And it's not any "ground loop" thing since it affects the S/PDIF optical out.
Hardware/OS:
i5-6600 (not K)
Asus Z170-A with Realtek ALC892
2x8G DDR4-2666
Asus GTX 1070 Dual O8G
Windows 10 64bit
(Full list)
I have a pair of speakers with S/PDIF and analogue input. The sound have been working fine from the S/PDIF out of the motherboard. I have set the line-in to listen mode so the S/PDIF stay on.
The PC have been used with two monitors, one connected via DVI and one connected via a HDMI->DVI adapter. Last week I replaced the DVI monitor with a Dell S2716G (1440p G-sync), connected by DisplayPort. Games are running great, but I started noticing random popping sound from the speakers when in games.
The pop sound is correlated to GPU load, just enabling GPU computing task in Folding@Home would cause it continuously. It sounds like the optical signal keep getting switched off and on. Switching to analogue output from the motherboard reduce the pop frequency, but I can still hear a bit of it.
I have tried:
- Update Realtek driver.
- Roll back to older Nvidia driver.
- Disable Nvidia audio output device in device manager.
- Disable "High Definition Audio Controller" on the same PCI bus as the GTX 1070 in device manager.
None of that helped much. Any idea on what else I should try? Is it a system bus bandwidth issue?
Not tried yet:
- Update BIOS. (Already second to newest)
- Flesh install windows.
- Give up and use the headphone out of the monitor as speaker out.
- Return the new monitor and go back to DVI.
Hardware/OS:
i5-6600 (not K)
2x8G DDR4-2666
Windows 10 64bit
(Full list)
I have tried:
Not tried yet:
