Depending on how windy it is, I can imagine whyRandom nit pick but.. near freezing temps keep you from cycling? Below freezing sure, but you don't need much fancy to cycle in freezing temps. I think around -5c is when you need more specialized winter gear.
But your legs are not going to turn into one of your apartment's primary sources of energy.
Perhaps he just finds it unpleasant and would rather not?Random nit pick but.. near freezing temps keep you from cycling? Below freezing sure, but you don't need much fancy to cycle in freezing temps. I think around -5c is when you need more specialized winter gear.
Seconded - having a large-ish battery that i am trickle charging throughout the week would be a heck of a lot better than just directly charging small devices.I rather charge into a UPS or large back up battery, for more uses, than simply charging a cellphone.
That depends on whether it's near freezing because it's cooling down or because it's warming up. Encountering ice when the air temperature is above freezing is an "interesting" experience if you don't have studded tires on your bike. Ice with a thin film of water on it has an astonishingly low coefficient of friction.Random nit pick but.. near freezing temps keep you from cycling? Below freezing sure, but you don't need much fancy to cycle in freezing temps. I think around -5c is when you need more specialized winter gear.
near freezing temps tends to mean for me that cycling becomes dangerous because my road bike and ice do not get along.Random nit pick but.. near freezing temps keep you from cycling? Below freezing sure, but you don't need much fancy to cycle in freezing temps. I think around -5c is when you need more specialized winter gear.
When I was young and in grade school, they still had budgets for actual inventory, and in an early class about electronics, they had us using hand generators to drive lightbulbs. It was astonishingly difficult to drive a tiny little incandescent night light bulb. You had to crank like crazy to get it to light up at all, and it never got especially bright.
There's a reason we use all those other sources of power instead; biology is very efficient at producing mechanical work from food, but the scale is so tiny compared to what can be done mechanically that it's nearly irrelevant. You'd probably have to pedal hard for hours and hours to fully charge a laptop. You'd be so wiped out that using it afterward probably wouldn't be much fun.
What I learned, all those years ago, is that the amount of power coming from a US standard 120V outlet is miraculous, and something to be very thankful for. If you want exercise in inclement weather, this unit might do that, but it's not going to be a significant charge source.
Following “rule of thumb” that just means you’re cracking nicely into Zone 3. Depending on one’s goals for exercise, could be either good or bad. Myself, I’m solidly into Zone 3 on my indoor trainer, as I’m working on building cardio and building legs and core. I’ll pull down to Zone 1-2 for endurance every other day. Unfortunately it’s my arse that lets me down more than the rest of my middle aged carcass. Finding the right saddle for multi hour rides is not fun.Exercise physiologists will tell us that if we can't maintain a normal conversation whileexercisingusing our smartphone, we should slow down.
That gels with my experience. When I started to train last fall, 100W steady was an impossible effort. No part of my body could sustain it. Today I can sit around 200-240W steady. The longest I’ve held that pace on my trainer was about 1.5 hours, at which point both butt cheeks exited stage left. I’m in my late 40’s, getting back into cycling (definitely been playing in the snow the last few weeks!) and the only part of my shrinking physique that doesn’t wanna play ball is the ol rump. Got a new saddle last week that shows promise, as well as a suspension post. The pairing was awesome on the couple hour jaunt I did before going back to work.You can get 100watts of power out of a bike with pretty minimal effort. If somebody was biking regularly, I would guess that 150watts would be sustainable for a decent amount of time (certainly more than an hour or two) without major challenge. Certainly enough power that hours and hours to get wiped out is probably somewhat of an over exaggeration.
I do agree with others though, in my mind the best use for this would be charging a giant backup battery a percent or two every day. Seems like it would be a neat pairing.
Gear isn't hard. Back when I was messenger-ing I biked in 20 - 30 below fahrenheit. Wind was sometimes a problem but temp really wasn't.Random nit pick but.. near freezing temps keep you from cycling? Below freezing sure, but you don't need much fancy to cycle in freezing temps. I think around -5c is when you need more specialized winter gear.
But frozen eyelashes make one look so preeettttyyyPerhaps he just finds it unpleasant and would rather not?
I mean imagine having a different tolerance or comfort level to another person. Couldn't be me.Random nit pick but.. near freezing temps keep you from cycling? Below freezing sure, but you don't need much fancy to cycle in freezing temps. I think around -5c is when you need more specialized winter gear.
Second option is much better though because then you don't get weird look from UPS employees and / or have security called on you.I rather charge into a UPS or large back up battery, for more uses, than simply charging a cellphone.
