Engineers could make another attempt to launch Starship as soon as Friday evening.
Apparently, jinxed by Nicki Minaj coming onto the official SpaceX broadcast to wax poetic about what a towering paragon of virtue Elon is...
Where's the Kaboom! ?
I’m not really sure why this is spun as a positive thing for SpaceX. If something goes wrong on this flight and it’s a hardware issue then they have to go back and retrofit it on the already built hardware. As opposed to having the fix designed and built right the first time.
On the first launch of such a major redesign for a system this large and complex, everything going flawlessly would be a more than minor miracle - no matter how much care was taken in design up-front.I’m not really sure why this is spun as a positive thing for SpaceX. If something goes wrong on this flight and it’s a hardware issue then they have to go back and retrofit it on the already built hardware. As opposed to having the fix designed and built right the first time.
It's not called stage zero for nothing.It sounds like all of the holds in those final seconds were due to problems with the launch structure and ground systems, not the rocket. It was the same thing with the scrub of Artemis II. I don't understand why ground systems seem to be the source of more scrubs than the rockets, which I would assume are much more complex?
A lot of complex stuff happens in the ground system.It sounds like all of the holds in those final seconds were due to problems with the launch structure and ground systems, not the rocket. It was the same thing with the scrub of Artemis II. I don't understand why ground systems seem to be the source of more scrubs than the rockets, which I would assume are much more complex?
The two modified Starlink v2 Minis will burn up with all the rest. They're not capable of significantly raising their orbits, quickly enough to survive the low-apogee, suborbital trajectory they're initially deployed into. And that's before taking into account the extra bolted-on mass to shoehorn them inside a Pez dispenser designed for much wider v3 satellites.What's the track for the satellite mass simulators and close-range-photography-capable Starlinks? I would presume the lumps would follow their launch vehicle into approximately the Indian ocean, but are the operational ones going to burn like a bat out of hell to give themselves a longer mission or just dump data into the network until the plasma takes over?
Ah, extra brackets would do that even more! I'm guessing that they can run fully internal until toast and won't need to deploy solar arrays, either. Should be another unique view from this development process (we've had a lot of those!).The two modified Starlink v2 Minis will burn up with all the rest. They're not capable of significantly raising their orbits, quickly enough to survive the low-apogee, suborbital trajectory they're initially deployed into. And that's before taking into account the extra bolted-on mass to shoehorn them inside a Pez dispenser designed for much wider v3 satellites.
So...it's just coincidence that the German Nazi's had a V1 and a V2 and this is a V3...right?
For it to be a coincidence, none of the people involved in the decision to use V[number] can have been aware of both the relevant history and the allegations against Musk. That is obviously absurd, which means one of two things is true:
1. They knew and didn't care.
2. They knew and chose it deliberately.
Either way, V[number] isn't a good look when the accusations of Musk being a NAZI were already a thing.
Perhaps the company that has built the most reliable, most available and most frequent launch vehicle knows something about improving systems and processes to be repeatable and successful?Agreed its very difficult to get this all right and safe and working for one launch.
So how is SpaceX going to repeat this 10 - 20 - 50 times in space for any Mars mission ?
The most N1-like piece of this rocket - the Super Heavy booster - has actually been the most successful and reliable piece of the architecture to date. The more difficult piece - Starship - is the real wildcard with regard to whether or not this design will successfully achieve full and rapid reuse. But even if full reuse remains out of reach, flying SS/SH in partially reusable mode - like a vastly upscaled Falcon 9 or New Glenn - would still yield unprecedented performance and historically low cost of mass to orbit.SpaceX is a repeat of the Soyuz program and the attempt by the Soviets to try their luck at a moonshot with the N1.
Experience and success at the smaller vehicle does not translate into a formula to build a larger rocket at scale.
How many years and how many re-writes / re-designs has Starship gone thru because the previous was tested and shown to be a failure ?
Even Musk the ultimate grifter knows Starship will n ever work and tahts why he is cashing out.
Oh please, even someone who hates Musk as much as I do can recognize the realistic assessment that SS is likely to be very successful.SpaceX is a repeat of the Soyuz program and the attempt by the Soviets to try their luck at a moonshot with the N1.
Not so much working for one launch, as working flawlessly for the inaugural launch. There is a huge difference there, but it might be too subtle for you to pick up on...Agreed its very difficult to get this all right and safe and working for one launch.
Hopefully fewer years than you’ll be posting ignorant slop like this.How many years and how many re-writes / re-designs has Starship gone thru because the previous was tested and shown to be a failure ?
Maybe the just repeat what they do with the F9 every day ?Agreed its very difficult to get this all right and safe and working for one launch.
"...Starship will never work..."SpaceX is a repeat of the Soyuz program and the attempt by the Soviets to try their luck at a moonshot with the N1.
Zach Golden's latest video deals with the design of the new deluge system, and he reckons the new gas generators aren't raptor derived. There's no turbopumps in there at all - it looks to be gaseous O2 and CH4 being fed into a combustion chamber that then warms up a massive flow of N2.You also have the deluge system that requires a massive amount of water driven at very high pressures, etc. (actually gas generators built from a set of Raptor derived power heads, rocket engine pressuring the deluge system).
That's the thing, it's only deranged people who think this way.Why would anyone who was not deranged care? Vn stands for 'Version N' - a commonly-used construction - and in fact I think SpaceX internally use 'Block N'. The V does not stand for 'Vengeance Weapon', and Starship is not a ballistic war missile.
Engineers pumped more than 11 million pounds of methane and liquid oxygen into the rocket in less than 40 minutes
Assuming Google AI's extract from the Australian War Memorial is correct:It's a version number. Specifically, Version 3. You're reading way too much into it.
If tacking version numbers onto things makes someone a Nazi then I'm guilty and so are an awful lot of engineers and developers. In fact I had an email from a vendor trying to talk me into upgrading to a higher Version this very morning. Maybe I'll write them back accusing them of Nazi sympathies....
Germany called the rocket "V-2" because it was the second in their lineup of Vergeltungswaffen (retaliation or vengeance weapons). Originally developed by the German military under the technical designation Aggregat 4 (A-4), the Nazi propaganda machine rebranded it to boost morale and threaten Allied cities
Unfortunately we've entered an epoch were derangement is becoming more and more common.That's the thing, it's only deranged people who think this way.
