Only one US-built nuclear reactor has ever flown in space, and that was more than 60 years ago.
Here is NASA’s plan for nuking Gateway and sending it to Mars
Sigh. I guess we should be glad it's not SR-1 Mars Atomic Gateway Aquisition.SR-1 Freedom
Observational evidence suggests "no".Is it possible to stop giving spacecraft stupid stereotypically USA!USA! rah-rah names like 'Freedom'?
It's pointed out in the article, basically all parts are paid for already.sample recovery was too expensive but a whole space station mars vehicle isn't I guess? nasa is already getting magafied isn't it
you want them to call it Trumpship one?Is it possible to stop giving spacecraft stupid stereotypically USA!USA! rah-rah names like 'Freedom'?
The part that feels like flag planting is that they are tightly limiting the mission to actually achieve something. That’s a welcome change from bigger programs that are permanently 10 years away from flying.Not sure how I feel about this basically being a flag planting mission. But it is definitely pretty cool. Hopefully they can use this as a new relay satellite for a long time.
Once it drops copters on Mars, it's going to head back to Earth for next load.So it's an interplanetary nuclear powered aircraft carrier? Rad!
I think the reason they're doing it is to buy it more insurance against being axed by congress (how does that old saying go, 'no Buck Rogers, no bucks'?).Is it possible to stop giving spacecraft stupid stereotypically USA!USA! rah-rah names like 'Freedom'?
HEU (Highly Enriched Uranium) isn’t very toxic and is not very radioactive. Which is why you see technicians handling fuel rods for such reactors with gloves and masks.There needs to be a step change in rocket safety before you can even launch that much fissile mass. Just to keep the weight down, avoid a Xenon pit and to have the longest life per kg of mass you are probably going to need highly enriched materials. You significantly do not want that spread over a wide area because of a failed launch.
It's not a US-exclusive phenomenon, try translating some Russian or Chinese spacecraft names. For example, 'Soyuz' means 'Union' and 'Tiangong' means 'Heavenly Palace'.Is it possible to stop giving spacecraft stupid stereotypically USA!USA! rah-rah names like 'Freedom'?
Freedom has been NASA's placeholder name for a space station since the replacement for Skylab was mooted in the 80s. I'm not sure what it's doing attached to a NEP demo, though.Is it possible to stop giving spacecraft stupid stereotypically USA!USA! rah-rah names like 'Freedom'?
"No bucks, no Buck Rogers" is the line from "The Right Stuff". But yes I assume that is definitely the intent.I think the reason they're doing it is to buy it more insurance against being axed by congress (how does that old saying go, 'no Buck Rogers, no bucks'?).
If thats the case, I couldn't give less of a damn about what they choose to call it.
This seems like a solid R&D mission. Not sure how you get flag planting, there's nothing here that hasn't been done before in terms of going to Mars, or flying a drone there.Not sure how I feel about this basically being a flag planting mission. But it is definitely pretty cool. Hopefully they can use this as a new relay satellite for a long time.
Skyfall is pretty bad tooIs it possible to stop giving spacecraft stupid stereotypically USA!USA! rah-rah names like 'Freedom'?
RTGs have also been used for other NASA Deep Space missions such as New Horizons and Galileo because past the orbit of Jupiter, solar power becomes uneconomical as a way to power space probes (the solar panels that power the Juno probe in orbit around Jupiter are massive to compensate for the weaker concentration of solar radiation that reaches out to Jupiter's orbit). RTGs have also been used to power the Mars rovers Curiosity and Perseverance, as previously NASA had mixed results using solar power on the dusty surface of Mars.Wikipedia tells me Voyager 1 and 2 (and many others) use a "radioisotope thermoelectric generator (RTG)"
Just need to change one letteryou want them to call it Trumpship one?
That's exactly how an RTG works. The natural decay of the radioactive source generates heat, with associated thermocouples generating electricity.was thinking, surely the Voyager missions launched in the 70s used nuclear power as well, given their long lifespan remote from the sun? Wikipedia tells me Voyager 1 and 2 (and many others) use a "radioisotope thermoelectric generator (RTG)" which uses plutonium-238 to generate heat for electricity. Sounds a lot like what I'd call a nuclear reactor, but I guess the latter uses a chain reaction while the former "just" relies on elements to decay and is therefore more like a battery.
Technically, all nuclear reactors ever placed into space (mostly Soviet designs) have also used systems identical to those or like those employed on RTGs to convert thermal energy into electricity.Wikipedia tells me Voyager 1 and 2 (and many others) use a "radioisotope thermoelectric generator (RTG)" which uses plutonium-238 to generate heat for electricity. Sounds a lot like what I'd call a nuclear reactor, but I guess the latter uses a chain reaction while the former "just" relies on elements to decay and is therefore more like a battery.
Curiosity and Perseverance are nuclear because of how power-hungry they are. Solar arrays large enough for them would obstruct their vision and be difficult to manage on uneven terrain.RTGs have also been used for other NASA Deep Space missions such as New Horizons and Galileo because past the orbit of Jupiter, solar power becomes uneconomical as a way to power space probes (the solar panels that power the Juno probe in orbit around Jupiter are massive to compensate for the weaker concentration of solar radiation that reaches out to Jupiter's orbit). RTGs have also been used to power the Mars rovers Curiosity and Perseverance, as previously NASA had mixed results using solar power on the dusty surface of Mars.
Given the details from that slide (*), it's almost certainly Westinghouse's eVinci-derived design, i.e. heat pipes, HALEU, Brayton cycle engine. With some sarcasm, Kilopower seems to exist so that people can say that nuclear power in space cannot work because not enough power per mass, not enough power, limitations of Stirling engines etc. eVinci reactor has far more scope for cranking up the wattage, considering it's positioned as "nuclear battery" for remote mining installations.Is the nuclear power KILOpower (eg. 2x 10kW) or something else?
eVinci is designed to run 8 years on full blast before it needs refuelling, so presumably that's not a limiting item unless Nasa plans to take it on a tour over the Solar system.. Unlikely it'd carry enough reaction mass for the hall-effect thrusters to go to, say, Saturn, though.If they are sending it to Mars, then put the Mars comm relay gear on it and put it in a high enough orbit that it will be there for many years. It's got enough solar to keep it flying long after the reactor is spent.
