USB headers adapter
continuum
It has 2x USB 2.0/1.1 header. But the case plug do not fit. Male headers on board has a small gap between the 2 sets of 9 pins.
Where the case plug do not.
Looking at your motherboard on Gigabyte's website:
https://www.gigabyte.com/Motherboard/B850M-GAMING-X-WIFI6E-rev-1x/gallery#gallery
Your motherboard USB 2.0 headers look totally normal.
Okay, apologies, maybe I read your original post backwards. It now sounds like your case has only a USB 3.0 header?
In which case, this is the header you should be using on the motherboard, down at the bottom right.
Reactions: Jeff3F
steelghost
That case is old enough that the original version had an eSATA port when it was reviewed in 2011. Now case IO is one of those things that gets revised as a case ages, so yours may not have the exact same. But USB3 ports are (at least theoretically) compatible with USB2 peripherals. That said, if you can't make the front panel IO ports work, you probably just want to connect it to a motherboard back panel port directly.
You can also get this sort of thing so that you can connect it to your motherboard headers and get yourself four more USB2 ports, albeit on the back panel. But for things that tend to stay connected like headsets, game controllers, input peripherals etc, they work very well. I have one like that which is probably in its fourth or fifth system. It's not pretty inside the case, but it's super handy.
Reactions: Jeff3F
evan_s
With it being old enough to actually have front panel bays you could go for a 5 1/4 I/O panel on the front too if you aren't still hanging onto a couple of optical drives. That could add a number of USB ports of various types, Front panel audio, Card readers and probably a few other things depending on what you are looking for.
I totally missed the usb 3.0 header. Connected it and it works! Only issue is the case plug is straight and header is facing the outside and not up. HDD cage is in the way. Will need to find a right angle adapter.
I dont use the eSata. There maybe a way to replace it with a USB-C port connected to the type-E header on the board.
It most useful to have USB-C port in the front than in the back.
As for using 5.25 I/O panel is a good idea. This will expose more ports in the front.
continuum
At least from original versions of the PC-A04, I would speculate all those ports are a single piece, so absolutely no clue if yours is the same/even less clue if anything else would work. Maybe open your case up, you may need to remove the top panel or at least find some way to see how the ports are installed?
aka:
Now onto usb type c panel. Lian Li has a usb-c cable plug for LanCool case. Maybe it will work.
Seems like a bad gamble to me.
