Hyperscalers have come under scrutiny for their impact on water quality and availability.
They include pledges to replenish more freshwater than the company consumes, via investments in local water projects; to scale up the use of reclaimed and recycled water; and to disclose annual water use in data centers. (Other tech companies, including Microsoft, have similar promises around water replenishment and local investment. Google has been working on most of these pledges for a few years.) There’s also a promise to use “a data-driven framework” to decide what data center designs would work best with local watersheds.
Most tech giants, including Google, have seen their carbon emissions skyrocket as a result of the AI boom. Totally avoiding evaporative cooling could increase emissions if data centers rely on dirty energy to keep facilities cool.
Everybody keeps saying "closed loop water cooling" to me like a mantra but are leaving it up to me to figure out how that might translate into demand.
Except...Those abandoned mines aren't just empty caverns. Pumping liquid into them likely means you're going to dissolve a lot of, more often than not toxic, minerals, that will then leach out elsewhereThere are numerous underground, abandoned mines that are flooded in the Midwestern and Appalachian coal fields. Why not use them for geothermal heating?
Because of their honeycomb tunnel layouts, each one offers multiple square miles of surface area for heat transfer between the mine walls and the water in these mines.
It’s too dangerous for humans to reenter abandoned mines but vertical wells slowly pumping large volumes out and then back in should be doable.
You could put solar panels on the strip mined areas that are often nearby. There’s also natural gas in these areas.
Pledges are just that. These "pledges" are as useless and meaningless as "carbon credits" have been. Toothless promises with farcical follow through that all but never accomplishes anything IRL. Just a whole bunch of performative paper shuffling and corporate greenwashing to fool those who don't want to watch too closely.They include pledges to replenish more freshwater than the company consumes, via investments in local water projects
Using more water can save money and reduce e emissions for big tech companies by reducing the power needed for cooling that relies on energy-intensive pumps to recirculate water.
They're not, but their PR department is on top of it.Facing increasingly fierce resistance, some tech companies are scrambling to assure the public that they’re facing the issue head-on.
If you pump water in and out you’ll have a closed loopExcept...Those abandoned mines aren't just empty caverns. Pumping liquid into them likely means you're going to dissolve a lot of, more often than not toxic, minerals, that will then leach out elsewhere
By definition, a flooded mine is full of waterAlso...you need water to pump. Which isn't just everywhere
Just about any subsidence that was going to occur happened during active mining. It’s not unheard of, but not much happens after abandonment.Also also, you risk destabilizing geological formations causing problems to above ground structures.
Free lunch? Well, it cost someone else many, many millions to develop your tunnel network.TANSTAAFL
Pumping large volumes very slowly should not destabilize the existing supports (wooden cribbing, steel roof bolts).
I was involved with a large, long distance water pipeline. It moved water slowly to minimize erosion of the pipe and was designed for decades of use.
You’re not changing the water level
Eventually, much of your mine is going to collapse in bits and pieces over many, many years whether you’re pumping water
The thing about THIS water use is that it's fresh water. Something the world is already seeing issues with. The supplies themselves are under duress from sea water intrusion turning fresh water brackish, and it's only going to get worse. In areas where water is depleted, evaporative cooling only wastes that water. It's not going to becoming back down IN THAT REGION where it's needed. So areas seeing less rainfall now from climate change are going to get far worse water issues even without data centers fucking with the soup.They include pledges to replenish more freshwater than the company consumes, via investments in local water projects; to scale up the use of reclaimed and recycled water; and to disclose annual water use in data centers. (Other tech companies, including Microsoft, have similar promises around water replenishment and local investment. Google has been working on most of these pledges for a few years.) There’s also a promise to use “a data-driven framework” to decide what data center designs would work best with local watersheds.
The only water use that matters is when they use it in evaporative cooling. And they use water by the millions of gallons per day for that (1000 million per 365 days is 2.7 million gallons per day). What are you going to evaporate that you could just release into the atmosphere, and that also is available by the millions of gallons per day?I'm certain (a lot of) people have looked into this already, but why not use things other than water to cool the centers? Is it just because water is just so much cheaper than alternatives? Is there really nothing else you could use that wouldn't be better?
Capex for Alphabet in 2019 was $25B. They are expecting to spend $180B this year.I read a news story about the controversial one in Utah that is 40,000 acres and can potentially consume 9 gigawatts of power.
