“I think the team has really experienced the loss of a loved one with the end of the mission.”
Don't you mean V'GER ?I feel a bit sad reading this. Just checked, we are still in contact with the voyagers.![]()
The MRO was planned for a primary mission of eight years, so it is on its third life right now.It's interesting that they're able to use so many different orbiters to do this relay function. Interesting and resilient! It's great that it can handle dropouts like MAVEN. As the system gets upgraded, I hope they keep all this inter-operability to handle the next failure. The Mars Reconnaissance Orbiter is the main link these days, and it's now 20 years old, almost twice the age of MAVEN.
6 MTN REQUIREMENTS
6.1 Project Requirements
MTN-REQ-001 Operational Lifetime
Threshold Requirement: MTN shall provide communications and Position, Navigation, and
Timing (PNT) services for a minimum operational lifetime of 5 Earth years, beginning at operational readiness.
Not just NASA orbiters either - ESA's TGO returns more relay data than any other spacecraft.It's interesting that they're able to use so many different orbiters to do this relay function. Interesting and resilient! It's great that it can handle dropouts like MAVEN. As the system gets upgraded, I hope they keep all this inter-operability to handle the next failure. The Mars Reconnaissance Orbiter is the main link these days, and it's now 20 years old, almost twice the age of MAVEN.
Tea. Earl Grey. Hot. You Philistine.Mom would let me stay up and even drink coffee while we watched the original series. Good times.
NewCrow:
Quoth the MAVEN, nevermore...
The alignment of this comment is chef's kiss
Got the numbers for the other planetary probes ?Here's a chart showing just how conservative NASA engineers are in their designs. The extended mission is given as a percent of the total mission.
Why do extended missions tend to take up such a large percent of the entire mission? Because the engineers want to ensure that the primary mission happens, so they design the probe to be extremely robust, which leads to the probe lasting longer than it had to. And since most of the money in a NASA mission is just building the probe and getting it in place, extending the mission costs very little (maybe $10M on a $150M primary mission). And so, unless one is an idiot of the first water, the obvious choice is to extend the mission until the probe finally dies of its own accord.
TL;DR: Primary missions are what sell the probe. But extended missions do the vast majority of the science.
Best way to guarantee it works for 2 years is to design it to probably last 10 years.It is worth noting that MAVEN's planned mission was two years. That it lasted eleven years is a testimony to the engineers that designed it and the team that kept it running.
If we lived in a just universe, there would be a replacement probe already on its way. Since we don't all we can hope for is that a replacement makes its way to the top of the list at the next decadal survey.
Yes, but I am too lazy to put them up right now. In general, they are about the same as those for Mars.Got the numbers for the other planetary probes ?
Haha, I didn't even consider it.The alignment of this comment is chef's kiss
Wondering where you got these percentages.Here's a chart showing just how conservative NASA engineers are in their designs. The extended mission is given as a percent of the total mission.
https://en.wikipedia.org/wiki/Spirit_(rover)
"The rover completed its planned 90-sol mission (slightly less than 92.5 Earth days). Aided by cleaning events that resulted in more energy from its solar panels, Spirit went on to function effectively over twenty times longer than NASA planners expected. Spirit also logged 7.73 km (4.8 mi) of driving instead of the planned 600 m (0.4 mi),[6] allowing more extensive geological analysis of Martian rocks and planetary surface features. Initial scientific results from the first phase of the mission (the 90-sol prime mission) were published in a special issue of the journal Science."
I really need to read the labels better, don't I?From your reference:
"Mission duration: Planned: 90 sols (~92 days) Actual: 2,208 sols (2,269 days)"
Thus, Spirit's primary mission lasted 92 days (1/4/2004 - 4/5/2004); the extended mission lasted 2,177 days (4/6/2004 - 3/23/2010).
So, the primary mission was (92/2269) 4% of the total mission and the extended mission was an amazing (2177/2269) 96%.
If we go by distance, then the primary mission would have been 0.6 km and the extended mission 7.13 km, giving 8% and 92% respectively.
Well, Wikipedia is not noted for the consistency of their formatting, so it is understandable.I really need to read the labels better, don't I?
I had to do a similar double-take, because my brain expected a percentage beyond primary mission, which would be about 2200% for Spirit.Well, Wikipedia is not noted for the consistency of their formatting, so it is understandable.
And I have been known to make boneheaded math mistakes, so it is always good to double-check.
That’s because most of them (at least those launched after 2005) fly the JPL developed Electra software defined radio (they’re manufactured by L3, but the hardware design and the software is JPL). The landers also use Electra radios (or Electra Lite). MER was the first Mars lander to use relay ops with an orbiter to return data, and after a week or two, it had returned more data through the relay link than all previous Mars missions combined. It’s that effective (compared to basic X-band Direct to Earth at 8 kbps)It's interesting that they're able to use so many different orbiters to do this relay function. Interesting and resilient! It's great that it can handle dropouts like MAVEN. As the system gets upgraded, I hope they keep all this inter-operability to handle the next failure. The Mars Reconnaissance Orbiter is the main link these days, and it's now 20 years old, almost twice the age of MAVEN.
I did but only because I knew my understanding and the reality couldn't possibly match those numbers lol.I really need to read the labels better, don't I?
And if doing NASA space missions triple-check, quadruple-check...then send it to your arch rival two doors down to see if s/he[/] can find any flaws. That is how you get missions that last decades beyond the initial requirements...Well, Wikipedia is not noted for the consistency of their formatting, so it is understandable.
Ah, you've been through the proposal process, I see!And if doing NASA space missions triple-check, quadruple-check...then send it to your arch rival two doors down to see if s/he[/] can find any flaws. That is how you get missions that last decades beyond the initial requirements...
Redundancy tends to be built into many things not easily repairable, even on Earth, just most people don't notice it. In space, a certain amount of redundancy is pretty much a given. Even Starlink's devices are redundant in that there's thousands of them to take over from each other when a few go belly up... or belly down as the case may be. Space communications networks tend to have that resiliency even on the ground. DSN has many different dishes for communicating with their science missions in space at each station including a single 70m ear (dish) at each, one at Goldstone, one at Madrid, and one at Canberra for the weakest signals.Ugghh, I was reading the MTN RFP requirements document and came to this (emphasis mine):
I then searched for a few terms like replacement, spare, etc and came up empty.
Hopefully they're going to plan for some redundancy that lets it go longer than 5 years.
You can not just use Starlinks as they are.Send the next 5000 Starlink satellites to Mars and call them MarsLink.
