I am guessing that they aren't both called "corner mode".Each car’s front and rear wings are now active, with a raised position called corner mode that generates lots of downforce, and corner mode, which drops both wings to minimize drag
is paired with a 4 Mj (1.1 kWh) battery pack
Maybe dumb question, but how can the car deploy more than double the battery capacity? Does it recharge fully within a lap?Cars are allowed to deploy up to 8.5 mJ (2.4 kWh) of electrical energy per lap
Regen during the lap.Maybe dumb question, but how can the car deploy more than double the battery capacity?
Finally, we’re starting to get a better idea of how F1 coverage will work with the move to Apple TV here in the US.
I’m pretty sure the unbelievable reliability that’s been a feature of F1 for the last few seasons may be a thing of the past, at least for the first few races in 2026. Up and down the pit lane, teams have missed hours of practice sessions as they troubleshoot gremlins. Aston Martin looks particularly bad in this regard, even in comparison to brand-new Cadillac.
I could use the longer explanation for this.the MGU-K won’t be used at race starts—it only begins to contribute above 50 km/h (31 mph). That’s to prevent the danger of some drivers depleting their batteries and therefore slowing much faster than others in the approach to the first or second corner at the start as they superclip
I'm not sure where you are located, but if you sub Apple TV you can still sign in through the F1TV app like before. You never actually have to use Apple TV.I was following F1, but I don't use apple TV nor will I
the forced into is bs also annoys me.
I don't think it's going to be that exciting because they basically capped energy use per lap.
with 50% max from engine and 50% from battery it's set how much you can use. If everyone uses it at the same time, they should all maintain about the same speed. Woo. fun
that's not exciting racing that's just whomever can do math better.
Knowing Ferrari, they'll shoot themselves in both feet.No mention of Ferraris rear wing? Everyone is getting very excited over that....
Edit; poor use of words.
It just showed up today!No mention of Ferraris rear wing? Everyone is getting very excited over that....
Ferrari tested an interesting approach to this in Bahrain at one point, with rear wing elements that flipped a full 180 degrees. I wonder if we’ll see that in-season.
They still have the flow regulators that measure fuel injection though. But I do like your creative problem solving...Bacon Briefcase? WTF does that mean
Regardless, I know how I'd cheat. With the sustainable fuels, I'd make slowly dissolving fuel lines that add energy to my fuel. Maybe not so slowly dissolving for qualifying. The fuels are going to be a huge part of the competitive balance this year.
I've seen it said in places that the movable front element does very little to change drag. Moving it does reduce the amount of downforce. Now, I don't completely understand all the losses that additional downforce is creating, but a few engineers seemed quick to point out that while the rear wing does produce a ton of drag, the front elements generally do not, so the active elements are accomplishing slightly different things on each end.
You missed this bit: " Ferrari tested an interesting approach to this in Bahrain at one point, with rear wing elements that flipped a full 180 degrees. I wonder if we’ll see that in-season."No mention of Ferraris rear wing? Everyone is getting very excited over that....
I did....You missed this bit: " Ferrari tested an interesting approach to this in Bahrain at one point, with rear wing elements that flipped a full 180 degrees. I wonder if we’ll see that in-season."
The front wing shapes the air in front of the tires.I've seen it said in places that the movable front element does very little to change drag. Moving it does reduce the amount of downforce. Now, I don't completely understand all the losses that additional downforce is creating, but a few engineers seemed quick to point out that while the rear wing does produce a ton of drag, the front elements generally do not, so the active elements are accomplishing slightly different things on each end.
https://www.fia.com/news/fia-statement-formula-1-power-unit-advisory-committeeI'm mostly curious about the engine shenanigans Merc and RB are supposedly pulling, with combustion ratios increasing while hot. Playing games with CTEs almost always leads to unexpected failures in my experience, so I'd love to get more details about what they're doing, or if the FiA treats it seriously enough to modify the testing rules as they've been discussing.
