Can someone explain to me why 16:9 aspect ratio is a bad thing? Is it outdated now in favor of 3:2?
Seems like buyers should consider buying the cheapest one and pop in a better SSD and RAM, that is of course if you don't need gaming graphics.
Thanks for the review, I had missed this product roll out. Definitely something for me to consider next time I'm in the market. My wife is the primary user of our laptop, and she'd value a better screen and usable keyboard over powerful internal specs (and I value a solid price point above anything). And as always, I can install a clean version of Windows (or even Linux) to fix the bloatware issue.
Laptopmag had a slightly more favorable take on the keyboard than you did, and also had nice things to say about the screen. Looks like a winner to me!
I don't think they're a deal anymore, given the unreliability. I'm not saying go out and buy this thing, basically 3 pounds of laptop, but I'm sticking with an old MBA because it's lasted us years as major purchases should do.The $900 model makes the MacBook Air look like a deal.
Is the storage correct in the specs chart?
Best is listed as 256GB
But has reviewed is 512GB.
Guess those are flipped or at least the best is wrong.
Claiming "anything" else overstates the generally valid argument. IDEs such as those from JetBrains, for example, do a great job of making use of extra horizontal space. (You could even consider the limited vertical space as another encouragement to keep your functions/classes short and to the point!) Many content creation applications have so much going on in different palettes and floating windows that they work great with a wide screen, too (Blender, Premiere).[...] But anything else (web, productivity) having more vertical space is better, less scrolling.
Companies usually send a machine with all the bells and whistles, and this review unit came without the nVidia GPU.
Hmm.. I guess this means that battery life with with this laptop is terrible if you're using GPU-heavy apps/games.
Not that I'd buy a machine like this for coding and video editing, but plenty of UI designers have figured out ways to make good use of the horizontal space of the dominant 16:9 screens.
This looks a lot like my 3-year-old Acer Aspire V, which is generally also "adequate" outside of its excellent touchscreen screen (I bought it refurbed, so the price was what sold me).
But what's less-than-adequate is the location of the power button, which on this one and mine is in a bizarre spot on the left side that is incredibly easy to press by accident when moving or adjusting the laptop.
This was a complaint common in Aspire reviews 3 years ago, and I'm surprised it isn't mentioned here. It's truly awful, and annoying to the point where it would prevent me from buying this.
A web browser on Windows doesn't use significantly (any?) more resources than a web browser on a locked-down Linux distro. Honestly, what advantage would ChromeOS offer other than a faster boot time? (Please don't say "no viruses".)This would be better as a ChromeOS laptop. If you need windows then you are going to want more performance.
It probably doesn't help that the MX150 is kind of an unflattering chip.
It has the great virtue of being able to lift games that are just plain unplayable on 'low' in an Intel 620/630-level integrated GPU to something north of 30FPS; making them at least passable; but while that's a significant real world virtue at the low end it's also the case that it gets beaten up and has its lunch money stolen by any real GPU; while even the lower-power variant(Nvidia is apparently so proud of this that the 10w "N17S-LG-A1" and the 25w and somewhat faster "N17S-G1-A1" are both sold as "MX150") is a good 50% extra TDP on top of the CPU, which does the battery and fan noise no good at all.
It has a niche, and it's not surprising to find a part there; but it's not a very glamorous niche. It's a pretty gimpy GPU by GPU standards; and a pretty thirsty part by ultrabook standards; which puts it in the fine tradition of mutually disappointing compromises.
The power button on the Swift 3 is on the top right hand corner right above the backspace, i've never hit it before by accident, and just now i pressed it briefly as if i might if i hit it accidentally while typing and nothing happened, you need to hold it down for a couple seconds to enable it.
