest. There are areas where, due to soil types (extremely sandy so it doesn't hold water) and/or crops (vegetables mostly), it is somewhat common but, in general, only a small fraction of the vast corn and soybean fields in places like Illinois are irrigated. Really, the big problem is often getting rid of water- much like most farmland in the west is irrigated, a huge amount in the midwest is drain tiled to help dry things out.I'm curious about the cause of Joliet's big increase in water consumption. Generally, agriculture is far and away the dominant consumer of water. I can't imagine there is a farmland boom in the area. Has there been a major change in crops? Some other industry consuming a lot of water?
Is there any breakdown on why it's so expensive?I live right on Lake Michigan and our water comes from the lake about a quarter mile from our house. It is expensive, water and sewer is about $100 a month for normal use.
He may be in one of the few communities that use a privatized water supplier.Is there any breakdown on why it's so expensive?
I don't know. . . it does seem. . .slightly ridiculous, to say that a town 30 miles from one of the largest bodies of fresh water in the world has to disappear because of lack of water.
Yes, there likely are places, like major cities in Nevada and Arizona that will need to shrink or disappear because of lack of water, but it seems sort of crazy to say you can't pipe water thirty miles from a great lake.
Nestle in Michigan, which is gleefully pumping over a 1 million gallons of Lake Michigan a day to sell it at $2 a bottle all across the country, seems like a larger abuse.
