I keep seeing these "deals" for noise canceling bluetooth headphones for $250-$350.
Does anyone have a recommendation for a decent set of bluetooth headphones (NOT earbuds!) in the $50 range? Noise canceling not required.
The Cowin E7 seem popular are come in right at $50.I keep seeing these "deals" for noise canceling bluetooth headphones for $250-$350.
One thing about those Sony's is that the mics on them are utter trash. If you want to use them for just listening they're awesome, but if you want to try to use them as a Bluetooth calling device, watch out.
Yes, this x 1 million. Came here to also warn people about this. No one will be able to understand you when you call them, so don't bother trying.
Just bought this MPow H5 noise cancelling headphone about three weeks ago. Bought it for a tablet, not phone, so I can't speak to phone function. As audio, I'm basically happy. First ever noise cancelling for me, so no baseline from which I can compare. But I feel the noise isolation.I keep seeing these "deals" for noise canceling bluetooth headphones for $250-$350.
I bought a pair of Sony 1000xm3s and was thoroughly disappointed. As mentioned by another poster, the mic isn't great. Worse, the headphones would occasionally, briefly, lose sound. It was worse while outside in the winter when I'd wear the headphones under a thick hood.
I gave them two weeks before returning them. Massively overrated IMO.
Are there any over-ears that have good mics? The three I've had (one being the WH-1000XM2) all weren't great at picking up my voice in loud environments. I've only had good luck when using wired earbuds (not even wired over-ears unless I was using the V-Moda BoomPro which turns a pair of wired headphones into a full headset outright.)One thing about those Sony's is that the mics on them are utter trash. If you want to use them for just listening they're awesome, but if you want to try to use them as a Bluetooth calling device, watch out.
I have those - they're good but the speaker's supports are a little weak though. They're made of plastic and can break easily with the wrong applied force. Always remove the headphones grabbing both speakersThe Cowin E7 seem popular are come in right at $50.I keep seeing these "deals" for noise canceling bluetooth headphones for $250-$350.
I like the Urban Ears brand, had their wired headphones back in the day. The Bluetooth ones range from 60-100 depending on sales on Amazon.
They're nigh useless outdoors, and you have to talk pretty loudly inside, but I have found them to be usable. Not good at all, but usable. Luckily I don't use them to talk very often. If you do, I wouldn't buy them for that purpose.One thing about those Sony's is that the mics on them are utter trash. If you want to use them for just listening they're awesome, but if you want to try to use them as a Bluetooth calling device, watch out.