Woth Zwift and my Kickr I’m basically heating the house. In the winter I guess it’s taking a minuscule amount of load off the furnace.Too bad you can't pair it with Zwift. Would be fun to power my laptop playing Zwift.
Also, agree with the others. I would buy a trainer that charges a large backup battery. In the winter, I could easily generate a couple thousand watt-hours per week, much less the rest of the year.
You don't have to tell my metacarpal twice.That depends on whether it's near freezing because it's cooling down or because it's warming up. Encountering ice when the air temperature is above freezing is an "interesting" experience if you don't have studded tires on your bike. Ice with a thin film of water on it has an astonishingly low coefficient of friction.
This reminds me of an olympic track cyclist taking on the "Toaster Challenge" - one of the most powerful cyclists in the world could just about toast a slice of bread - can't link the video but it's called "Olympic Cyclist vs Toaster: Can He Power It?"When I was young and in grade school, they still had budgets for actual inventory, and in an early class about electronics, they had us using hand generators to drive lightbulbs. It was astonishingly difficult to drive a tiny little incandescent night light bulb. You had to crank like crazy to get it to light up at all, and it never got especially bright.
That's me. I live in the desert and have more than ample opportunity to cycle when I don't find it unpleasant. On our cooler winter days I use that as an excuse to take a day or two off to use as recovery days. And still manage to get in well over 300 days a year of enjoyable cycling.Perhaps he just finds it unpleasant and would rather not?
Tolerance to what though? You won't feel cold above freezing temps if you have decent gloves, jacket, and headgear. It's only below freezing when you have to start adding lots of layers and normal gloves won't keep your hands warm.I mean imagine having a different tolerance or comfort level to another person. Couldn't be me.
There aren't any controls on the hardware; everything is controlled via software.
I just bought an ebike and for some reason everyone asks me if me peddling charges the battery and the bike is solely propelled by throttle. Beyond how much more complicated the wiring would be, it's way simpler and more efficient for it to just be a normal bike that's also got a battery/motor.When I was young and in grade school, they still had budgets for actual inventory, and in an early class about electronics, they had us using hand generators to drive lightbulbs. It was astonishingly difficult to drive a tiny little incandescent night light bulb. You had to crank like crazy to get it to light up at all, and it never got especially bright.
Alright, I was assuming this discussion would die off, but it clearly hasn't. For me, the big issue is the big difference in my internal temperature between the start of the ride and a half hour into things when I've really warmed up. It is a serious challenge to find the right level of clothing where I don't spend the first half hour miserably cold, and everything after sweating heavily and trying to find places to store all the layers I'm taking off. It is much, much easier for me to just deal with a single layer. The clothing I have at present keeps me comfortable down to about 40F (about 5 in civilized units). I could probably figure something out to manage lower temperatures, but then I'll be dealing with icy streets in some areas of my usual rides. In the end, I'm just not that desperate to bike in cold weather that it's worth the bother for me.Tolerance to what though? You won't feel cold above freezing temps if you have decent gloves, jacket, and headgear. It's only below freezing when you have to start adding lots of layers and normal gloves won't keep your hands warm.
Yes, so it can order me a pizza once I've burnt enough calories.Jesus Christ does everything need a god damn app?
And it has handlebars making it much easier to do a high intensity workout.Good lord almighty!
Running a stationary bike to power your cell phone...and other modern contraptions.
It sounds like overkill.
I have an exercise bike that's pretty basic, doesn't use WiFi, and I still get a decent work out.
It also cost $100 second-hand. It has a small battery run meter that tells the time, speed, calories burned and miles done.
Why does everything have to be so overkill in purpose and still lack the basics?
Everything is just turning into electric zombie stuff and still doesn't work.
For that price I'd demand a refund if it did not.
I wouldn't pay for beta testing any product.
I was going more for the dumb joke so the over-generalization was intentional. Twenty years ago when my carcass was 40, I'd run up mountain trails with my heart at 170 - 185 for an hour and a half. Now at 60 (and my skeleton a decaying ruin), maybe I could drive up the the same mountain in an hour.Following “rule of thumb” that just means you’re cracking nicely into Zone 3. Depending on one’s goals for exercise, could be either good or bad. Myself, I’m solidly into Zone 3 on my indoor trainer, as I’m working on building cardio and building legs and core. I’ll pull down to Zone 1-2 for endurance every other day. Unfortunately it’s my arse that lets me down more than the rest of my middle aged carcass. Finding the right saddle for multi hour rides is not fun.
