This ^Regarding your final build: "Four 32 GB sticks". No, just no. In most cases, four DDR5 sticks will result in poor memory performance. I've seen news about certain vendors improving on that, but it's rare. There are some very good 48 GB DDR5 6000-6400 MHz low-latency modules available, which will give you a comfortable 96 GB build.
Can confirm that 4 RAM sticks was a horrible idea in my case - running a Ryzen 7 7700X on a ASRock PG Lightning B650 board with x2 16GB Kingston FuryBeast 5600MHz cl36 sticks - perfectly fine - put in 4 of the exact same sticks (even had the same manufacturing date) - constant random crashing if I try to run them on anything above 3600MHz (and even then it was not stable all the time). Borrowed a 64GB (2x32GB sticks, also 5600MHz) - works fine.A gaming system in 2025 should have at least 32 GB of RAM, period, so I don't like your second build.
Many games have been shown to consume up to 16 GB of RAM, so a 16 GB build will result in heavy swapping and terrible stuttering.
That hasn't been updated since early 2023, more than two years ago, so I don't use it anymore.I found the below list helpful for choosing a power supply.
https://cultists.network/140/psu-tier-list/
It should be noted that the Lian Li Lancool 207 has a maximum length of 160mm for the PSU. And they mean it.A comfortable 4K gaming rig
That remains a good list, but hasn't been updated in a couple of years. For PSU's released more recently, reviews on hwbusters, techpowerup and tomshardware are generally good, and were used as the source for that list.I found the below list helpful for choosing a power supply.
(I replaced the link since I can't post links yet.)I found the below list helpful for choosing a power supply.
<Link to Cultists Network Power Supply Tier List>
Hardware Busters is my current primary source for PSU testing. I also suggest relying on the Cybenetics rating more than 80 Plus, although they're a bit less widespread right now. Their testing process seems to be stricter and more thorough than 80 Plus's. My understanding is that 80 Plus primarily tests for efficiency, while Cybenetics tests things like how the PSU regulates current at various power draws, noise, and so on, in addition to efficiency (which isn't directly comparable to 80 Plus due to differences in testing methods).As for power supplies, we're looking for 80 Plus certified power supplies from established brands with positive user reviews on retail sites (or positive professional reviews, though these can be somewhat hard to come by for any given PSU these days).
For monitors I generally check the recommendations on rtings.com. They have different categories for things like gaming, media consumption, and resolution.Reading this I just had the idea that I should probably finally get a 4k monitor before spending money on upgrading my still perfectly fine system.
My 30"+24" Dell OLED monitors were great ca. 2008 when I started Uni and they still work fine, but there's probably not much innovation in that area any more and I'm just being lazy.
That said oh great hive mind, any recommendations? I do like good color accuracy and would mostly use it for development these days, but games once in a while.
Budget isn't a big issue these days, but I do prefer to not spend ridiculously for small gain just out of principle (and growing up poor)
I had a tough time finding a case with an external 5.25” drive bay for a previous build. I ended up putting my excellent BluRay reader/writer into an external enclosure. Works great. Also easy to move between systems if needed.Perfect timing, as I want to build a new PC. But after decades of macbook and thinkpad usage, I'm very rusty with all this PC building.
In my particular case, I'll use the PC for two things: reading/writing m-disc blurays and for VMs. So my priority is CPU and RAM. And the hardest part… finding a modern-looking case with a slot for an optical drive unit. I love the looks of the Fractal Nord, but I haven't found anything like it with an optical drive slot. Any recommendations anyone?
I'm still going 4 x 24". Makes multitasking a dream and also works with my eve online addiction.Reading this I just had the idea that I should probably finally get a 4k monitor before spending money on upgrading my still perfectly fine system.
Not a whole lot of options, but the Fractal Design Focus G looks pretty nice and has support for an optical drive. Also some HTPC cases that have drive baysPerfect timing, as I want to build a new PC. But after decades of macbook and thinkpad usage, I'm very rusty with all this PC building.
Since you can't go too big... Dell UltraSharp U4025QW is a good choice. Your 30" can shift to 2nd monitor position.My 30"+24" Dell OLED monitors were great ca. 2008 when I started Uni and they still work fine, but there's probably not much innovation in that area any more and I'm just being lazy.
Pretty amazing resource on first glance, thanks.For monitors I generally check the recommendations on rtings.com. They have different categories for things like gaming, media consumption, and resolution.
Oh right, 16:9, I completely forgot about that. I think that's why I gave up looking the last few times I got the itch.I'm still going 4 x 24". Makes multitasking a dream and also works with my eve online addiction.
They are 2560x1440 sadly but thinking hard about upgrading to 4x BenQ SW242Q just to get those vertical pixels that everybody and their dog likes to waste.
So many hours into that game in the mid to late 2000s.I'm still going 4 x 24". Makes multitasking a dream and also works with my eve online addiction.
That is why I want those BenQ SW242Q, they are 16:10 format. They have a cheaper "programmer" version that is also 16:10 but it comes with speakers which drives me fucking crazy so I'm prepared to pay extra for SW just to skip that particular idiocy.Oh right, 16:9, I completely forgot about that. I think that's why I gave up looking the last few times I got the itch.
Might just have to accept it.
If you can skip the pure modern part, check thrift/goodwill/habitat stores. Often an older system will show up for not much money with a decent case w/5.25" bay(s). Some of the 10+ year old cases still look pretty good. Sometimes you will get lucky and the guts are good enough for that family member that has been bugging you for a basic browsing type computer. Just put the old guts in the cheapest case you can find.Perfect timing, as I want to build a new PC. But after decades of macbook and thinkpad usage, I'm very rusty with all this PC building.
Make sure you are on the latest BIOS and default Intel power settings for that 14900K to mitigate the degradation risk. Same goes for the I7 if you get one.I just upgraded my rig, came into an i9-14900K and 64Gb RAM. Upgraded from a 3700x/32Gb RAM, I recycled my 4090/24Gb. I love it but damn is it loud when gaming! I have the Liquid Freezer III 360 and I've been tweaking fan settings so that it's quiet for normal use but gaming is loud. Currently I'm seeing 75-80C when playing PUBG. I'm seriously considering dropping down to an i7 just to get lower temps.
Honestly, just get a 2k (1440p) monitor instead. Most people can't tell the difference between 2k and 4k, they cost much less so you can get bigger monitors, and you'll save ~70% or more on graphics hardware since you won't need to run games in 4k.
PC Part Picker has some great guides as well, including real-time pricing at different vendors for whatever country you set it to. You can take one of those and then copy it into your own list where you can tweak and such, and it'll even check that you have enough power available for what you've picked.You, Sir, have impeccable timing. This is just what I need for my new system build.
