"Biggest advantage of lower altitude is that beam diameter is smaller for a given antenna size."
I think the primary reason is for ensuring quicker deorbit times in case of a satellite failure. The "performance" improvement was highlighted by Musk - so it sounds like he's trying to gild the lily by saying that it will also improve latency as a side effect.I wonder if this means they don't expect to have Starship up to operational cadence anytime soon? Because IIRC the original plan was to have much larger satellites fly on Starship to give smaller spot beam size.
These satellites should be EOL by then. I think they're only planned to be up there for five years.I hadn't thought of the solar cycle affecting the minimum altitude like that, but yeah, obviously.
They may need to start moving them back up next time the cycle starts rising again.
Not just latency but speed too. That's because each satellite's spot beam is now smaller and therefore serves fewer customers, making average speed per customer in the beam go up.I think the primary reason is for ensuring quicker deorbit times in case of a satellite failure. The "performance" improvement was highlighted by Musk - so it sounds like he's trying to gild the lily by saying that it will also improve latency as a side effect.
The spot beams have a fixed 3 degree angle. They will illuminate a smaller cell on the ground once operated at a lower altitude.Spot beam would be larger if they're lower, not smaller. So, it sounds like you're trading improved latency for less bandwidth.
Reducing the distance between Starlink satellites and SpaceX’s 9 million Starlink customers will also provide a small improvement in latency, or the time it takes Internet signals to travel between a transmitter and receiver.
The area over which the satellites are distributed varies with the square of the radius, so a 1% change in radius decreases the area by (1.0 - 0.01)^2. Since the change is small, it effectively amounts to a 2% decrease in spacing, not 1%. But your point remains valid, it is a pretty small change.Although packed more tightly, the Starlink satellites won't be packed that much more tightly. The satellites are moving from a 341 mile to a 298 mile altitude; the radius of the Earth is about 3960 miles, so orbital radius changes from 3960 + 341 to 3960 + 298 miles, or from 4301 to 4258 miles. This is a change of 1%, and thus the resulting spacing between the satellites also changes by 1%.
did you make it to the second sentence of the article?I seem to recall that fairly recently we had a solar storm that was pretty severe. I'm assuming the orbit lowering is planned over the years to come and won't happen that quickly.
Starlink went from 4.5m users at the end of 2024 to over 9m users now. SpaceX is definitely worried about congestion, with many areas already over-saturated with customers and new customers having to pay an extra one-time fee just to connect.Newbie question: Is Starlink reaching limits of scale?
Ie. A narrower beam > fewer customers per beam (each satellite handles fewer clients/streams at once).
Musk said something similar, and I’m missing something. If there’s still the same number of subscribers and the same number of satellites, then won’t each satellite be serving the same number of users?Not just latency but speed too. That's because each satellite's spot beam is now smaller and therefore serves fewer customers, making average speed per customer in the beam go up.
Yeah, and you're potentially losing overlap if multiple satellites were able to provide failover/bandwidth.Musk said something similar, and I’m missing something. If there’s still the same number of subscribers and the same number of satellites, then won’t each satellite be serving the same number of users?
Think about it the other way: if the satellites were already at a lower attitude, and then the satellites were magically, instantly raised higher, each satellite could serve exactly the same users they could at the lower altitude right? Just because they can theoretically “see” other users doesn’t mean that they have to serve those other users (that’s the whole point of the beam shaping, etc).
Solar cycle predictions from NOAA suggest that the sunspot number should remain about this high throughout most of 2026 with a slow decline toward Solar Minimum underway by the end of the year. Between now and then, space weather will continue to storm.
There's an entire RF tower chain from NY to Chicago that was setup so that some high frequency traders could arbitrage the markets a bit faster than folks using fiber optics. I'm not sure if Starlink with RF up and down plus laser links through vacuum is faster than the RF through air plus repeaters, but if it is I'm sure someone paid Musk $$$$$$$ to use it for similar purposes (come to think of it, I'm sure that Starlink could be used to do such work between NY and London where RF relay isn't possible).https://www.wolframalpha.com/input?i=time+for+speed+of+light+to+travel+43+miles
0.2 milliseconds.
Couple decades back, a friend of mine worked at a NOC for one of the backbone networks. He was given an escalated support ticket from a customer who was complaining about latency between the east and west coast of the US being 15 milliseconds. He looked into the network, then paused, did the math, informed the customer that the speed of light limited latency to no less than 13.9 milliseconds, and closed the ticket.
This customer, I suspect, now uses Starlink and will the thrilled at the 0.2ms improvement.
