I'm an embedded systems engineer and I once worked on a product that had dimmable front panel LED's. We used pulse width modulation to control the intensity. This means that you turn on the LEDs to full brightness for a short amount of time, then turn them completely off for a short amount of time. You do this faster that your eyes can detect. The longer the "on" time is, the brighter the display appears to the be. Your eyes average out the on/off flicker and only see the display as a solid intensity. Since this is the best way to dim an LED display, from a battery usage stand point, I'm sure Apple is doing the same thing to control the display panel's backlight LEDs.
When the front panel was at a low brightness, the LEDs were pulsed for a very short amount of time, and the results were some pretty intense RF generation -- more than we had counted on. We ended up having a problem with bleed over into other parts of system. Our temporary solution, (until the hardware could be updated), was to issue a firmware update to limit how far the display could be dimmed.
So their solution of increasing the screen's brightness to limit RF interference, makes perfect sense to me.