There is a video on the official F1 channel (done by the Tech Talk guy) where he monitors a bunch of practice starts from the pit lane. With the MGH-K no longer muffling the exhaust, it's 5-20 seconds of absolute HOWLING noise before the start. If you're going to an event, you're gonna want to wear earplugs for the start if you're in the home stand!And I'm looking forward to the chaos of the new revving procedures without the MGH-U to reduce turbo lag. All the cars need a good 10-20 seconds of revving prior to launch. Will be interesting to hear what that sounds like...
Everybody would, but nobody's talking. There's no dynamic adjustment or chip thing you can do to change it, right? There has to be something in there designed to expand in a controlled fashion to get this done. As a RB homer, I don't necessarily want this to be banned and exposed afterwards -- but as a nerd, I am dying to know at the same time.I'm mostly curious about the engine shenanigans Merc and RB are supposedly pulling, with combustion ratios increasing while hot. Playing games with CTEs almost always leads to unexpected failures in my experience, so I'd love to get more details about what they're doing
Little wonder Stella/Mercedes teams were bringing up the "safety issue" with starts.Also going back to the start procedure/long revving to offset turbo lag, Ferrari brought this up as a concern last year and it was dismissed. Now all the other teams want to change start up procedures. Meanwhile Ferrari off the start is: https://streamain.com/en/03U0Aisp9RzTXTJ/watch and https://packaged-media.redd.it/081t...00&s=ec1b21ff1d8d8903d3e57a16ce18f25d901a3569
Ferrari doesn't want to change now, because they might have been the only engine manufacturer to really think through the turbo lag issue during design...
The honest drivers are not, and so are some of the better F1 journalists. If you listen to some of the driver comments, they all tell you the cars are less fun to driveEveryone is super-excited for these new regulations,
1. Eliminating quali would take whatever fun there was out of tracks like Monaco. Plus, it's interesting to see which teams aim to do well in qualifying and hold onto their position during the race, versus optimize for the race and hope to survive quali.F1 race day will not improve until at least one of the following is adopted.
1. Get rid of qualifying and adopt a reverse grid start based on the current season leader board. Why was giving extra advantages to the fastest racers ever a good idea?
2. Get rid of aero. Real racing means cars, gasp, get close. Would anyone notice or care that top speeds are 180 mph instead of 220 mph? Didn't think so.
A lot of commentators have attributed some of this to a couple elements of the hybrid system. First, variation in how much electric power a car is deploying or regenerating on the straight before a big braking zone means that cars are approaching the corners at a much wider range of speeds than the previous generation. The drivers seem to still be getting used to how this affects the braking point.The really interesting thing I'm seeing in testing is the insane number of lockups everyone is having. Seems to have to do with switching the active aero into corner mode (possibly changing the load balance). Some teams seem to be getting on top of it, some are not -- Aston and Racing Bulls look to be squaring off tires like nobody's business still. The fun part is that it affects and is affected by everything -- your aero, your actuation of your active aero, your suspension, your brake balance, on and on and on.
The Dutchman did not pull any punches when asked what he thought about the 2026 F1 cars, saying it felt like he was driving in Formula E.
Facing the media in Bahrain on the first day of the final preseason test, he claimed he was not the only driver with a negative view on the new rules, saying: "“Most of them think the same way.”
The likes of Lando Norris and George Russell do not agree with the Dutchman, so when it was suggested to him that two camps are emerging, he quipped: "That one camp is more like a small easy-up tent; the rest are in a very big tent. So it’s one small camp and one big camp!
“I might be a bit more extreme in how I say it, but that’s also because I don’t really care that much [about what others think]. Some people are a bit more diplomatic," he explained.
Someone just needs to ask the French.I mean, Brits aren't known to speak their mind in a straightforward way. The Dutch do.
Really? Lift to reduce friction (and increase speed without increasing power) without being catapulted? I got that image, I sure hope it is not that dramaticIt looks wild as hell. I thought they said that they'd use it for the Australia GP at least? Really interesting development. It actually generates lift vs only reducing drag. Will be fascinating to see how it performs in the straights vs others.