Large solar flares can occur at any time, so even at the true solar minimum in the sunspot cycle, the risk never really goes away. What we're dealing with here is the change in ionospheric activity, and its knock-on effects on the atmosphere, that does follow along with the sunspot cycle.I seem to recall that fairly recently we had a solar storm that was pretty severe. I'm assuming the orbit lowering is planned over the years to come and won't happen that quickly.
Quote adjusted to make a point.Do we need this sh!t? I seem to recall Humankind got along just fine withoutglobal Internetindoor plumbing.
There are only about 3000 inactive payloads on orbit, plus a bunch or rocket bodies and other debris. About half of those are Soviet or Russian. And most of them are pretty old.14,000 active satellites of which, 8000 are Starlink satellites. Is that right, more than 57% of active satellites are Starlink?
How many inactive satellites are there?
Did we really?Do we need this sh!t? I seem to recall Humankind got along just fine without global Internet.
Stipulating that it's probably a dumb question, and acknowledging the slower (but still accelerating) pace of its development, but wouldn't a warming planet create the same kind of effects at altitude? Warmer gas expands, after all.There’s another natural reason for reconfiguring the Starlink constellation. The Sun is starting to quiet down after reaching the peak of the 11-year solar cycle in 2024. The decline in solar activity has the knock-on effect of reducing air density in the uppermost layers of the Earth’s atmosphere, a meaningful factor in planning satellite operations in low-Earth orbit.
NYC would be very high on my list of places where Starlink is a largely unnecessary service.If at their old altitude NY city had 10 beams pointed at them and at the new altitude they have 12 that's more bandwidth for everyone in NYC to share.
The beam size - or Earth footprint - is the crucial factor in allowing Starlink to serve more customers in the more dense regions of the planet, so I suspect that is the priority. Lower latency is serendipitous - a nice-to-have - but I don't downplay the "self-cleaning" aspects of those lower orbits; Starlink's future depends on making sure that defunct spacecraft do not impair operations....or threaten other satellite.I think the primary reason is for ensuring quicker deorbit times in case of a satellite failure. The "performance" improvement was highlighted by Musk - so it sounds like he's trying to gild the lily by saying that it will also improve latency as a side effect.
Our greenhouse gases and other climate meddling seem to be causing warming of the lower atmosphere and significant cooling of the upper atmosphere.Stipulating that it's probably a dumb question, and acknowledging the slower (but still accelerating) pace of its development, but wouldn't a warming planet create the same kind of effects at altitude? Warmer gas expands, after all.
What you're missing is that at the lower altitude they can use more spot beams.Musk said something similar, and I’m missing something. If there’s still the same number of subscribers and the same number of satellites, then won’t each satellite be serving the same number of users?
Sending a modulated neutrino beam would be even faster, especially for more widely dispersed cities, because you'd get essentially the speed of light along a straight line instead of following the curve of the surface of the Earth. Building a suitable detector is left as an exercise for the reader, but I'm sure one could get some folks to invest in such a scheme.There's an entire RF tower chain from NY to Chicago that was setup so that some high frequency traders could arbitrage the markets a bit faster than folks using fiber optics. I'm not sure if Starlink with RF up and down plus laser links through vacuum is faster than the RF through air plus repeaters, but if it is I'm sure someone paid Musk $$$$$$$ to use it for similar purposes (come to think of it, I'm sure that Starlink could be used to do such work between NY and London where RF relay isn't possible).
Since we're talking density instead of turbulence (as in ripping away some of the atmosphere to higher altitudes where satellites orbit from CME's) wouldn't a warming earth create the same issues, even if at a slower pace?
Not trying to troll this. It seems like a hotter atmospherics will expand, and that the solar storms lead to heating in the upper atmosphere which increased the altitude at which the atmosphere can interfere with satellite orbits. If that's the case, I'd think climate change would do the same thing. I don't know by how much or how fast (even if the pace of climate change is increasing).
I also get that the satellites up there in that orbit NOW probably won't be the same ones later if the atmosphere expands due to warming to the altitudes they do during solar maxes. So it's kind of a thought experiment at this point. I am being a bit lazy asking about it, but I think it's a bit of trivia that, if not relevant today, will be sooner than one might expect. So assuming I'm not misreading this situation, does anyone know the math for how soon that might be, or at what global surface temperature it would most likely occur?
Aren't all engines, other than cold-gas thrusters, plasma engines?The maneuvers undertaken with the Starlink satellites’ plasma engines will be gradual...
