That VMware Converter is awesomely awesome.<BR><BR>Used it a couple of times before on healthy, non-critical stuff. Client had a very sick win2k/ex5.5 server with all sorts of config oddities (was effectively a one-node cluster, for one thing). It had corrupted it's information store and had real problems with it's logfile and DB arrays - just copying a few small files about would take forever, sometimes hanging it either temporarily or permanently. IS far too big to be fixed with eseutil or isinteg, and restoring it from tape would fail after a couple of hours at horribly slow speeds.<BR><BR>They'd had some disk failures in the past but the controller was quite happy with the state of things, and no relevant events to say something was amiss. No spare controllers to try either.<BR><BR>Fortunately they had an ESXi box which we'd prepared for another project. Put on Converter, set the ESXi box as the target, a little over an hour later it's virtualized self was running perfectly. Restore worked great, IS came up fine, the world is saved.
