In an attempt to better serve advertisers
Wait, you mean it'll be a dumb TV if I don't have a Walmart account? This sounds too good to be true.
Unfortunately, if you keep eliminating manufacturers and retailers based on the shenanigans they pull, you will run out of both before you find a decent TV.Awesome! So next time I'm shopping for a TV I can automatically eliminate not only one manufacturer but one retailer as well! Every little bit to reduce the search space helps. Thanks Vizio and Wal-Mart!
I read that as the TV won't even TV at all until you login with a Walmart account. As soon as you power it on it'll require a login before you can even select an input. So even the usual "Buy a smart TV but don't use it as one" advice is severely compromised.In an attempt to better serve advertisers, Walmart, which bought Vizio in December 2024, announced this week that select newly purchased Vizio TVs now require a Walmart account for setup and accessing smart TV features.
A Walmart spokesperson confirmed to Ars Technica that Walmart accounts will be mandatory on “select new Vizio OS TVs” for owners to complete onboarding and to use smart TV features.
Can you not just login, unplug from internet, and use as dumb TV or does it require a constant connection to continue to TV? Smart TV that delivers ads and stops working without internet sounds an awful lot like HP bricking printers with firmware updates for using 3rd party (or sometimes even legit HP!) cartridges.I read that as the TV won't even TV at all until you login with a Walmart account. As soon as you power it on it'll require a login before you can even select an input. So even the usual "Buy a smart TV but don't use it as one" advice is severely compromised.
I'd like to be wrong, but I don't think I am.
Indeed. As long as it's priced affordably, this is a net benefit. Is it truly not sending Walmart telemetry unless you have an account?Wait, you mean it'll be a dumb TV if I don't have a Walmart account? This sounds too good to be true.
Becuase like all of them they push and push and push you to use them "smart" and set up an account.Why would anyone buy a Vizio when Samsungs and LGs are as affordable as they are?
A few TVs are already beginning to require an internet connection for initial setup, and an "always on" requirement is just around the corner. It's going to go downhill unless governments step in, and I don't have hope at this point.Wait, you mean it'll be a dumb TV if I don't have a Walmart account? This sounds too good to be true.
And this is the short, short road to ads on everything. And after that, the prices can march back up because what are you going to do, switch to the other guy doing the exact same thing?If the televisions are cheaper then I guess its a trade off s long as prospective buyers know before they buy.
(emphasis added)...Vizio TVs now require a Walmart account for setup and accessing smart TV features.
Nah. All the ad tracking and phone-home bullshit will still work without a Walmart account.Wait, you mean it'll be a dumb TV if I don't have a Walmart account? This sounds too good to be true.
Vizio was great 10 years ago. Then they got caught in the race to the bottom price war. And lost.
Not if not connected to the Internet.All the ad tracking and phone-home bullshit will still work without a Walmart account.
I can't seem to find the Pirates playing the nationals in my backup movies. Can you help?Just get an AppleTV, get the VLC app, set up a network share, put your "backed up" movies in the folder, press play.
I have a PX75-G1 from....2019? Wow, that old?Anyone who hasn't read these Arstechnia articles needs to go do it now.
Am I the only one that remebers the P, M, and V lines? (Pro, Medium, Value) Then the D line. Now it is all V or D equivalent. The P's were very good quality
I have NEVER used any smart features on a TV. I use Apple TVs. And if people don't want to pay for an Apple TV I tell them to get a Roku. A Google whatever is just a data hovering device for Google's ad services.
I miss my cable card Tivo. Tablo is getting to be the only "free" OTA option around.
Quite happy with mine.Vizio TVs have always had the worst audio (expecting you'd buy one of their soundbars). I returned the two I bought. Garbage.
M65Q6 from 2024.I have a PX75-G1 from....2019? Wow, that old?
It was among the nicest LCD TVs you could get at the time. It gets incredibly bright for HDR content. It was before 120 and 144Hz and VRR TVs became normal unfortunately.
It has developed an issue where the left and right backlight drivers are out of sync though. On fading transitions, you can see the right side dim like it's one frame behind the left.