To put that in prospective, I am currently working at a data center that supports large scale traditional computer processing (websites with petabytes of data, millions of transactions a day), and that data center fits on a 1 acre lot.
There’s no comparison.1) No you won't have a closed loop. Mines and geologic features are not impermeable. See what happens when fracking companies inject waste water into wells...it has a habit of bubbling back to the surface.
2) If you move slowly is the key. You do realize you're talking about an industry whose entire motto was literally "move fast and break things"...right?
Because water is just about the best coolant in the universe, especially when the operating temperature range of thing being cooled perfectly matches the liquid phase range of unpressurised water. You pretty much couldn't dream for a better coolant for this application than water.I'm certain (a lot of) people have looked into this already, but why not use things other than water to cool the centers? Is it just because water is just so much cheaper than alternatives? Is there really nothing else you could use that wouldn't be better?
I was wondering how they would "Replenish" the water. We can't just Harry Potter this. The Law of Conversation of Matter also has a word to say.I've heard about such projects before and its a lot of smoke and mirrors.
Big Hyperscaler hires a technology company to help conserve water with an irrigation company or water agency. Maybe it works, maybe it saves some number of gallons per year. But the technology company runs back to Big Hyperscaler and misrepresents the amount of water saved (because they get paid by the gallon), and that misrepresentation is used in their sustainability reports.
It’s a nice idea, but probably not workable. I’m only familiar with Appalachia, but acid mine drainage is a major issue here. The mine water can be both toxic and corrosive. Even if you were only doing heat exchange into that water, any equipment or pipes with reasonable heat transfer could get damaged being submerged in a toxic acid bath.It’s been many years since I was in a coal mine or looked at a mine map, but a long-operating mine might spread underground over an area of 5 to 10 square miles.
If continuous miners were used, it would consist of long, parallel 15’ wide tunnels with 15’ cross tunnels and 15’ square pillars of coal left in between tunnels to help hold up the roof. The tunnel height would match the seam height: typically 3’ to 8’
On a map, this looked like a honeycomb
Caveat: it’s been a long time since- I may be off 50% on the tunnel widths and coal block sizes.
When the section was fully developed, miners would “retreat” the mine, blasting pillars one at a time and retrieving some of the remaining coal. The mine roof behind the remaining roof would collapse but still leave large voids in the “gob” since you’d still have your wooden cribbing and/or roof bolts in old tunnels.
In some cases, the mine may have closed for economic reasons before the pillars were blown, leaving intact tunnels.
Starting in the 1980s some mines in these 2 regions moved to long-wall mining. Those mines have potential, too, but perhaps less than what I’ve described. See Wikipedia for more information
If the mine was “below drainage” (approximately the elevation of the nearest creek), it would fill with water after the pumps were turned off.
There’s enough cooling potential to support a lot of computing power.
Assuming an inlet temperature of 50 degrees F (15 C) and an return temperature of 104 F (40 C), a system moving 1 cubic meter of water per second will remove 160 MWThere are numerous underground, abandoned mines that are flooded in the Midwestern and Appalachian coal fields. Why not use them for geothermal heating?
This is an excellent typo.The Law of Conversation of Matter also has a word to say.
Water is actually phenomenal at this job due to its high specific heat and the energy required to evaporate it. The only other way to really get this waste energy out of these plants is to try to dump it into the surrounding air directly (due to the scale of energy involved, I don't think you can just dump it into the ground and expect it to cool off before you start causing problems). It's hard to put energy into the air because, unlike water, air's an insulator, has a low specific heat, and is already a gas so you can't take advantage of the energy required to push it through a state change.I'm certain (a lot of) people have looked into this already, but why not use things other than water to cool the centers? Is it just because water is just so much cheaper than alternatives? Is there really nothing else you could use that wouldn't be better?
Use stainless steel piping: already widely used in power generation.It’s a nice idea, but probably not workable. I’m only familiar with Appalachia, but acid mine drainage is a major issue here. The mine water can be both toxic and corrosive. Even if you were only doing heat exchange into that water, any equipment or pipes with reasonable heat transfer could get damaged being submerged in a toxic acid bath.
Flooded mines are just generally treacherous too. Any activity in them could release toxic gases or destabilize parts of them. If you did breach or destabilize old, flooded mines, you could trigger new/worse mine drainage which is already a major problem for PA/WV streams and rivers.
